Paracord Self Defense/Survival With Duct Tape
Intro: Paracord Self Defense/Survival With Duct Tape
STEP 1: Create the Monkeys Fist
I used a jig which makes it way easier. First you put your core in the jig. Then wrap around 8 times on each side and tighten.
STEP 2: Duct Tape Role
First get a pen tube. Wrap duct tape around until you get the desired amount. Cut off excess pen tube. Feed the two strands through the tube.
STEP 3: Braid
For this step i used the four strand round braid. But you can use many other knots. Just choose one you would like the best. Keep repeating the knot until you get the length you want.
STEP 4: Handle
For the handle you also can use pretty much any knot. I used the crown knot.
STEP 5: Key Ring
I used a crown knot again to secure the key ring to the handle. Then cut of the excess paracord and melt it.
STEP 6: Final Product
This is what you should have after it all is done.
15 Comments
Making Everything Modern 7 years ago
what size is this paracord?
Making Everything Modern 5 years ago
huh i've been here before....
Jobar007 8 years ago
Flails have some serious drawbacks: they are slow to respond and can be easily defeated by a skilled opponent. Most of the time they aren't in a position to strike. As a result, you get lag between when you should strike and when you can strike. By intercepting the line, the flail becomes a weapon against the wielder and it loses it's momentum.
That said, they do have a good amount of force behind them when they hit due to the lever and momentum.
Flails were designed to attack opponents by bypassing their shield. They excel in 1:1 tournament style melee where opponents tend to use a shield. In modern times, they aren't very practical for self defense.
Good use of a monkey's foot knot and a great way of explaining how to make one fast. The tightening part can be really tedious though.
jonathon.mcmahan 7 years ago
Jobar007 7 years ago
The paracord would have to be wound really tight or it would become a liability on a handgun grip. ;)
I'm sure it would be a good self defence weapon, if you practiced with it religiously. No weapon is good unless you are proficient and practice often. Every weapon has advantages and disadvantages. I was just pointing out what flails were originally designed for and are good at along with their shortcomings. Everything has a trade off and being aware of disadvantages help to mitigate their shortcomings.
Pee-Ka-BooG 8 years ago
cool
jmateos 8 years ago
tgm700 8 years ago
fmallari 8 years ago
FletchINKy 8 years ago
Review local laws for blackjacks and saps.
1mountain1 8 years ago
Battlespeed 8 years ago
Or, a tube sock and a rock - the rock to be conveniently tossed when the skull-bashing has been successfully accomplished.
juanfitness 8 years ago
Thanks, great idea !! :)
mrobinson43 8 years ago
RamblinLane 8 years ago
What are the lengths of the various sections?
