Pencil Perfect Ring
Intro: Pencil Perfect Ring
Personalize your wardrobe with a handmade ring. Use lots of color for summer or create a more toned down look for fall. Design it yourself and do it your way with the following steps and tips.
For some fantastic inspiration for your own variations, check out Maria Cristina Bellucci. (Thanks for the link meatchris!)
STEP 1: Collect Supplies
Supply List:
hexagonal colored pencils (You can use other shapes, but you risk having gaps between your pencils which may lead to a weaker structure)
super glue or epoxy (I used E6000. It was a big mistake. You need a glue that dries clear and HARD. E6000 dries rubbery. When I had to re-glue pieces, super glue worked fine.)
jewelers saw or hack saw blade (I used these interchangeably. If you don't have a jewelers saw, you will need a very large drill bit or require a lot of extra sanding.)
masking tape
dril
drill bit (with a jewelers saw, you can use a small bit. With no jewelers saw, you need a bit as close to your finger size as possible.)
mod podge
sand paper
scrap wood
dowel/knitting needle/round pencil
masking tape
dril
mod podge
sand paper
scrap wood
STEP 2: Arrange and Glue
*Decide what shape you want your pencils to take. I decided to do a rectangular shape and arranged my pencils in three rows.
*Once you've decided, tape each row on one side to aid you in gluing them together. I only applied glue to about a third of the pencil so that I could use the rest for another project.)
*Once they are taped, add glue to the appropriate sides. When each row is dry, glue the rows together.
*Once everything is glued, tape the entire bundle at both ends
Tip: Be sure that you pay attention to the entire length of the pencil. It needs to be straight from one end to the other.
Tip: Even if you choose not to glue the entire length of the pencil, don't cut the rest off until you absolutely have to. The extra length will help you grip and control your project.
STEP 3: Cut a Hole
Time to make the hole for your finger.
If you have a jewelers saw:
I used a large bit to drill a hole and then used the jewelers saw to make the hole bigger.
Alternative:
*Use a small bit to drill a hole that your saw blade will fit into.
*Make a template with an existing ring. Trace it onto your pencils as a cutting guide.
*Cut your hole
No jewelers saw:
Use a drill bit that is as close to the size of your finger and drill a hole in your bundle.
Alternative:
*Cut your hole
No jewelers saw:
STEP 4: Sanding and Shaping
This step is about getting the top looking the way you want it. I sanded until I had stripes of color on each side and then cut the top at an angle.
Various sanding methods
*tape sandpaper to board and rub pencils against it
*tape sandpaper to small scrap wood and rub it against the pencils like a nail file
*wrap sandpaper around something round
At this point, you can also cut shapes out of it with your saw or drill more holes. Make it yours!
STEP 5: Bottoms Up
Make sure you have the top the way you want it. Put some making tape around the top so that your hands don't get it dirty while you cut the bottom.
I made three cuts. One straight and then two diagonals.
This is a tricky step. You have to pay attention to all angles when cutting the diagonals. I suggest starting your cut looking down on the top of the ring. Then turn the ring on each side and begin cutting a diagonal that is parallell to the hole. Cut a bit and rotate, cut and rotate, cut and rotate, until you've cut through.
Once you've made all three cuts, keep sanding until it's smooth.
STEP 6: Shiny!
Once it's sanded to your satisfaction, add mod podge and impress your friends.
41 Comments
Joetta_Jett 9 years ago
Brooklyntonia 9 years ago
Look for Faber Castell pencils. You could order them off Amazon if need be. So glad you're giving it a shot!
daner girl 16 9 years ago
michaelgc 9 years ago
Great looking ring, My wife would love one of these. I think that you should find some kind of good cause, and put some people to work making these. I am sure you could get a whole bunch of pencils donated.
jasonw6565 10 years ago
explosivemaker 10 years ago
And yeah, e-6000 does not dry hard.
But a very cool idea.
mygibzone 10 years ago
Derek Scott Customs 10 years ago
Brooklyntonia 10 years ago
bartworker 10 years ago
DeeRilee 10 years ago
But I don't want to sacrifice my CPs! =(
I'll have to keep an eye open for sales on CPs, the higher end ones have such greater pigment load, but the gloss finish may compensate.
Great idea, I love it!
amonj02 10 years ago
