Proposed Bellagio Fountain DIY
Intro: Proposed Bellagio Fountain DIY
So I am proposing this completely on theory that I have yet to test. I have looked for DIY replicas of the fountains in front of Bellagio Resort in Las Vegas, Nevada. Most of what I found around the internet involved expensive equipment. I saw one person that estimated he spent $10,000.00 on top of approximately another untold thousands on parts he already had on hand. My proposal is a fairly inexpensive (poor mans) patio or garden pond display. I plan to attempt a build of this in the future. However if anyone has already done it / or does it before I do please comment on where to find your Instructable. I searched Instructables ahead of time and couldn't find anything.
STEP 1: Planning
The first phase as always is the design phase. This is one you will do on your own. My design basically uses a premade pond liner in a raised box. Any variation would do as long as there is space underneath for your chosen air valves.
STEP 2: Valve Design
Another way my proposed design varies from others that I have seen is that I plan on using air to launch the water, rather than a water pump. The design for my valve is my homemade version of a solenoid air valve. I plan to use Harbor Freight air guns, and solenoids either bought or harvested from other things. The solenoids will be controlled with an Ardiuno. I added the reservoir (cups on top of the blow guns) because I assume without them the air gun will launch nothing. When the Arduino sends a signal, the solenoid actuates pushing the air gun lever opening the valve. Theoretically the burst of air will push the water up and out.
STEP 3: Valve Mounting
The reservoirs will protrude through holes in the bottom of the pond liner and be sealed to prevent leakage.
STEP 4: What Now?
I hope to try this some day. I have so many projects I don't know when I will try it. Will you try it? Will you make a proper Instructable? It may be up to you to save this project. Comment, questions, suggestions, time savers, money savers all are welcomed and appreciated.
12 Comments
ewicp 10 years ago
In reality, I've actually been very intrigued by this idea. In Aerospace, we often use "flow straighteners" to make airflow less turbulent. As another comment suggested, this is rather like a bunch of straws stuffed into a pipe. But with water, that's only part of the issue. You also need to remove, from the water, as much of the air as possible. Air disturbs the flow of H2O. There are many ways of doing this but, on a small scale, i have been working on the idea of using a vacuum pump on the water supply prior to putting it through the straws. then keeping the system as tight as possible from that point on.
MDheliMech 10 years ago
ewicp 10 years ago
steveastrouk 10 years ago
iceng 10 years ago
Its the tubular jet water spray nozzles that make the display so nice.
If we had a cross section of a working nozzle, it could be reproduced by a 3D printer.
iceng 10 years ago
resists dispersing the air until a mass of water is moving upward.
Perhaps you have seen treasure hunters in the Caribbean ocean using air
to water vacuum bottom sand away from a treasure site ?
A
animal98 10 years ago
Wermo 10 years ago
