Moon Station Powered Moon Lamp
Intro: Moon Station Powered Moon Lamp
This instructables show how to add a rechargeable Moon station light source to make a portable Progressive Detail Moon Lamp.
STEP 1: Why Moon Station?
A portable Moon Lamp require a light source; And the light source require a power switch and recharge plug socket.
The switch and socket make the Moon surface not perfect. How about make it look like a Moon station? It can explain why part of the Moon become unnatural :P
STEP 2: 3D Printing
Download and unpack the STL file from thingiverse:
https://www.thingiverse.com/thing:3444020
3D print the model with white filament. I am print it with 0.1 mm layer height, no support required.
STEP 3: Light Source
The interior of the Moon station is 28 mm in diameter and reserved a micro USB port window.
This time, I am using a tiny LED drive board with charging circuit. It originally designed for 18650 LED flashlight, you can use any similar light source in hand.
STEP 4: Soldering Work
Connect power switch, LED drive board, Lipo battery and LED altogether.
STEP 5: Hot Glue Work
Since soldered circuit not in perfect shape, simply use hot glue fix it into the Moon station. I recommend fix the switch first then align the LED drive board to the USB port window.
STEP 6: Install Moon Station
Use a coin screw the Moon station into the Moon.
STEP 7: Charging
The USB port window designed at the side but not the bottom, so that you can screw up the Moon station a little bit and plug the USB power for charging. At the same time, you can treat it as a decent decoration on your desk.
STEP 8: Happy Night!
It's time to show what you have done with friends at night!
11 Comments
mcgurkryan 4 years ago
davide3941 4 years ago
陳亮 4 years ago
StrangeRand 5 years ago
陳亮 5 years ago
I'm not sure that I'll be able to order from this website, but in any case, thank you.
Rperez62 5 years ago
陳亮 5 years ago
MissionCritical 5 years ago
陳亮 5 years ago
SofíaC44 5 years ago
