Minecraft 3x3 Door - NO PISTONS!!!!!
Intro: Minecraft 3x3 Door - NO PISTONS!!!!!
What you'll need:
- 18 command blocks
- 9 blocks of your choice (for the door)
- Redstone Dust
- 1 lever or button
STEP 1: Create the Door
Place the 9 blocks of your choice to make a 3x3 square.
STEP 2: Place the On/Off Switch/Button
Place your switch/button two blocks away from the door to the left or right. I, for example, put mine on the left.
STEP 3: Place the Command Blocks & Redstone
Look at the picture above. IT IS VERY IMPORTANT THAT YOU PLACE THE COMMAND BLOCKS, OR GATES, AND REDSTONE AS SHOWN IN THE PICTURE, however. If you are experienced with redstone then you might be able to edit the layout, but I do not recommend doing so.
STEP 4: Code the Command Blocks
NOTICE: THIS IS THE HARDEST PART!
Start by going into every command block and typing "setblock".
Next, find the coordinates for every block of the wall and enter the coordinates into Section A & B.
Don't understand what I mean? Here's an example: If the bottom left block of the wall's coordinates were "X: 200 Y: 40 Z: 200" then I'd enter that into one command block in each section, so that the command in the two command blocks looks like this: "setblock 200 40 200".
Now, enter the id of the block of the wall into Section B.
For example, if my entire wall was going to be iron blocks then I'd put "42" or "minecraft:iron_block" into all of the command blocks in Section B. Then it should look something like this: "setblock 200 40 200 minecraft:iron_block"
Finally, in Section A do the same thing that I said in the example, but put "0" or "minecraft:air" instead of the block the wall is made out of.
STEP 5: Check It!
Now, check that what you've made looks nearly exactly like the picture above.
STEP 6: Test It Out! (Video)
Now you've successfully made a silent, fast, reliable, and new 3x3 Command Block door! Enjoy!
21 Comments
J-CODE-BUILDER 10 months ago
MsSweetSatisfaction 9 years ago
Hmmm that's a cool design, you'll have to show us if you come up with any other applications for this design.
Geeks with lasers 9 years ago
setblock has one hundreds of uses. I've used it to build a bridge thats activated by a switch, or my personal favorite was to use a timer circuit to build a moving bridge :)
Max490 9 years ago
callahanelias-100 3 years ago
I've started on an instructable for making a moving platform bridge with "/setblock" So i'll let you know when its done.
Got destracted mid make, by someone loging on to my build server and starting destroying things :(
Max490 9 years ago
I'll have to make another Instructable showing how to make it.
Henryworks 8 years ago
This is awesome! but I made some ajustments, now it looks like a door is opening, not "its there" "bop! now it isn't"
Lasanga4 4 years ago
Very CreepyC 8 years ago
same here
it is amazing tho
hl9019145 3 years ago
cars367 9 years ago
BlueRobot 9 years ago
/Commands
It has the list of commands:)
wbarnes24 4 years ago
