Phaser Guitar Pedal
Intro: Phaser Guitar Pedal
A phaser guitar pedal is a guitar effect that splits a signal, send one path through the circuit cleanly and shifts the phase of the second. The two signals are then mixed back together and when out of phase, cancel each other out. This creates a sound somewhat akin to a flanger or an auto-wah.
This effect pedal first hit the scene very hard in the 1970s and added a special brand of outerspaciness to a pretty funky decade. Looking to revive this original vintage sound, I have built a classic 4-stage phaser. This particular pedal is pretty basic and allows you to adjust depth and the rate of the phasing. While the controls are rather bare, you can still dial it in to produce a subtle fullness to the guitar, or crank the dials all the way up for full-on slippery sounding funk.
STEP 1: Materials
(x5) LM741
(x4) 2N5457 FET
(x3) 2N3904 transistor
(x1) 100K trim potentiometer
(x1) General purpose PCB
(x1) DPDT pushbutton
(x2) Aluminum knobs
(x2) 50K potentiometers
(x2) 510K resistors *
(x1) 390K resistor
(x2) 150K resistors *
(x11) 100K resistors *
(x1) 47K resistors *
(x1) 43K resistor
(x4) 22K resistors *
(x2) 10K resistors *
(x1) 5.1K resistor *
(x2) 2.2K resistors *
(x1) 220uF capacitor **
(x1) 22uF capacitor **
(x1) 10uF capacitor **
(x1) 0.33uF capacitor
(x3) 0.15uF capacitors
(x1) 0.022uF capacitor ***
(x4) 0.01uF capacitors ***
(x1) 0.001uF capacitor ***
(x1) 7.5V Zener Diode
(x2) Stereo audio jacks
(x1) 9V battery snap
(x1) 9V battery
(x1) BB-sized enclosure
* Carbon film resistor kit. Only kit necessary for all labeled parts.
** Electrolytic capacitor kit. Only one kit necessary for all labeled parts
*** Ceramic capacitor kit. Only one kit necessary for all labeled parts.
Please note that some of the links on this page contain Amazon affiliate links. This does not change the price of any of the items for sale. However, I earn a small commission if you click on any of those links and buy anything. I reinvest this money into materials and tools for future projects. If you would like an alternate suggestion for a supplier of any of the parts, please let me know.
STEP 2: Phaser Schematic
Build the circuit as specified in the schematic. Do not worry about the potentiometers, audio jacks, or toggle switch for the time being. These will be installed later.
Keep in mind that you are squeezing a lot of components into a small space, so lay the parts out and plan carefully before you begin soldering.
About the Circuit
While this may seem like a very large mess of analog electronics, the circuit is somewhat simple.
The guitar signal first enters through a preamp stage. It is then split such that the clean signal goes straight to the output jack and the signal to be phase shifted goes to a series of 4 LM741 op-amps that form an all-pass filter. This filter is essentially what shifts the phase based on the signal from the LFO (low frequency oscillator).
The LFO is comprised of the 5th LM741 op-amp in the circuit (and surrounding circuitry). The rate of the LFO is controlled by a 50K potentiometer. The LFO then provides a CV (control voltage) to the all-pass filter by way of the 2N5457 FETs. This modulation then causes the signal in the filter to shift phase at the rate of the LFO.
The audio signal from the all-pass filter then goes to the foot switch. If the switch is open, only the clean signal makes it to the output jack. If the switch is closed the phase shifted signal is allowed to pass through to the output and get mixed with the clean signal. However, before the altered signal gets mixed in with the clean signal it passes through a 50K potentiometer which determines how much of the signals get mixed together.
From there, it goes out to the amp and the rest is history.
STEP 3: Attach Wire
Attach 6" wires for the two potentiometer connections to the circuit board.
Also, connect 6" wires to the circuit board for the audio jacks.
Finally, connect the red power wire from the power jack to the appropriate place on the circuit board.
STEP 4: Guitar Pedal Template
Print out and afix the attached template to the the outside of the guitar pedal closure in preperation for drilling.
STEP 5: Drill
Drill 9/32" holes for each of the potentiometers.
Drill a 1/2" hole to house the foto switch.
Drill a 3/8" hole for each audio jack.
STEP 6: Insulate the Case
Cut out a 1/8" sheet of cork using the attached template.
Apply spray adhesive to one side of the cork and stick it to the inside of the enclosure's lid.
STEP 7: Rubber
Cut a rubber spacer out of 1/8" thick adhesive rubber sheeting using the attached template.
Attach the rubber spacer to the inside of the enclosure where the potentiometer mounting holes are.
STEP 8: Install
Mount the potentiometers and foot switch in their respective mounting holes.
STEP 9: Wire It Up
Wire the circuit board to the audio jacks, potentiometers, foot switch and the 9V battery snap as defined in the schematic.
STEP 10: Audio
Mount the audio jacks into the body of the case.
STEP 11: Power
Connect the battery to the 9V battery snap.
STEP 12: Close the Case
Close the enclosure using the appropriate hardware.
STEP 13: Knobs
Press the knobs onto the potentiometer shaft.
STEP 14: Plug and Play
Plug the guitar into the audio-in jack and the amp into the audio out jack.
You should now be ready to rock out.
Did you find this useful, fun, or entertaining?
Follow @madeineuphoria to see my latest projects.
69 Comments
TheDeadRat 1 year ago
merely a minor gripe, and a personal one. just not sure we know what we are supposed to do with the trimpot. i cant be the only one. anyway thanks for these, brother! i truly appreciate these
johnrottingliver 1 year ago
txdm 1 year ago
TDHofstetter 1 year ago
"The LFO is COMPOSED of the 5th LM741 op-amp in the circuit (and surrounding circuitry)"
or (preferred):
"The 5th LM741 op-amp in the circuit (and surrounding circuitry) comprise the LFO"
The parts comprise the whole, which is composed of the parts.
BTW... tToo bad you didn't include an actual schematic. That would have been nice.
ccncs517 4 years ago
TheDeadRat 2 years ago
those are the voltages (approximately) that should appear on those nets/links/nodes/junctions/etc. that theyre on in the schematic.
i.e.)) the cyan link is about 7V, and the purple one is about 4V. theyre listed in an attempt to help you troubleshoot or check your circuit against the original's voltages.
DavidP820 3 years ago
would’ve uploaded an image but it looks, well, bad... I don’t think anyone but me would understand what’s going on there :)
randofo 3 years ago
(In full disclosure, I don't know the PWM rate of the circuit off the top of my head, so it might just appear that the LED is always on. That said, I would think you should be able to see some sort of change as you adjust the potentiometer.)
Also, make sure the output jack is grounded with a wire. I didn't draw in a ground wire because in my circuit the jack gets grounded through the metal case.
AGUS2508 4 years ago
All the voltages are correct and when testing it i can hear a rise in volume when turning the top pot but the lfo pot does nothing.
I apologise for the mess in advance.
randofo 4 years ago
randofo 4 years ago
sumeyraduraak 5 years ago
randofo 5 years ago
I'm afraid I don't really have enough information here to debug your circuit.
JunmarF1 5 years ago
randofo 5 years ago
I didn't and I was pleased with the results, and couldn't hear anything wrong with the effect. However, I suppose you would get a more pure signal if you did.
green3ggsandhams 6 years ago
randofo 6 years ago
If you view the 'clean' signal at the same time as the phase shifted signal, they should be the same signal, but the phase shifted one should be moving in and out of phase (at the rate determined by the LFO).
One potentiometer controls the LFO
The other potentiometer mixes the two signals together before being output to the amp.
randofo 6 years ago
Honestly, I have never looked at the output wave. What you are describing sounds feasibly 'about right' (I think).
The pot is basically mixing the two signals together into one signal. That wave is going to be some combination of the two.
Being that it is sort of summing the two waves, I would think its probably correct that the amplitude increases.
