Objet 3D Printer Fit Tests
Intro: Objet 3D Printer Fit Tests
It is often desirable to achieve a very specific fit between a mortise and tenon (or similar situation). This instructable describes a set of gauges that make it easy to determine the dimensions needed to achieve the desired fit when using an Objet 3D printer at Pier 9. It also includes the AutoDesk Fusion 360 files and .stl files used to generate these gauges, so that those with access to other 3D printers can make their own gauges.
The gauges are stored in a drawer in the 3D Print Shop at Pier 9. If you can't find them, just ask Gabe.
STEP 1: Description of the Gauges
There are three sets of gauges, one for each of the printing options: HS, HQ, and Auto. Each set of gauges consists of four pieces: three mortise pieces and one tenon bar. Each of the four pieces has either "HS", "HQ" or "Auto" debossed on the surface to indicate which print setting was used. Each of the four pieces also has an arrow "^" debossed on the surface indicating the positive Z-direction when printed.
Mortise Pieces: One of the mortise pieces has two mortises, the other two have one mortise each. All the mortises have nominally the same dimensions of .250" x .500". Together they represent mortises that were printed facing four different directions: +X, +Y, +Z, and -Z.
Tenon Bar: The tenon bar was printed with the inserts facing up (+Z-direction). It contains ten tenons dimensioned in graduated steps of .002" from .250" x .500" to .230" x .420". The dimensional information is debossed on the tenon bar.
STEP 2: Using the Gauges
To determine the dimensions required for the desired fit, select the appropriate mortise-&-tenon pair and insert the mortise piece onto the various tenons until the desire fit is achieved. The difference in the dimensions between the mortise piece and the tenon piece is the difference you should apply to achieve the same fit for your mortise-&-tenon situation, regardless of scale.
STEP 3: Notes:
If you use calipers to measure the actual dimensions of the mortises and tenons you will find that in some cases the dimensions vary considerably from the nominal dimensions, and the variances are different in different axes.
STEP 4: Files
The image above shows what the fit test file models look like, and the orientation in which they were printed (+X axis direction is from bottom-left to upper-right, +Z is from bottom to top). Below are the fit test files. I have included both the original Autodesk Fusion 360 files (.f3d), and the .stl files. Fusion 360 is available as a free trial from AutoDesk.
Note that all of these files were printed with the tenons facing up (+Z). If you want to make fits test facing in a different direction, just rotate them before printing, but be sure to first change the location/orientation of the arrow "^" deboss to avoid confusion.
16 Comments
Basp 6 years ago
gin_ger 7 years ago
If you're the 95% of the earth's population that uses metric then I've made a metric set
http://www.thingiverse.com/thing:2251031
pmandryk 6 years ago
Doing God's work here, gin_ger. We'll convert those heathen Imperialists yet.
pillaleitner 7 years ago
Nice design! I will probably be printing yours soon.
maljg 7 years ago
Sorry I might be missing something here but on the 'Tenon Bar' description it says there are Ten Tenons but the model shows Eleven? Also, .230 to .250 in increments of .002 is ten increments therefore 11 tenons but .420 to .500 in .002 increments is way, way more than ten increments.
edmark 7 years ago
I'm afraid it's been too long since I produced this instructable or
worked with those machines to remember anything about it. You're
probably right about whatever conflicts you're finding (thought it's
surprising that nobody has mentioned it until now). Sorry, and good luck.
crazy_thiago 7 years ago
it dosent open on my 360
JON-A-TRON 7 years ago
You have to Upload it- you can't open local files directly in Fusion because everything is on the cloud.
claudiof2 7 years ago
"..i cant find"
*)Finally, i have open the file in my Fusion.
I have download the file,--the first--
after that "insert : file stl"........
and the file open in Fusion.
**) thanks your answer /
in the beginning message problem with " local files"( ?).
***)But i can fin the dimensions clear from the piece 3D.
mrehan.elshehawy 7 years ago
what do HS,HQ and auto stand for ?
edmark 7 years ago
edmark 7 years ago
If you're finding the holes too small or the pegs too large, that would suggest that your printer is printing too much material.
SteveS162 7 years ago
Three hours of printing and its no good. Holes either too small or the Pegs are too big. Nice idea though
Jack Moran 9 years ago
Great idea!
MsSweetSatisfaction 9 years ago
Very useful and nice design! Thanks for sharing!
