Meshmixer: Generate Supports
Intro: Meshmixer: Generate Supports
In this section of the user manual we'll walk you through support generation.
Meshmixer for Ember User Manual
STEP 1: Generate Supports
To automatically generate supports for your model in Meshmixer.
- Click on the model you want to support.
Tip:If you want to support multiple models in one go, you should first combine the models.
- Click "Analysis" on the left toolbar and then "Overhangs"
- In the "Overhang" menu, make sure that "Autodesk Ember" is selected in the top drop down menu
- Click "Generate Support", supports will automatically be created for your model
- Individually supports can be deleted by secondary clicking on them
- On Mac: CMD+click
- On Windows: CTRL+click
- Click "Done" to save the supports
Note:DO NOT click "Convert to Solid"
- Repeat for all un-supported models
Tip:
To learn more about support generation read the Advanced Support Generation Tutorial
5 Comments
bobbyJi3177 2 years ago
warhawk8080 5 years ago
DáliaG2 6 years ago
Why not make solid? Where is Advanced Support Generation Tutorial?
Thank you
Frankv14 7 years ago
Presumably this is all aimed at someone using an Ember 3D printer, and someone with a different printer should *NOT* choose "Autodesk Ember" in the first dropdown menu, and should probably adjust the various settings as best they can. In particular, the Y-offset should be set to 0. It seems to me that the right workflow then is to "Convert to Solid" then use (e.g.) Slic3r to produce the Gcode.
Where can I find the "Advanced Support Generation Tutorial" as per the "Tip"?
koisurusuagi 8 years ago
I've been experimenting with this. Why not convert to solid? I've noticed my prints fail when i do that.
