Program Arduino From Raspberry Pi
Intro: Program Arduino From Raspberry Pi
In this tutorial I will show you how to program arduino with the raspberry pi.
All you need are:
Raspberry pi with internet connection
Arduino uno
Connection cord
STEP 1: What to Do
Go in to the raspi lxterminal and type in sudo apt-get install arduino.
Once you hit enter it will download and once you finish restart the pi.
This video will help u through it.
10 Comments
Arman5592 9 years ago
HristoH11 7 years ago
basically the reason why I want to use arduino pro mini and control it over the Pi is the following - ADC
dougsmith74 9 years ago
frederic.plante.Legrand 7 years ago
I'd like to point out that an ATmega328 can pretty much boot load from an SD card, and have a menu to select the program to load, and as such, it can pretty much act like a computer.
http://gamebuino.com/wiki/index.php?title=Bootload...
dougsmith74 7 years ago
Thanks, I was not aware of that even to this day. I'll check it out but, I'm skeptical that it would be as Trivial to setup as simply using the rPi is to control my microcontrollers. Then again I'm a bit biased since I've been using Linux since 1994 and I store all my infrastructure as code.
Frankv14 8 years ago
In case its useful to someone:
When I ran "arduino" on my RPi3 (Raspbian Jessie), I got a message "Gtk-Message: Failed to load module "canberra-gtk-module"". I don't know if that's important, but I ran "sudo apt-get install gnome-session-canberra" and it went away.
JMS Infrastructure ConsultanciesL 8 years ago
The arduino.cc IDE 1.0.1 was pretty straight forward, all you really have to do is set the serial permission then you can select the board and upload without a problem. The real problem I'm having is that I purchased a zero pro board from arduino.org and I'm having trouble getting the 1.7.6 that would be required to upload code to it installed on Raspbian. I know the simple solution would be to just run it on a full-sized desktop but lets just assume that all I have to work with are a couple of RPi 2's. I can find virtually nothing online about how to go about it and I know there are others out there looking for ARM to ARM programming options so any suggestions? (Wiling to use an alternate Pi2 compatible IDE to program it from as long as I can have a debugging interface that is preferably integrated but I can settle for a separate one)
cuongpt 9 years ago
BrianM15 9 years ago
unable to locate package arduino
StevenS8 9 years ago
I bought a chinese knockoff arduino that would not been seen on my macbook air or my hackintosh. I know linux sees it just fine but I have gotten rid of all of my linux machines at home. Just wanted to see if I could program it with my raspberry pi and your video proves it can! Thanks for the info.
