Planter From Pallets, No Nail Pull Method
Intro: Planter From Pallets, No Nail Pull Method
A while back I had decided to build some vegetable planters out of old pallets. I mean, hey, free wood, right? I had originally decided to deconstruct the pallet by yanking out all the nails and reusing the lumber. However, to my annoyance, I discovered the nails were darn near impossible to pull. Every single time you ended up cracking the board you were trying to remove, reducing it to useless splinters.
After a few cracked boards I paused to curse and kick at the pallet, and then sat down and decided to puzzle out a different way of doing it without having to pull out each nail. And here is how it is done:
STEP 1: Cut Slats Off the Support Board
First just cut the slats off with a jigsaw. Just cut them off from each side of the support beam. You'll end up with a nice pile of slats.
STEP 2:
Once the pallet is all cut up, you end up with a couple of support beams with pices of wood still nailed to it.
STEP 3: Trim the Nails
Now, you can pull those nails off, or do it the easy way and run it over the table saw. The blade easily cuts through the nails, and you can trim off any uneveness of the wood while you are at it. Be sure to wear eye protection.
STEP 4: Cleaned Boards
In short time you have a pile of nice clean boards.
You need all the support pieces from both pallets. Six in this case. No pallet ever seems to be made the same, so if your pieces are not the same length, trim them down to match. In my case I had a pallet about half a foot longer than the other one.
STEP 5: Measure and Trim Boards
Boards all trimmed to live up evenly.
STEP 6: Cut End Pieces
You want four long ones and four short ones, or half the size of the long ones. Actual length will vary with pallet, so just scale the smaller pieces down by a half.
STEP 7: Add End Slats
Find two slats of roughly the same size, and nail or screw them down on either end of the support wood. You do this first so you do not have a box that is two feet high on one end and then goes up crookedly a half a foot in the other.
STEP 8: Add All Slats
Just go right down the line and add the slats to the support wood. I personally used screws along with a squirt of wood glue. The wood glue helps because these cheap pallet boards love to crack, so if it does crack the glue will help old it in places.
STEP 9: Add Slats to End Pieces
Fill the slats on both the side and end pieces.
STEP 10:
Now just assemble the four peaces together. I just used long screws and some wood glue.
Ta-Da, a sturdy planter.
I do not have a bottom on mine, because I am filling it up with good dirt and letting the roots of the plants just work their way down. You can put a bottom on it easily enough, however.
This way is a lot easier than trying to get those impossible nails out of the pallets.
44 Comments
MitchW16 6 years ago
Carpenter Guy 7 years ago
nice idea! When I pried out my nails from the pallet, I pry the board up a bit, then hammered it down. This leaves you enough room to get the hammer under the nail head.
arobinson17 11 years ago
http://mandamakesblog.wordpress.com/2012/05/16/topsy-turvy-garden-week-3/
I think it is going to work out nicely!
cart562 11 years ago
tgersh 12 years ago
CementTruck 12 years ago
Master Beorn 12 years ago
fegundez1 12 years ago
woodreaux 14 years ago
There is a tool available(or make your own) for pulling the boards apart, they can then have the nails tapped a bit and pulled out with a conventional crowbar. The tool looks like a two pronged fork with about a 4 foot handle. The tines of the fork are bent so the 2x4s can be straddled perpendicular to the slats and the slats lifted by prying down on the handle. Maybe northern tool (dot com) has them if you want to look. I love re-purpose-ing stuff!
moosetooth 13 years ago
pfiddle 14 years ago
static 14 years ago
DIY-Guy 14 years ago
I've had good results wtih cutting the nails flush with a flexible metal cutting blade in my demolition saw (also called a Sawz-all in some places). For people in the united states, these can be found on sale for $19.99 instead of the usual $40 or $60 USD at Harbor Freight Tools. The motors eventually burn out, but so do the motors on the $160 "professional" brands! For throw away tools once they're worn out, I prefer http://www.harborfreightusa.com very cheap tools from China. But I'd never buy a cheapo table saw! A well built table saw (mine's made in USA) will last for decades with simple maintenance.
DdraigGoch 14 years ago
hickarus 14 years ago
pdub77 14 years ago
Spokehedz 14 years ago
Mikey D 14 years ago
carpespasm 14 years ago
