Passive Amplifier
Intro: Passive Amplifier
Simple and easy to do using an empty ambient deodorant,increases the sound more than 20 decibels without battery nor wires
STEP 1: Materials and Tools to Make It
A deodorant tin can can,not the aluminum one,and to cover it some kind of adhesive sheet,like this ( carbon fiber),or simply paint it
STEP 2: Preparing the Can
Take off the upper part part of the can,with the help of a plier or screwdriver
STEP 3: Getting the Components of the Amplifier
With a handsaw or a angle grinder Cut both sides of the can,the upper one will be the base and the lower one will be a sound reflector
STEP 4: Prepparing the Components
Bend a little bit the bottom side,in order to let us introduce in the can,and with the help of a hammer bend the upper side as seen on picture,this will make a better seat of the can on the base
Also we have to mark a rectangule according to the size of our cell to let us put it in,make the little window some mm bigger so the cell enters freely
STEP 5: Finishing the Job
And after soldering the base and the sound reflector in the inside,I covered It with fiber carbon sheet ,It is a really efficient amplifier,It amplifies enought the sound of the cell
2 Comments
YourMagesty 7 years ago
(late getting to view this). I could use this! I am probably going to attempt making one for myself. Thanks for the idea! One question: Does the reflector have to be soldered together with the can? If I just sit the two pieces together, will the amplification still be present? Thanks for your reply.
Ugofirst 7 years ago
I found that this reflector amplifies better being closer to the speaker.
Hope this is useful for you BR
