Parkside X20V Battery Powerbank USB Charger
Intro: Parkside X20V Battery Powerbank USB Charger
This is a simple DIY power bank project which combines a cheap quick charge charging module with a Parkside 20V battery.
The module I used is here (2 ports, affiliate link):
The module is great and the quick charge is working like a charm on Samsung Galaxy 9 and 10.
I designed it using the fantastic Autodesk Tinkercad free online 3D modeling tool and I encourage you to try it by yourself, especially if you are a beginner. If you are looking for a more powerful 3D modeling tool, take a look at the Autodesk Fusion 360.
STEP 1: 3D Printing
Print your files from Thingiverse (top, middle, and bottom part):
https://www.thingiverse.com/thing:4629874
When you finished printing, remove supports. There will be a little struggle with supports where the front corners of the board go, as they are just 2 mm high.
I used draft/rough settings, with support. The thing is divided into two big pieces (middle and bottom) in order to save filament - to prevent unnecessary support.
STEP 2: Assembly
- Holes in printed parts are a little bit tight, you can (pre)screw the screws (screw-unscrew), it will be easier later
- Put wire terminals and place them in place, using hot glue.
- Solder another side of the wire to the charger board. Be careful with +- and before soldering put the module in the printed housing
- Screw the screws :)
STEP 3: Test
To confirm that this thing is working, I took a few measurements. I used the simple Android app Ampere and compared 3 kinds of charging - using this charger, original Samsung wall charger, and PC USB port. Every time, I used the same USB cable (Samsung OOTB).
Also, I was able to fully charge my phone (0-100%) 2 times. To be honest, there is a little bit more juice in the Parkside battery, but I didn't want to push it.
If you're interested to take a look at the Parkside battery, here is a nice video. We can see that there are five 18650 cells inside.
STEP 4: The End
If you decide to make this thing, please share your work :)
STEP 5: Original Parkside USB Charger and Battery
If you are looking for the original products, you can find them here:
4 Comments
Beneficial Wizard 3 years ago
powerusertutorials 3 years ago
Great idea to add LED to it. That's on my todo list, as I had few situations where this kind of reflector/torch would be helpful. I have few 94x50MM 15W COB LED chips in drawer waiting me to make use of them. If you want, I can let you know if/when I make something useable of it. And if you make it, please let me know.
randofo 3 years ago
