OLPC Telepresence
Intro: OLPC Telepresence
Updates! This is an ongoing project. I will be updating this instructable, but my blog is updated more frequently.
One Laptop per Child (OLPC) is a new, non-profit association dedicated to research to develop a $100 laptop, a technology that could revolutionize how we educate the world's children.
This instructable shows how to couple an OLPC with an iRobot Create to create a telepresence robot. Using a simple web interface, users can drive the Create, monitor its sensor readings, and explore the world across the internet through the attached OLPC's webcam and microphone.
Materials:
- OLPC
- iRobot Create (includes Create serial cable)
- USB-to-serial adapter
- Stick on velcro or duct tape
- 2 Female/Male Kyosho Battery Connector pairs
- 25 Pin Male Solder Cup DB25 Connector
- Solder
- Electrical tape or heat shrink
- Soldering iron
- Volt meter
- Wire cutters
- Wire strippers
- Hair dryer (if using heat shrink)
STEP 1: Connect the USB-to-serial Adapter and the Create Serial Adapter
Connect the USB-to-serial adapter to the Create's serial adapter.
STEP 2: Optional: Power the OLPC From the Create
This step allows both the OLPC and the Create to charge together.
First, prepare the DB25 connector.
1. Take a female Kyosho connector and strip about 0.25 inches of insulation from the tips of both wires.
2. Twist and tin the strands.
3. Cut two small pieces of heat shrink and slide one on to each wire.
4. Solder the red cable to pin 11 of the DB25 connector.
3. Solder the black cable to pin 25 of the DB25 connector.
4. Slide the heat shrink down to cover the pins and use the hair dryer to shrink it.
Next, prepare the OLPC power connector.
1. Cut the OLPC power cable in half with wire cutters. Be sure you can remember the orientation of the two cables (positive and negative).
2. Strip about 0.25 inches of insulation from both cut ends.
3. Separate the two cables on both ends approximately 1 inch down the cable.
4. To determine which wire is the ground, use a volt meter set to check continuity or measure resistence. Place one probe on the outside of the barrel plug and place the other on one wire. If the meter indicates resistance or continuity, you have selected the ground wire.
5. Strip about 0.25 inches of insulation from a male Kyosho adapter.
6. Cut two short pieces of heat shrink and slide one over each cable of the Kyosho adapter.
7. Solder the black Kyosho adpater wire to the ground wire of the OLPC's barrel plug.
8. Solder the red Kyosho adapter wire to the positive wire of the OLPC's barrel plug.
9. Slide the heat shrink over your solder joints and use the hair dryer to shrink it.
Finally, solder and heat shrink another female Kyosho adapter to the other half of the power adapter.
STEP 3: Attach the OLPC and Cables
The OLPC fits nicely on top of the Create. Use stick on velcro or duct tape to attach the OLPC to the Create so that it won't slide off during operation.
Attach all cables to the create and neatly wrap them up in the cargo bay. Leave a little slack on the ends of the serial, power, and USB cables to feed through the handle of the OLPC. Then stick the OLPC on top of the Create.
Open the OLPC lid and twist it so it's facing forward. You can now plug in the OLPC power cable and the USB-to-serial adapter USB plug.
STEP 4: Install Telepresence Software
The first step is to download and install the required software.
If you'd like to work from the development version, you will have to install the required dependencies yourself.
The picture below is a screenshot of the web interface.
- PyRobot is a Python library for controlling iRobot's Roomba or Create. It was developed for this instructable and includes modules for accessing the OLPC's webcam and microphone and for serving a web interface to control the Create over the internet.
- PySerial
- web.py
- MochiKit
- simplejson
root@olpc$ wget http://pyrobot.googlecode.com/files/pyrobot-alpha1.tgzroot@olpc$ tar zxvf pyrobot-alpha1.tgz
STEP 5: Start the Web Server
To start the webserver, either SSH in to the OLPC or open the developer console. Then run web_ui.py in the pyrobot directory.
'host:port' should be the IP address of the OLPC and the port you would like to run the web server on. Root permissions are required to access the serial port. To view the interface and control the Create, point your web browser to http://host:port.
root@olpc$ cd pyrobotroot@olpc$ python web_ui.py host:port
34 Comments
Timmers 10 years ago
http://www.kickstarter.com/projects/567971283/iroo?ref=live
Jr Hacking kid 16 years ago
paperboy_825 12 years ago
What you do is you buy one for $100 and a school or child that can not afford one will receive a laptop and you will receive one as well
Thundermoon99 11 years ago
ghostis 16 years ago
wolf555hound 15 years ago
Ora 16 years ago
Ora 16 years ago
rrrmanion 15 years ago
damonkohler 16 years ago
Fenwick 16 years ago
cotton 15 years ago
AzurusNova 16 years ago
Xellers 16 years ago
MindTorm 16 years ago
im3733 16 years ago
omnibot 16 years ago
