Milk Top Bowl
Intro: Milk Top Bowl
Hi
This insturctable will go through how I turn milk bottle tops (and various odd ones) into blanks for working with, mainly for turning but you can work it just like timber so your imagination is your limit :)
To start off with you need LOTS, just to be clear here LOTS of milk bottle/coke/fabricsoftner tops I get various places like cafes, staff canteens an family to save them for me just ask whoever you can.
A mold, this should be near the shape/size you want to use less caps, in my case im making a bowl so i used a bowl. If you want to be safe have one that you can melt into at 200 celsius because trying to melt it and move molds is unplesnt the lids retain loads of heat and stick to most surfaces so its just asking to cause serious burns.
An oven to melt it in. an expensive bit of kit but if you look hard in the kitchen (the place you take the lawnmower apart when it breaks before you manly shave the lawn) you might be as suprised as me that you already have one. (same applies to the mold the next cake my wife bakes will have plastic in it...)
And a work shop or tools to create! in this case a lathe was all i needed
STEP 1: Wash and Dry
This is a really important step if you don't want material that smells of old milk and this is also a good time to remove any of the little silver seals stuck in the lids.
STEP 2: Fill Your Mold
STEP 3: Remove the Blank
this was a gamble as i usually do this in loaf tine paper cases so the just lift out but this time i decided to see if glass would keep it loose, it didn't until i stuck it in the oven at 200 for 5 minutes then up ended it which should work on all smooth molds? but wont leave the mold completely clear. this can be remidied if really needed with more heat just burn it out after scraping any big bits off the hot surface.
STEP 4: Make!
Whatever you want to i've done pens, bottle stops, garden dibbers and now a cereal bowl.
This isn't a wood turning tutorial (i can do one at some point if its wanted) but I will take anyone interested through my process (everyone works differently especially with turning)
I mount the blank between head tail stock as centered as I can by eye (brilliant tool impossible to buy a new one even from screwfix so put a protective case on yours such as goggles) and then make it true round from said centers and the shape i want before cutting a rebated dovetail in the base for my chuck jaws to expand into and grip.
clean the base as you wont have it spinning at 2000rpm and accesable at the same time after this.
spin the blank round and grip with the jaws and turn out the center which ever method you prefer as the all work on plastic do a clean pass on the outside and the rim aswell and make it all nice and clean and then out have a bowl.
STEP 5: Done
my first suggestion is save the shavings or any other type of HDPE you can get as they can all be melted together.
second suggestion is be really creative with ideas and if you can implement them let me or others in the comments know about them so we can try them.
third is tell me off for grammar and spelling as needed as I'm more comfortable with a chainsaw then with writing stuff.
And lastly if you like this idea or instructable spare me a vote?
All the best making and breaking and thanks for reading
123 Comments
kthlnworth 1 year ago
I have loads upon loads of baby food tops I have been saving from the screw off kind. (Because I recently lost all my teeth and baby food is a. Huge option) Well I have lots of colors and I already did one soak. But for a bowl I will do another.
Do you recommend one of those hobby ovens you can cook in from the garage with the doors open? I have read melting plastic in your kitchen can set off bad fumes.
Also, how do I find out if my top will melt. I know it is recyclable but is it meltable? Just wondering?
Thanks for your help!
ChattyK
bick577 8 years ago
thank you. Such a fun idea
danzo321 8 years ago
Mixing ought to free some of the air bubbles but you might prefer the blotchy color
Tomahawk92 8 years ago
I think it would be very hard to mix, it doesn't liquefy. It just gets goopy.
matt.sims.37266 8 years ago
lovethebackwoods 8 years ago
Matt, it's a beautiful bowl! I am an art and language arts teacher, among other ventures, and we use those colored caps for all sorts of things, however, I've never done anything like this. I can't wait to get started. Thanks for your clear instructions and great photos! I enjoyed reading this. Your Instructable makes sense so just ignore the whiners!
Fredfly 8 years ago
2.the bowl can give you cancer, melting plastic can make the plastic dangerous.
2 no melting plastic is perfectly safe and won't effect your health burning plastic on the other hand will.
gingerbaker 8 years ago
It's not necessarily the plastic itself which is dangerous, but the plasticizer compounds which may be present. These, if present, are estrogenic and definitely carcinogenic.
See: http://www.ncbi.nlm.nih.gov/pubmed/19463926
noahspurrier 8 years ago
funny1048 8 years ago
yes its definetely pvc this plastic has plasticizers in it to make it more flexible hdpe is completely safe
chancefour 8 years ago
Is there a concern with fumes? Seems like there would be some trouble there at that temperature. No?
nope hdpe is very inert and has very low toxicity even lower than paraffin when i melted the hdpe there was almost zero smell its a very safe plastic just be sure it's hdpe remember never melt down pvc or styrofoam these types of plastics are very toxic and will produce very dangerous fumes
Thank you. Do you know of an adhesive a person can use on this material? I would love to use PVC cement as it melts the two surfaces together, but I am not sure it works on this kind of plastic or the other part of the milk bottle plastic. Have you tried to bond one piece to another?
Thank you.
Look at it this way, many PVC and acrylic cements and solvents are distributed in HDPE containers, so that should be a clue that you're using the wrong glue for HDPE.
taur561 8 years ago
just as a matter of interest , if you take your wife's used cooking oil and heat it up to just below smoke point ( the stage when it burns and smokes ) , then drop your plastic caps into that , they become soft and gooey like thick syrup and can be removed with tongs from the oil and rolled or shaped over a bowl to give a similar effect . Afterwards you wipe off the oil and wash with soap to remove the oil . Just work carefully as hot oil can seriously burn you if you get it on your skin . The benefit is you have no fumes except the smell of cooking oil as though you are frying fries . Still a good idea as you are recycling waste . Here in Africa they are now making plastic logs and plastic planks from waste . Makes great outdoor furniture , garden bridges etc and never rots or gets eaten by termites .
oil actually isnt needed at all all you need is an oven which you set to 330-340 degrees f the hdpe will flow without any kind of smoke or burning as long as you take it out when it all melted and the bottle caps are actually made using a process called injection molding which means bottle caps have a high flow rate when melted and therefore will flow into a mold without any kind of pressure
