Pocket Laser Show Mod
Intro: Pocket Laser Show Mod
In this instructable i will show how to mod the pocket laser light show from thinkgeek to use it with any other laser. Because the original red laser does not provide that much fun then a green one. The laser I will be using is the Core 5mW from Wickedlasers
Click here for 5% Discount at Wickedlasers!
STEP 1: What You Need
Pocket Laser Show
The Core Laser (Any pen-style laser pen would work)
Screwdriver
Drill
PVC Pipe
Some plastic or rubber to connect the PVC pipe to the pocket laser show.
Screwdriver
Drill
PVC Pipe
STEP 2: Unscrew
Remove the screws from the pocket laser show.
STEP 3: Remove the Red Laser
Carefully open the case and make sure the wires don't break. Unscrew the red laser, you can either leave it hanging in the casing or cut it off.
STEP 4: Drill a Hole!
Close it for now and drill a hole here.
STEP 5: PVC Pipe
Now your going to need your PVC pipe. My PVC pipe it around 10CM long. I attached a piece of plastic on it so it gets stuck in the hole from the pocket laser. You can basically use anything depending on how big the hole in pocket laser show is to attract the PVC pipe. As long as it does not fall off and can hold the weight of your laser ofcourse.
STEP 6: Attach the PVC Pipe
Attach the PVC pipe to your pocket laser show.
STEP 7: Put Your Laser in the PVC Pipe
Put your laser in the PVC pipe. I used some tape to keep the laser on. The Core 5mW can basically stay on until the batteries run out aslong as you watch the tempature of the laser. If your using a more powerful laser be careful to not go over the duty cycle.
Posted by Laser Community member: Slayerduck
laser forum
green laser pointer
laser forum
green laser pointer
28 Comments
Daddio_UK 14 years ago
chaydgb 13 years ago
hipydude2001 13 years ago
pleabargain 13 years ago
PoisonedV 16 years ago
slayerduck 16 years ago
neopangea 16 years ago
disturbedreaper 14 years ago
Noodle god 15 years ago
psyteknology 15 years ago
mspark400 15 years ago
