Paper Marbling With Food Dye and Shaving Cream
Intro: Paper Marbling With Food Dye and Shaving Cream
A quick and easy way to marble paper!
STEP 1:
STEP 2:
~ Supplies ~
~ Ruler
~ Food Dye
~ Shaving Cream (make sure it is foam)
~ Painters Tape
~ Envelopes/ Paper
~ Plates
~ Tooth Picks or Spatula
~ Tray
STEP 3:
Start by taping off any areas of the paper you do not want to be marbled. Since I started by marbling the flap of the envelope, I also used a different piece of paper to help cover up the area I wasn't marbling.
STEP 4:
Cover the tray in a layer of shaving cream. Then, add a few drops of food dye onto the shaving cream. Next, take the spatula or the tooth pick and mix the food dye with the shaving cream. I use the tooth pick when I want to create more of a pattern. Using the spatula will create more of the marbled look.
STEP 5:
Next, press the paper on top of the shaving cream. Then, pull up the paper and take the rule and scrape the shaving cream off. Let dry before using.
6 Comments
Slippery arm 7 years ago
nanaverm 8 years ago
Wow! I didn't know you could use regular paper & food dye for this! Thanks!
It's spectacular on glossy or photo paper.
craft within reach 8 years ago
Thank you! I'll have to try it on the glossy paper! I've also seen where people use the same technique on fabric.
kandiceaz 8 years ago
I just have to try this for our next charity card event. thanks so much for sharing.
rflowers2 8 years ago
Tait_Clements 8 years ago
