Plastic Perfection
Intro: Plastic Perfection
Hey guys, I have another post! I am much more pleased with this then my last gun, hence the title.
What makes this really sweet is how accurate at close range it is. I always thought that having a fairly lengthy and tight barrel on a K'nex gun would reduce range and increase accuracy very little. I was wrong! Within indoor ranges, this gun is a real beast. I was able to hit a pop can consistently from across my room, and the gun still shoots 45-50 feet with one #117 band. The ammo is grey connectors, and I chose those so that they would turn end over end when shot, instead of flopping in a random detection.
Also, there is only one rod sticking out of the gun! The magazine is not removable, but it holds maybe 10 shots.
There is lots of nasty in the stock, and I ain't too pleased with it. But is sturdy enough, and the handle isn't too bad.
The trigger is simple, and not too heavy. I even threw on a rail for mounting Nerf stuff and anything that attaches to a weaver rail. Also, there is a rail under the barrel for a bipod or forgrip. This gun would be a decent indoor war gun for picking people off as long as you have a sidearm with removable magazines.
SPECS:
Shoots 50 feet.
Works smoothly.
Flat design.
Rails.
Stock is decent.
Accurate. Very.
Non removable magazine.
As you can tell I am pleased with this gun! Tell me what you think in the comments below and consider subscribing if you haven't already.
~~CorgiCritter
44 Comments
Dreamwave 7 years ago
What's the nasty you speak of in the stock? Honestly, your builds are so clean over all that something in the wrong place would stick out like a sore thumb...but I'm not seeing anything amiss. Great job!
CorgiCritter 7 years ago
It was because of it being flimsy and some of the pieces in the stock didn't fit together well.
The Knex Inventor 7 years ago
Awesome gun! As I said before somewhere else, I love the idea of combining two elements into one gun; in this case, K'NEX and Nerf. Favorited. :-)
That_Jamie_S_Guy 8 years ago
CorgiCritter 8 years ago
I always have a design or look in mind when I start building, but that changes as I build.
As for the look, that's just my building style. I try to avoid lots of cut parts so the square look comes from that.
The stock is kinda bad I admit.
I'm glad you sorta like the gun though!
Thanks!
Knextremely stupid 8 years ago
I like the gun a lot but the stock could look better and the gun could have maybe 7 layers
Thanks, I may end up posting it later with some improvements. I'll keep 7 layers in mind, and I'll try and renforce the stock.
Lucas The Boss 8 years ago
I first noticed the rail on some of Red's guns. It reduces comfort but looks cool. On this gun it's needed since only two rods are holding the stock onto the body, and so I needed an extra connection point.
I think my failure rate is even higher then that. If a project is showing no signs of success after an hour or so... goodbye to that!
the knex gun boy 8 years ago
