PVC Stage Backdrop or Room Divider
Intro: PVC Stage Backdrop or Room Divider
our elementary school doesn't have a stage. 5th grade graduation usually meant decorating the back wall of the gym. i had to take this down last year, it involved a 10 ft ladder! since i don't get hazzard pay, i had to come up with something else.
i searched the internet to no avail... so one brain fart later this was born!
we got the stuff to decorate it from the prom catalog. the music teacher is happy because she can use the frame for her plays and such. you can use the whole 40' long frame or only a couple of sections. the fittings are permanately attached to the vertical pipe pieces with screws. it all breaks down easily and stores in a closet in the basement.
the main section is 8' high and 40' long, each section is 8' x 8'. the cross pieces that hold it up are 2' on either side (4' total). the photo op for the parents is a seperate 10' x 10' section with the same cross piece dementions. the whole thing cost us under $200, for the frame. the decos were a bit more, but we can reuse the star backdrop plastic for a couple of years. the 2007 columns we'll have to replace of course. we spent maybe $500. i probably could have gotten the pipe cheaper at one of the big home stores, but we've got a lumber yard catty corner to the school and it was easier to pick up the pipe this way. the 5 way and 4 way special fittings i got at http://www.hartnagels.com/pvc.htm . it's made with 1 1/2" pipe.
STEP 1: End Bottom
this is the special 4 way piece.
STEP 2: Center Section Pieces
this is the special 5 way pieces for the middle sections.
STEP 3: Side View
here's a side view of the finished product.
STEP 4: Front View
here's a front view with the 5th graders practicing for graduation that evening. it took us about 8 hours total to put everything together for this. the pvc went up quick, it was the rest of the stuff that took time! those 2007 columns and the silver ones in the photo op aren't easy! we had no more than 6 people at any one time working on this. the next morning, i came to work early (i'm the library assistant and pta president) and it took me 45 minutes to have it cleaned up. one of the teachers helped me set the pvc frame down so i could take it apart. some kids from the latchkey program helped clean up the balloons and put all the chairs back in the classrooms they came from.
there's the back wall of the gym that used to get decorated, you can kind of see where the stage used to be before they walled it in sometime in the 70's to make a music classroom behind it. the school was built in 1937 by the WPA.
38 Comments
chakayiab 5 years ago
EricS188 6 years ago
I'm one of the senior class sponsors at my school, and we're planning a PVC backdrop for our graduation this year. The concern we have is the drapery covering the support posts. How did you get it to cover the PVC pipe so completely?
dkrmwiz 6 years ago
we used the plastic sheeting you get from the prom supply catalog, it's big enough to cover anything and pretty cheap.
cewinfield 6 years ago
I made this identical backdrop for about 80 dollars. I purchased all my material from Home Depot. It turned out great
dkrmwiz 6 years ago
reggiej 9 years ago
I have an 8X8 banner which I build a stand for using pcv. I was planning on using it at our family reunion so peoplecan stand in front of and take pictures. The pieces 3/4 inch pcv but the problem that I am running into is stablity. I tried sticking 1/2 inch pcv inside of 3/4 inch but there is just too much sway. I am afraid the whole thing is going to come toppling down. Does anyone have any suggestions to make this more stable.
FunE2 8 years ago
I built and 8 x 8 ft. backdrop using 3/4 Schedule 40 pvc and only standard "T" and 90 degree elbows. Legs were assembled using 2 pieces about 15 inches each glued into the straight ends of the "T" fitting. A roughly 30" piece of 1/2 inch thin-wall conduit was inserted through the legs and the "T" and the ends were capped.(You will need 2 of these). This was all glued together. An short upright was added and topped with another "T" and a cross brace linked the two leg sections. Another upright was added to each side and at the top an elbow was added. A cross bar was added at the top to complete. Because the legs were weighted with the conduit, I never experienced any instability. I do not have pictures as I got rid of it a while back, but I can send a drawing if you like.
dkrmwiz 9 years ago
dkrmwiz 9 years ago
manmohanpipe 10 years ago
Very well said.
These tips are really amazing. I appreciate it for sharing them
<a href="http://www.pisces-aqua.co.uk/pipe/">Plastic Pipe Fitting</a>
templets 16 years ago
your realtor 16 years ago
JimTheSoundman 10 years ago
Jaino 16 years ago
dkrmwiz 16 years ago
http://www.littlegreenhouse.com/accessory/pvc.shtml
they are pretty quick on turn around.
cmjmed1 12 years ago
Cush 14 years ago
catherinem1 12 years ago
