Mitre Saw Levelling
Intro: Mitre Saw Levelling
A while back I installed my mitre saw into a recess in my workbench. All was good and the saw was level with the bench on either side.
I needed more bench space so I installed an electronic ram underneath and hinged the platform to allow the saw to drop below the level of the bench, like a flip-top but I'm lazy.
When it was all back together, the saw was sitting a little lower and not level with the bench, the wooden area under the saw had sagged a little due to the central support rather than screwed in from all sides. This was going to result in 1 of 2 outcomes:
- all of my cuts would be a little crooked
- The wood while under downward pressure would bow and bind on the blade, this is not super dangerous in the mitre saw but a bind or kickback is never desirable.
I didn't want to take it all apart again so here is how I set about leveling it all out using some threaded inserts and bolts with lock-nuts.
STEP 1: How Bad Was It?
From the images, you can see that the saw was sitting several millimetres lower than the worktop and what was worse it wasn't level, this made for crooked mitres and it was dangerous to use as the wood started to bind when cutting and it collapsed into the drop to the bed of the saw.
STEP 2: Preparation
I removed the saw from the recess.
When the saw is flipped over I found a nice consistent flat spot close to the mounting hole.
Using a reference distance from the mounting hole, I drilled an 11mm hole for the insert.
The inserts were threaded in from the top of the work surface, they are 10mm deep and the timber is 18mm, the reason I went from the top is that the force will be applied downwards, the insert will push against the top. If I went in from the bottom there was a risk of bursting out of the plywood under the force.
STEP 3: Levelling
I threaded in some M8 bolts pre-fitted with nuts from the bottom, the nuts would be used to lock the bolt in place once the levelling was correct.
I reinstalled the saw on top and loosely fit the anchor bolts.
I threaded the levelling bolts up and down while maintaining some tension on the anchor bots until all was level in both axes.
The straight edge confirmed that I was flush with the worktop.
I carried out a number of cuts, rotating a block and cutting from different faces and testing the fit was straight afterwards. There is still some tuning required on the saw itself but this is an adjustment of the fence rather than the relationship between the blade and the bed.
26 Comments
gregwest77 4 years ago
Left-field Designs 4 years ago
1. My shop has no heating or insulation so the temperature and moisture change through the year does have an effect on my fully timber workbenchs.
2. My benches are made from really crappy low quality shuttering ply as when I built them I was on a small budget.
3. The saw is on an electromechanical lift as I have a serious back problem and cant lift it up and down, this ram was a cheap Chinese unit and isnt always consistent with it's stop position
4. This technique is much easier to fine tune in multiple directions than using fixed shims such as sections of ply
biosonar1 4 years ago
Berquin 4 years ago
This seems to be a very interesting way to do the leveling. However, my English is not perfect and I did not very well understand where and how the adjustable bolts with their nuts are installed (step 3).
Would it be possible to add a picture with those adjustable bolts in place?
Thank you.
Berquin 4 years ago
alanjones 4 years ago
MaC41 4 years ago
IMHO your only reference surface when working a Miter Saw should be the base+fence of the miter saw.Adjusting this to make accurate cuts is vital and there are very good Yutb vids on how to setup your machine.This is step one and is vital.
Once your machine is squared,just rely on it.
Relying on a bench to feed your stock will often give crooked results because long wood stock is most of the time warped.
Horizontal support+stop blocks,movable and clampable to the bench are all you need to work longer lenghts of wood,the saw can sit clamped on top of the bench.
You can unclamp and remove this setup in seconds,freeing the bench for other work.
I learned this from others, i'm no Newton :)
1. Accuracy, where the top was not aligned with the saw and I was getting an off plumb cut
2. Safety, the cut was closing as the piece was not resting on the bed of the saw, as I cut the piece closed on the blade binding and making a dangerous situation
yrralguthrie 4 years ago
Leveling the saw or the table it sets on is not necessary or even a useful objective. Neither needs to be level. They do need to be in alignment with each other. Place a straight edge on the saw as if you were going to cut it. Then adjust the saw (with shims) until the straight edge is supported equally by the two sides of the table and the saw. This will allow very precise and correct cuts. It is quite easy to align the saw to the point where a .001 shim cannot be slid between the board and the table and saw. If the board is only 4 feet long that would give you a 90 degree cut within 4.1 x 10 neg 5.
operabuffo719 4 years ago
naic98 4 years ago
