Op Amps Without Circuit Boards
Intro: Op Amps Without Circuit Boards
This is another example of fabricating circuits without circuit boards or breadboards, using direct solder and wires and tweezers in 3 dimensions. I'm using the MCP6241 op amp here, and making one amp of voltage gain 10,000 and one of voltage gain 100. I use a combination of surface mount and axial resistors, and I don't specify which one you use when. Also, the instructions here are assuming you already know and care about op amps, I'll have another more basic one for beginners later. I show schematics I'm going off of directly as I go. Again, I advocate in most cases, keeping that schematic with the physical thing for future users to be able to understand. That schematic should also contain a URL back to your or my or someone else's documentation.
STEP 1: Cut Off Unwanted Leads
pins 1,5 and 8. Cut them off with clippers! Smash!
STEP 2: Add Feedback Resistor
I use a 1 M Ohm 0603 SMT resistor for this every time because I bought a ton of those a long time ago and have an effectively infinite number and that gives me a ton of choice for gain based on the input resistor.
STEP 3: Add Input Resistor and Other Bias Resistors
As shown. That's it. If you're making a simple circuit with a simple op amp, you should never need either a breadboard or PCB. Just grab, solder and go.
7 Comments
steven4872 7 years ago
Another approach to building a circuit is to use a breadboard:
https://learn.sparkfun.com/tutorials/how-to-use-a-...
With breadboards you don't have to damage the chip or cut the pins. Everything just plugs in without solder. And if needed you can reconfigure the circuit in a few minutes. Also when you are done all parts can be reused in your next project.
lafelabs 7 years ago
rafununu 7 years ago
We called this "spiders" when I started electronics decades ago.
JunezRiyaz 7 years ago
Nice idea, but reuse of IC may difficult.
DIY Hacks and How Tos 7 years ago
Free form circuits are a lot of fun to make. What's really cool is that if you have multiple of the same IC, you can stack them on top of each other and share the same power terminals (and any other shared terminals).
