Motion Sensitive LED Throwies
Intro: Motion Sensitive LED Throwies
Designed to be placed/thrown on moving targets, these throwies utilize a crude motion sensor.
STEP 1: Put the Batteries Together
Instead of using the cr2032 batteries, I use 2 button cell batteries. 1Put the batteries together (- to +) roll the two small batteries up in duct tape and trim the tape from each end.
STEP 2: Cut a Piece of Guitar String
2 Cut a piece of the guitarstring (approx. 4") and roll up one end of the strig with your needle nose pliers. This hopefully will proctect eyes if in the event someone gets jabbed there.
STEP 3: Tape the Other End
3 Tape the other end (unrolled) to the + end of the rolled up batteries.
STEP 4: Roll the = Side of the LED
4 Roll the + side of the LED with the tip of your needle nose pliers.
STEP 5:
5 Place the - end of the LED on the - end of the batteries and tape securely.
STEP 6: Thread the Guitar String Thru the Hole
6. Thread the guitar string thru the hole you the made by rolling up the + side of the LED. The sensitivity of the guitar string can be tweaked by placing a bit of tin foil on the end of the string.
STEP 7: Adjusting Motion Sensitivity
7 Sensitivity can be adjusted by placing a small bit of tin foil on the rolled end of the guitar wire.
24 Comments
Clayton H. 16 years ago
rockyt 16 years ago
akimbo m 16 years ago
dean-101 16 years ago
colin 18 years ago
richelton 16 years ago
Blockman 16 years ago
smidge147 17 years ago
Savage_Insight 16 years ago
locofocos 17 years ago
rockyt 17 years ago
rockyt 17 years ago
finfan7 18 years ago
rockyt 18 years ago
clint eastwood 18 years ago
rockyt 18 years ago
cedel 18 years ago
austin 18 years ago
rockyt 18 years ago
