Pocket Sized: Key Ring Crocodile Bottle Opener
Intro: Pocket Sized: Key Ring Crocodile Bottle Opener
It might be an Alligator, not a Crocodile.... you can decide what yours will be. ;-)
Need a bottle opener, that's also stylish, and fits in your pocket along with your keys, make this!
If you like this, please vote above. danke! =)
STEP 1: Tools & Material
What you'll need:
Tools:
Hacksaw (metal saw)
File
Drill +drill bit
(Optional) Etching tool
Material
Some metal, I used some scrap steel 4-5mm thick
Tools:
Hacksaw (metal saw)
File
Drill +drill bit
Material
STEP 2: Get Your Pattern...
This was what I used as a template. If you want to use it, just click the "i" in the top left corner, and download the largest version.
btw, the original idea was to make a Gecko key fob... it didn't turn out quite how I expected, so I did this instead. ;-)
-Print it out, (or trace it :-) ) then cut it out.
-Cut your metal into a rough size.
-Trace the pattern onto your metal. (I etched it)
STEP 3: Hack It!
Now cut along your tracing with the hacksaw, I also used a bench grinder for a few parts.
Patience is useful. :-)
STEP 4: Smooth the Edges
After you've cut all the excess metal off, it'll probably pretty rough, get a metal file (I was using a bigger small file, and a small file) Keep going all around until it's smooth.
-If you want you can also add some "teeth" =)
STEP 5: I Want to See!
To add some character to it, drill a hole, obviously near the head. ;-)
-then another hole (I made it a little bigger) at the other end for a key ring &c.
Put it on your keyring, or attach some cord to it, hang it up somewhere, Enjoy!
17 Comments
Martyka 11 years ago
tevers94 14 years ago
Jason Bj 14 years ago
3366carlos 15 years ago
w00ty32 16 years ago
Stanislaw 16 years ago
jtobako 16 years ago
ll.13 16 years ago
duck-lemon 16 years ago
LinuxH4x0r 16 years ago
GorillazMiko 16 years ago
ll.13 16 years ago
Gunk on Floor 16 years ago
