Programmable Temperature Controller + Hot Plate
Intro: Programmable Temperature Controller + Hot Plate
Heating things up is one of the most performed tasks in a lab. Quite a lot of times it is not enough to simply hold something at a certain temperature, but the rate at which something is heated and for how long is just as important. Especially when you try to develop catalysts for chemical processes, the temperature program and exact temperature control is crucial and you probably do not want to stay in the lab for 16 hours to manually adapt your temperature program. Unfortunately, programmable temperature controllers that can automate processes are really expensive. So I decided to build a highly customizable controller that is able to run temperature ramps and read multiple different temperature programs from a SD card. It also provides a logging function on the SD card that allows you to evaluate the resulting temperature profile after running a program.
It is a great hack for your heating devices, since it can be easily connected to almost any heating apparatus you can think of, as long as it allows you to also connect a thermocouple. So If you have ever thought about building the perfect electric kiln (there are multiple really good explanations online) or hot plate (take a look at the steps 6 and 7), now is your time.
Overall the controller should cost you about $45 and the hot plate about $55. You should easily be able to build this as a weekend project.
STEP 1: Things You Need
Programmable temperature controller:
Electronics:
Hot plate:
Electronics:
- Solid state relays (5V control voltage, 16 A load current)
- LCD (e.g. on amazon.com
) - SD card board
- MAX 6675 controller board (e.g. on olimex.com)
- Atmega 328 chip & socket
- 5 x 10 kΩ Resistors
- 4 x 1 kΩ Resistors
- 4 x 560 Ω Resistors
- 1 µF Capacitor
- 100 pF Capacitor
- 2 x 22pF Capacitor
- 16 MHz quartz oscillator
- LM7805 5V linear voltage regulator
- Rotary encoder
- Mechanical 110 V switches
- 10 A fuse and fuse holder
- 4 mm ply wood
- Wood glue
- Laser cutter
- Primer
- Paint
Hot plate:
- Metal case as support (e.g. an old computer power supply)
- Small plastic case
- Aluminum plate 20x20x1 cm
- 2 Cartridge Heaters (1/4’’ or 6 mm) (e.g. on amazon.com
or from China on ebay.com) - Type K thermocouple (1/4’’ or 6 mm)
- Steel thread rod (¼ ‘’ or 3/8’’) and nuts
- Locking screws
- Lead
- Copper paste
- Long (ca. 30 cm) drill for the heating cartridge and thermocouple
- Tap & die for Locking screw and steel thread rod
- Drill press
STEP 2: Building the Case Part 1
You can of course use any casing you want, but I decided to laser cut a custom one. I uploaded the files to this step (the three different file types all include the same design. I just wanted to offer you options depending on which file type works best for you). You can see in the first image where every piece goes. Start by glueing the LCD distance holder to the back of the front-top panel. While the wood glue sets, attach the side panels to the back and the top panel. A corner clamp is certainly helpful to do so. Than add the front-bottom and front-top piece.
In case you are wondering whether wood is a good material choice for the casing, let me reduce your fears. Its autoignition temperature is about 572°F [1]. Since I have added a thermal switch to the hot plate that shuts it off at 338°F, you can be very sure that it is safe. Even after more than a thousand days at a constant temperature of 300°F, studies showed that wood would not self ignite [2]. Furthermore air is know to be an extremely good thermal insulator. If you are planning on running the temperature controller with a apparatus that heats up the surrounding air to more than 500°F: DON'T! Even if you are building a kiln the outside shouldn't be getting that hot.
STEP 3: Building the Case Part 2
Since I am not a big fan of the burned edges the laser cutter leaves, I decided to get rid of them by filling the gaps with wood filler and sanding them down. You can see the result in the first picture.
I used a triangular shaped strip of wood to strengthen the connections. They will also be used to attach the bottom later on. Cut it to fit the corners, as shown in the pictures.
If you want you can prime and spray paint it, but that's up to you.
STEP 4: Electronics
Safety precautions:
In this instructable you'll have to wire some parts with 110 volts line power and most of the heating plate is conductive metal. Unless you are not 100% sure, what you are doing (and even then I would not work without one) it is very advisable to use a ground fault circuit interrupter adapter or a safety socket when working on and with the device. These sockets will shut off the current immediately when a current leakage is present (e.g. through you). Otherwise you have to wait until one of the fuses blows which needs much more power (in Germany line power fuses blow at about 3.6 kW). GFCIs are cheap safety features that I would everybody urge to use. You can buy them e.g. on amazon.com.
Since I am planning on using heating power up to 1 kW, the main power is led through a 10 amp fuse and a mechanical power switch with a LED power indicator. These devices can disconnect the whole controller and heating circuit from the AC power. The ground wire is fed into the heating cartridge connector and should be attached to all conductive metal parts of the casing.
As you can see in the electronics circuit plan, one of the 110 V lines from the switch is led to the heating cartridge connector through a solid state relay and a second mechanical switch, whereas the second line is wired directly to the heating cartridge connector. When pin 6 on the Atmega controller is set to HIGH and the second mechanical switch is turned on, the load circuit is closed and powers the heating cartridges. The second mechanical switch also contains a LED power indicator which visualizes the heating pulses.
The low voltage supply for the controller circuit is generated by a small print transformer that generates 12 V AC which is subsequently fed into a four diode bridge rectifier and a LM7805 linear voltage regulator.
For measuring the temperature, we use a K-type thermocouple and MAX6675 controller board (MOD-TC). The MAX6675 chip has an internal 12-bit AD converter and can be connected via a serial interface. The LCD (SainSmart IIC/I2C/TWI Serial 2004 20x4 LCD Module Shield), is connected with the Atmega's I2C port and the SD-Card interface board is wired with the SPI interface. For navigation and setting the parameters we use a rotary encoder with integrated push button.
The heating plate also contains a thermal switch, which mechanically disconnects the heating cartridges when the temperature is over 190°C.
STEP 5: Code
You can find the code in the attached files. I implemented the following external libraries:
PID library
Bounce library
Rotary Encoder
I2C LC Display
MAX6675
NOTE: In "MAX6675.h" you have to replace line 11 ( #include "WProgram.h" ) with
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#endif
in order to make it run on Arduino 1.05
Use the "LiquidCrystal" library in the sub folder 2004-1.0 code, ignore "LiquidCrystal_I2C".
When a temperature is set manually or a program is selected from the SD card, the controller starts reading the temperature ever 0.1 seconds and calculates the next heating pulse length with PID library. As we are using a lot of different libraries I used up more than 99.5% of all the free flash memory on the atmega 328 chip. Worse, I had to shorten the text and menu for the LCD display, as I was running out of SRAM. Next time, I would probably be using an atmega 2560 or swap some strings into the EEPROM.
The different programs have to be saved as comma separated text files with incrementing file names (1.txt,…10.txt) in the root folder of the SD-card. The layout of the files should look like this:
1. Line: title (maximum 20 characters)
2. Line: first temperature set point, first heating rate, first duration
3. Line: second temperature set point, second heating rate, second duration
4. Line ...
You can use up to a maximum of 10 lines per file. It has to be terminated with a blank line.
I used an Arduino UNO to upload the following code to the Atmega:
PID library
Bounce library
Rotary Encoder
I2C LC Display
MAX6675
#else
#endif
4. Line ...
//Temperature Controller #include <MAX6675.h> //LCD #include <Wire.h> #include <LCD.h> #include <LiquidCrystal_I2C.h> #include <SD.h> #include <PID_v1.h> //Rotary Encoder #include <Encoder.h> Encoder roundEnc(2, 3); //Pushbutton on rotary encoder #include <Bounce.h> Bounce pushButton = Bounce(4 ,5); #define I2C_ADDR 0x3F // Define I2C Address where the LCD is #define BACKLIGHT_PIN 3 #define En_pin 2 #define Rw_pin 1 #define Rs_pin 0 #define D4_pin 4 #define D5_pin 5 #define D6_pin 6 #define D7_pin 7 LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin); //Temperatursensor int tCS = 7; // CS pin on MAX6675 int tSO = 9; // SO pin of MAX6675 int tSCK = 8; // SCK pin of MAX6675 int units = 1; // Units to readout temp (0 = raw, 1 = ˚C, 2 = ˚F) int TCError = 0; // ErrorFlag - TC Error int tempVal = 0; // Actual-Temperatur //Display unsigned long lastMeas = 0; // Last temperature measurement unsigned long lastDisp = 0; // Last display change unsigned long lastTempDisp = 0; // Last temperature update on display unsigned long lastLog = 0; // Last Logstate unsigned long logTime = 0; int lastDispTemp = -1; int dispOn = 0; // blink int cPosX = -1; // x-position (cursor) on display int cPosY = -1; // y-position on display String emptyString = " "; unsigned long lastDispPrg = 0; //Zeit seit letztem Update des Programm-Displays // Has the button on the rotary encoder been pressed? // 0 = no // 1 = yes // 2 = yes, for more than 2 seconds int buttonPressed = 0; // Rotational Encoder // 0 = not changed // 1 = clockwise // 2 = counterclockwise int rotationState = 0; int rotationNumber = 0; int lastRotationNumber = 0; int rotationBigLeap = 0; //was the rotationl encoder moved more than ~20° int oldRotState = 0; //Program state // 0: No program // 1: Manual Setpoint // 2: Load from SD // 3: not used // 4: Program is running int progState = 0; int subProgState = 0; int lastProgState = -1; int lastSubProgState = -1; // Programs from SD-Card int progCount = 0; byte progLnCount = 0; byte progTSp[10] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; byte progSprr[10] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; word progTime[10] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; //Which type of program is running at the moment? //-1 = 0; //0 = Single-Point //>1 = SD-Card int progRun = -1; int runLine = -1; // Actual subprogram of the SDCard unsigned long runTime = 0; // How long is the step running already unsigned long stepTime = 0; // How much time to increase the ramp unsigned long lastPuls = 0; // Last heating puls int minutesPast = 0; boolean SDOpen = false; int aTsp = 0; int Tsp = 120; //Setpoint °C int MaxT = 190; // Maximal T °C byte Sprr = 15; //Rate °C/m byte MaxR = 20; // Maximale Ramp int TAlert = 200; // Shutown Temperature int Tdig1 = Tsp/100; //Digits for Tsp int Tdig2 = (Tsp%100)/10; int Tdig3 = Tsp%10; int Rdig1 = Sprr/10; //Digits for Rp int Rdig2 = Sprr%10; // Initialize the MAX6675 Library for our chip // Setup Serial output and LED Pin // MAX6675 Library already sets pin modes for MAX6675 chip! MAX6675 temp(tCS,tSO,tSCK,units); //PID Parameters double Setpoint, Input, Output; PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT); void setup() { //Serial.begin(9600); lcd.begin (20,4); // Switch on the backlight lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE); lcd.setBacklight(HIGH); lcd.noBlink(); lcd.clear (); pinMode(10, OUTPUT); //SC-Pin SD-Card //pinMode(53, OUTPUT); //SC-Pin SD-Karte - Arduino mega //digitalWrite(53, HIGH); pinMode(6, OUTPUT); //heating pin } void loop() { //disable Heating digitalWrite(6, LOW); //get user input getButtonState(); getRotState(); //change display setState(); //Update display displayState(); //Update Temperature //Faster measurement when program is running. In the programming stage the LCD lags if (progState == 4){ getTemp(); updateProgram(); Input = tempVal; Setpoint = aTsp; myPID.Compute(); heatingPuls(); if ((lastLog + 1000) < millis()){ updateLog(); lastLog = millis(); } } else if ((lastMeas + 10000) < millis()){ getTemp(); lastMeas = millis(); } if ((tempVal > TAlert) || ( TCError ==1 )) { stopProgram(); delay(5000); } } void getButtonState(){ unsigned long pushTime = pushButton.duration(); pushButton.update(); //How long was the button pressed - abort? boolean pushed = pushButton.fallingEdge(); if ((pushed == true) && (pushTime < 1500) ){ buttonPressed = 1; } else if ((pushed == true) && (pushTime >= 1500) ){ buttonPressed = 2; } else { buttonPressed = 0; } } void getRotState(){ //int roataionState = 0; //int rotationNumber = 0; - Scale 0-10 long tempState = roundEnc.read(); if (tempState > oldRotState) { rotationState = 1; // rotationNumber = (tempState%100)/10; int tempRotationNumber = (tempState%100)/10; if (tempRotationNumber != rotationNumber) { rotationBigLeap = 1; } rotationNumber = tempRotationNumber; if (rotationNumber < 0) { rotationNumber = 10 + rotationNumber; } oldRotState = (tempState%100); roundEnc.write(oldRotState); } else if (tempState < oldRotState) { rotationState = 2; // rotationNumber = (tempState%100)/10; int tempRotationNumber = (tempState%100)/10; if (tempRotationNumber != rotationNumber) { rotationBigLeap = 1; } rotationNumber = tempRotationNumber; if (rotationNumber < 0) { rotationNumber = 10 + rotationNumber; } oldRotState = (tempState%100); roundEnc.write(oldRotState); } else { rotationState = 0; rotationBigLeap = 0; } } void resetRotState(int digit){ //For entering numbers in the LCD rotationNumber = digit; //Failsave if ((rotationNumber > 10) || (rotationNumber < 0)) { rotationNumber = 0; } oldRotState = digit * 10; roundEnc.write(oldRotState); } //Verarbeite Eingaben am Display void setState(){ //Rotationstate 1 = right //Rotationstate 2 = left //Long pressing: abort if ((progState != 0) && (buttonPressed == 2)) { stopProgram(); buttonPressed = 0; return; } //submenu 0,1 if ((progState == 0) && (rotationState != 0)){ int select = rotationNumber%2 + 1; subProgState = select; displayState(); return; } //choose menu entry //manual setpoint if ((progState == 0) && (buttonPressed == 1)){ if (subProgState == 1) { progState = 1; subProgState = 0; displayState(); buttonPressed = 0; return; } //SD-Card if (subProgState == 2) { progState = 2; subProgState = 0; displayState(); buttonPressed = 0; return; } } //Submenue 0,1 - manual mode if ((progState == 1) && (subProgState < 4) && (rotationState == 1) && (rotationBigLeap == 1)){ subProgState = subProgState + 1; if (subProgState > 3) { subProgState = 0; } displayState(); rotationBigLeap = 0; return; } if ((progState == 1) && (subProgState < 4) && (rotationState == 2) && (rotationBigLeap == 1)){ subProgState = subProgState - 1; if (subProgState < 0) { subProgState = 3; } displayState(); rotationBigLeap = 0; return; } //Back, TSP, Rp, Start in Manual Mode if ((progState == 1) && (subProgState == 0) && (buttonPressed == 1)) { stopProgram(); buttonPressed = 0; return; } if ((progState == 1) && (subProgState == 1) && (buttonPressed == 1)) { subProgState = 11; buttonPressed = 0; return; } if ((progState == 1) && (subProgState == 2) && (buttonPressed == 1)) { subProgState = 21; buttonPressed = 0; return; } if ((progState == 1) && (subProgState == 3) && (buttonPressed == 1)) { startProgram(0); buttonPressed = 0; return; } //1., 2., 3. Digit T-Setpoint if ((progState == 1) && (subProgState == 11) && (buttonPressed == 1)) { subProgState = 12; buttonPressed = 0; return; } if ((progState == 1) && (subProgState == 12) && (buttonPressed == 1)) { subProgState = 13; buttonPressed = 0; return; } if ((progState == 1) && (subProgState == 13) && (buttonPressed == 1)) { //Last digit subProgState = 1; Tsp = Tdig1 * 100 + Tdig2 * 10 + Tdig3; if (Tsp > MaxT) { Tsp = MaxT; } //Maximal Temperature Tdig1 = Tsp/100; //Digits for Tsp Tdig2 = (Tsp%100)/10; Tdig3 = Tsp%10; buttonPressed = 0; return; } //1., 2. Digit ramp if ((progState == 1) && (subProgState == 21) && (buttonPressed == 1)) { subProgState = 22; buttonPressed = 0; return; } if ((progState == 1) && (subProgState == 22) && (buttonPressed == 1)) { //Last digit subProgState = 2; Sprr = Rdig1 * 10 + Rdig2; if (Sprr > MaxR) { Sprr = MaxR; } //Maximal/minimal ramp if (Sprr < 1) { Sprr = 1; } Rdig1 = Sprr/10; //Digits for Rp Rdig2 = Sprr%10; buttonPressed = 0; return; } //Submenu 1,1 - SD-Programm if ((progState == 2) && (subProgState < 11) && (rotationState == 1) && (rotationBigLeap == 1)){ subProgState = subProgState + 1; if (subProgState > progCount) { subProgState = 1; } displayState(); rotationBigLeap = 0; return; } if ((progState == 2) && (subProgState < 11) && (rotationState == 2) && (rotationBigLeap == 1)){ subProgState = subProgState - 1; if (subProgState < 1) { subProgState = progCount; } displayState(); rotationBigLeap = 0; return; } if ((progState == 2) && (subProgState < 11) && (buttonPressed == 1)){ startProgram(subProgState); buttonPressed = 0; return; } } void stopProgram(){ progState = 0; subProgState = 0; progRun = -1; runLine = -1; lastSubProgState = -1; lastProgState = -1; displayState(); myPID.SetMode(MANUAL); } void startProgram(int runType){ progRun = runType; aTsp = tempVal; runTime = millis(); runLine = 0; progState = 4; myPID.SetMode(AUTOMATIC); logTime = millis(); } void updateProgram() { //SD-Card //progLnCount //runline minutesPast = 1.0 * ((millis() - runTime) / 60000.0); if (progRun > 0){ Tsp = progTSp[runLine]; Sprr = progSprr[runLine]; //Load new program? if (minutesPast >= progTime[runLine]) { runLine++; if (runLine > progLnCount) { stopProgram(); return; } runTime = millis(); } } //Ramp long timeStep = (1000.0 * 60.0) / (double)Sprr; if ((stepTime + timeStep < millis()) && (aTsp < Tsp)) { aTsp++; stepTime=millis(); } else if ((stepTime + timeStep < millis()) && (aTsp > Tsp)) { aTsp--; stepTime=millis(); } } void heatingPuls(){ //pulse every 0.1 s if ((lastPuls + 100) < millis()) { digitalWrite(6, HIGH); int dly = Output * 1; //limit Power if (dly > 1000) { dly = 1000; } else if (dly < 0) { dly = 0; } //Serial.println(dly); delay(dly); digitalWrite(6, LOW); lastPuls = millis(); } } void getTemp(){ // Read the temp from the MAX6675 float loop_temperature[2]; for (int ii=0; ii<2; ii++) { loop_temperature[ii] = temp.read_temp(); if (loop_temperature[ii] < 0) { TCError = 1; } delay(50); } tempVal = (int)((loop_temperature[0] + loop_temperature[1] ) / 2 + 0.5); } void updateTemp( boolean force = false, int lastPosX = -1, int lastPosY = -1 ){ if (((millis() > (lastTempDisp + 1000)) && ( tempVal != lastDispTemp)) || (force == true)) { lcd.setCursor(0, 3); lcd.print("T: "); lcd.setCursor(3, 3); lcd.print(tempVal); lcd.print((char)223); lcd.print("C "); lastTempDisp = millis(); lastDispTemp = tempVal; if ((lastPosX != -1) || (lastPosY != -1)) { lcd.setCursor(lastPosX, lastPosY); } } } void fillNumber3(int number, String &dest3){ if (number < -9) { dest3 += String(number); } else if (number < 0) { dest3 = "0"; dest3 += String(number); } else if (number < 10) { dest3 = "00"; dest3 += String(number); } else if (number < 100) { dest3 = "0"; dest3 += String(number); } else { dest3 = String(number); } } void fillNumber2(int number, String &dest2){ if (number < 10) { dest2 = "0"; dest2 += String(number); } else { dest2 = String(number); } } void printProgLine(byte number, String &line){ line = (String)(number); line += ": "; line += (String)(progTSp[number]); line += ", "; line += (String)(progSprr[number]); line += ", "; line += (String)(progTime[number]); line += " "; } void printProcessLine(String &line){ String saSP; fillNumber3( aTsp, saSP); String st; fillNumber3( minutesPast , st); line = "TaSp: "; line += saSP; line += (char)223; line += "C "; line += " t: "; line += st; } void printSingleLine(String &line){ String sTsp; String sSprr; fillNumber3(Tsp, sTsp); fillNumber2(Sprr, sSprr); line = "Tsp: "; line += sTsp; line += (char)223; line += "C "; line += "Rp: "; line += sSprr; line += (char)223; line += "/m"; } //Update display void displayState(){ if (progState==0) { display0(); } if (progState==1) { display1(); } if (progState==2) { display2(); } if (progState==4) { display4(); } } void display0(){ if (lastProgState != 0){ cPosX = -1; cPosY = -1; lcd.noBlink(); lcd.clear (); // go home lcd.print("Program"); // program ended lastProgState = 0; lastSubProgState = -1; //Reset updateTemp(true); //Update Temperature } //Update every second if ((subProgState == 0) && (millis() > (lastDisp + 1000)) && (dispOn == 0)) { lcd.setCursor(0, 1); // go to the 2nd line lcd.print("-"); lastDisp = millis(); dispOn = 1; } else if ((subProgState == 0) && (millis() > (lastDisp + 1000))){ lcd.setCursor ( 0, 1 ); // go to the 2nd line lcd.print(emptyString); lastDisp = millis(); dispOn = 0; } else if ((subProgState == 1) && (lastSubProgState != 1)){ lcd.setCursor(0, 1); lcd.print("Setpoint"); lastSubProgState = 1; updateTemp(true); } else if ((subProgState == 2) && (lastSubProgState != 2)){ lcd.setCursor(0, 1); lcd.print("SDCard "); lastSubProgState = 2; updateTemp(true); } updateTemp(); } //Manual setpoint void display1(){ if (lastProgState != 1){ cPosX = -1; cPosY = -1; lcd.noBlink(); lcd.clear (); // go home lcd.print("Setpoint"); lcd.setCursor(0, 1); String line; printSingleLine(line); lcd.print(line); lastProgState = 1; lastSubProgState = -1; updateTemp(true); } //0. Back if ((subProgState == 0) && (lastSubProgState != 0)) { lcd.noBlink(); lcd.setCursor(0, 2); lcd.print("Back "); } //1. Set Temp if ((subProgState == 1) && (lastSubProgState != 1)) { lcd.noBlink(); lcd.setCursor(0, 1); String line; printSingleLine(line); lcd.print(line); lcd.setCursor(0, 2); lcd.print("TSp "); lastSubProgState = 1; } //2. Set Ramp if ((subProgState == 2) && (lastSubProgState != 2)) { lcd.noBlink(); lcd.setCursor(0, 1); String line; printSingleLine(line); lcd.print(line); lcd.setCursor(0, 2); lcd.print("Rp "); lastSubProgState = 2; } //3. Start if ((subProgState == 3) && (lastSubProgState != 3)) { lcd.noBlink(); lcd.setCursor(0, 2); lcd.print("Start"); lastSubProgState = 3; } //4. Change T 1. Digit if ((subProgState == 11) && (lastSubProgState != 11)) { //1. Digit cPosX = 1, cPosY = 1 cPosX = 5; cPosY = 1; lcd.blink(); resetRotState(Tdig1); lcd.setCursor(cPosX, cPosY); lcd.print(Tdig1); lcd.setCursor(cPosX, cPosY); lastSubProgState = 11; } else if (subProgState == 11) { lcd.setCursor(cPosX, cPosY); Tdig1 = rotationNumber; lcd.print(Tdig1); lcd.setCursor(cPosX, cPosY); } //5. Change T 2. Digit if ((subProgState == 12) && (lastSubProgState != 12)) { //2. Digit cPosX = 6, cPosY = 1 cPosX = 6; cPosY = 1; lcd.blink(); resetRotState(Tdig2); lcd.setCursor(cPosX, cPosY); lcd.print(Tdig2); lcd.setCursor(cPosX, cPosY); lastSubProgState = 12; } else if (subProgState == 12) { lcd.setCursor(cPosX, cPosY); Tdig2 = rotationNumber; lcd.print(Tdig2); lcd.setCursor(cPosX, cPosY); } //6. Change T 3. Digit if ((subProgState == 13) && (lastSubProgState != 13)) { //3. Digit cPosX = 7, cPosY = 1 cPosX = 7; cPosY = 1; lcd.blink(); resetRotState(Tdig3); lcd.setCursor(cPosX, cPosY); lcd.print(Tdig3); lcd.setCursor(cPosX, cPosY); lastSubProgState = 13; } else if (subProgState == 13) { lcd.setCursor(cPosX, cPosY); Tdig3 = rotationNumber; lcd.print(Tdig3); lcd.setCursor(cPosX, cPosY); } //4. Change Ramp 1. Digit if ((subProgState == 21) && (lastSubProgState != 21)) { //1. Digit cPosX = 15, cPosY = 1 cPosX = 15; cPosY = 1; lcd.blink(); resetRotState(Rdig1); lcd.setCursor(cPosX, cPosY); lcd.print(Rdig1); lcd.setCursor(cPosX, cPosY); lastSubProgState = 21; } else if (subProgState == 21) { lcd.setCursor(cPosX, cPosY); Rdig1 = rotationNumber; lcd.print(Rdig1); lcd.setCursor(cPosX, cPosY); } //5. Change Ramp 2. Digit if ((subProgState == 22) && (lastSubProgState != 22)) { //2. Digit cPosX = 16, cPosY = 1 cPosX = 16; cPosY = 1; lcd.blink(); resetRotState(Rdig2); lcd.setCursor(cPosX, cPosY); lcd.print(Rdig2); lcd.setCursor(cPosX, cPosY); lastSubProgState = 22; } else if (subProgState == 22) { lcd.setCursor(cPosX, cPosY); Rdig2 = rotationNumber; lcd.print(Rdig2); lcd.setCursor(cPosX, cPosY); } updateTemp(false, cPosX, cPosY); } void display2(){ if (lastProgState != 2){ lcd.noBlink(); lcd.clear (); // go home lcd.print("SDCard"); lcd.setCursor(0, 1); if (SDOpen != true) { if (! SD.begin(10)) { stopProgram(); return; } } SDOpen = true; progCount = 0; for (int ii = 1; ii < 10; ii++){ String fname = String(ii); fname += ".txt"; char fnamec[6]; fname.toCharArray(fnamec, 6); File myFile = SD.open(fnamec, FILE_READ); if (myFile) { progCount++; } myFile.close(); } if (progCount == 0) { stopProgram(); return; } lastProgState = 2; subProgState = 1; lastSubProgState = -1; updateTemp(true); } if ((subProgState < 10) && (lastSubProgState != subProgState)) { String fname = String(subProgState); fname += ".txt"; char fnamec[6]; fname.toCharArray(fnamec, 6); File myFile = SD.open(fnamec, FILE_READ); if (! myFile) { stopProgram(); } byte line = 0; byte Slength = 0; char tempString[1]; String HeadLine = ""; String ProgLine = ""; for (byte ii=0; ii < 10; ii++) { progTSp[ii] = 0; progSprr[ii] = 0; progTime[ii] = 0; } while (myFile.available()) { tempString[1] = myFile.read(); if (tempString[1] == '\r' ) { } else if (tempString[1] != '\n' ) { ProgLine += tempString[1]; Slength++; } else { if (line == 0) { HeadLine = ProgLine; ProgLine = ""; Slength = 0; line++; } else { if ((line > 10) || (Slength > 20) ) { stopProgram(); return; } char* accum; char buffer[Slength+1]; ProgLine.toCharArray(buffer, Slength+1); const char sep[] = ","; progTSp[line-1] = atoi(strtok_r(buffer, sep, &accum)); if (progTSp[line-1] > MaxT) { progTSp[line-1] = MaxT; } progSprr[line-1] = atoi(strtok_r(NULL, sep, &accum)); if (progSprr[line-1] > MaxR) { progSprr[line-1] = MaxR; }; if (progSprr[line-1] < 1) { progSprr[line-1] = 1; } progTime[line-1] = atoi(strtok_r(NULL, sep, &accum)); progLnCount = line - 1; //0-Anzahl-1 Slength = 0; line++; ProgLine = ""; // } } } myFile.close(); lcd.setCursor(0, 1); lcd.print(emptyString); lcd.setCursor(0, 1); lcd.print(HeadLine); printProgLine(0, ProgLine); lcd.setCursor(0, 2); lcd.print(emptyString); lcd.setCursor(0, 2); lcd.print(ProgLine); resetRotState(0); lastSubProgState = subProgState; } updateTemp(); } void display4(){ if ((lastDispPrg + 1000) > millis()) { return; } if (lastProgState != 4) { lcd.noBlink(); lcd.clear (); updateTemp(true); lastProgState = 4; } if ( progRun == 0 ) { lcd.setCursor(0, 0); String line; printProcessLine(line); lcd.print(line); lcd.setCursor(0, 1); printSingleLine(line); lcd.print(line); } if ( progRun > 0 ) { lcd.setCursor(0, 0); String line; printProcessLine(line); lcd.print(line); lcd.setCursor(0, 1); printProgLine(runLine, line); lcd.print(line); if (runLine != progLnCount) { lcd.setCursor(0, 2); printProgLine(runLine+1, line); lcd.print(line); } else { lcd.setCursor(0, 2); lcd.print(emptyString); } } updateTemp(); } void updateLog(){ if (SDOpen != true) { if (! SD.begin(10)) { return; } } SDOpen = true; File myFile = SD.open("T.log", FILE_WRITE); if (! myFile) { return; } myFile.print(millis() - logTime); // myFile.print(", "); // myFile.print(aTsp); myFile.print(", "); myFile.println(tempVal); myFile.close(); }As you can see in the picture, for a first (and not optimized) try these are very nice results. A really nifty way to improve the system even more would be to implement an autotunig library (e.g. from here), but it would need more space than what is available on the atmega328. An other optimization would be to use a more accurate thermocouple controller.
STEP 6: Preparing the Hot Plate
To find out, which the best position for the heating cartridges is and whether an adequate heat distribution can be reached using 1 cm thick aluminum, I simulated the stationary temperature profile. As you can see, at about 470 K (197°C, 387 F) the local deviation is roughly ±3 K which is enough for my purpose.
Start by drilling the holes for the heating cartridges and the thermocouple. This part is a little bit tricky and you definitely need a drill press for this step. You also can try to use two aluminum plates and routing machine with a ball nose cutter. Next, drill the holes for the steel thread rods and locking screws into the aluminum plates and metal support. If you want to use a thermal switch as safety device, also drill the matching holes into the aluminum plate. Lubricate the heating cartridge and thermocouple with the copper paste to improve the heat transfer to the aluminum. Afterwards use lock screws to hold them in the plate.
STEP 7: Assembling the Hot Plate
Fix the thermal switch to the plate and solder one wire of each cartridge to one pin of the switch. Connect the other pin to the plug in the metal casing and the other wire directly to a pin of the metal case.
To stabilize the heating plate, you can glue a small plastic casing into the metal support plate and fill it with lead.
In order to get an impression how hot the metal casing of the support gets, I simulated the temperature profile of the heating plate and the steel rods below the plate. It turns out that at 540 K (270°C, 518 F) the steel rods are about 370 K (97 °C, 206 F) hot. Since I limit the temperature to 180°C, I could also have used a wooden casing.
I placed a warning on the hot plate with heat resistant spray paint and used the hot plate to burn it onto the aluminum.
55 Comments
keytotheskies 1 year ago
nedjk 6 years ago
Best presented project I've seen so far.
I'm TRYING to make cheese using the Mad Millie kits from NZ.
Would this project manage to heat from 30 deg C to 100 deg with a 15 litre stainless stock pot on top?
Thanks in advance
Eadiecd 6 years ago
Could you explain how you set up your simulations, or upload your mph files? I'm new to comsol and would love to see how you did this. Thanks!
ayman hussien 7 years ago
would you mind telling me where the program file is?
BrittLiv 7 years ago
Please check out "Step 5: Code"
I did, but I found a lot of libraries and a program attachment
I copied this program to arduino but it couldn't verify the file.
So do I have to create the program from the libraries or does the program has a sequence to boot it in atmega?
also, would you mind telling me how can I program atmega? i have a way but I am not sure 100% from it.
And thank you for your reply.
WeitingQ 8 years ago
thank you very much for your sharing.
and we can use the programmable temperature controller omron e5cn
FangY1 8 years ago
Great project. Thanks for sharing. Ever thought about extending this to a heating AND cooling plate using TEC?
baecker03 8 years ago
mparsons1 9 years ago
Hi, I'm looking to do something quite similar to this using a cartridge heater, thermocouple and an Uno to control the temperature of an aluminium cylinder. My original intention was to earth the cylinder as it will be an exposed piece of metal (with a mains cartridge heater inside it), but I have just discovered that touching my thermocouple to the earthed metal produces a temperature reading of 0. Did you use an electrically isolated thermocouple? I'm struggling to find one with the right body type in the UK. Thanks
elfunkymunky 9 years ago
Hi can I modify an analog hot plate that I would buy from the store with this instructable?
andrea biffi 10 years ago
Wow, your projects are so well built... I love all of them.
For this one you could also use a commercial PID controller (digital temperature controllers on eBay), btw your design is much more unique!
BrittLiv 10 years ago
Hi, yes you can, but they are not programmable and therefore pretty useless in chemical engineering.
ynze 10 years ago
YOU WON A MILL!! Congrats! Again :-)
Y.
Thank you! *happy dance*. Greetings from Matthias (I still couldn't convince him to write his first instructable...)
bajablue 10 years ago
High five, BrittLiv!!!
Thank you! Any plans for your hundred instructable yet?
Lot's of plans, but they have to wait. I cannot find the battery charger for my camera!
No mail service here in the Baja boondocks, so I'll need to buy another one when I visit the States again. I'm just in no hurry to leave this warm and sunny paradise. :-D
Thanks for asking! Congrats again!!!!
blakhachib 10 years ago
congratulations
Thank you!
