Protecting Your Protection
Intro: Protecting Your Protection
Cleaning and securing The Ruger P90 Pistol..
Always exercise GUN SAFETY..
Cleaning your firearm regularly can protect against the elements (weather/water/dirt) it prevents gunky build up, rust, misfires, operation errors..
Securing your firearm will prevent theft and an accidental child/firearm incident.
Thiers are many different devices on the market for gun safety. I encourage use of any safety devices and layers of them.. In this Instructable I'm using a cable padlock type.
STEP 1: Check Pistol. Completely Unloaded.
Drop clip out, by pressing eject button just below trigger. Pull side back and press slide lock lever up. It will hold the slide back.. Inspect chamber to insure it completely unloaded..
STEP 2: Dissembling Slide
In the camber area is a tab. press it downward until it clicks.. pull slide back and press the slide lock lever out. next turn lever 180°.. pull back the slide again and it would slide right off the front of the trigger platform.
STEP 3: Remove Barrel
remove spring by pressing forward then angel to the side and remove. slide barrel forward angle and pull out.
STEP 4: Cleaning
With gun cleaner on swab, clean inside of barrel.. then use wire brush. swab again then wipe dry using cotton rag.
A small brush with cleaner is useful for getting in some spots.. wipe dry with rag.
STEP 5: Oil or Grease?
some say grease some say oil.. I like using oil.. oil all moving parts. wipe up excess oil..
STEP 6: Reassemble Pistol
First insert barrel into slide. Then place the spring into place. Align slide with track on trigger platform, pull slide back. Turn slide lever back 180°. Pull slide back and hold back while pushing slide lever in. Release slide and insert clip.
STEP 7: Storing Pistol Safe and Secure.
Remove clip. Pull slide back and lock into open position. Feed cable down though the grip. Lock pad lock. Place the pistol in a safe and the hide the keys in a different safe place. And don't forget the combination. Storing your ammunition under lock and key in a different area is a good idea too.
13 Comments
LeeGoffmyown 9 years ago
OMG that is the most useful info I have ever seen on instructables. Thx for the tips you have me thinking now.
KLethal 9 years ago
mariaclemente2000 9 years ago
Very very nice and safe. I will vote yes, and hope you will win.
KLethal 9 years ago
neo71665 9 years ago
I had a kp95 years ago, one of the few I wish I woulda kept but wouldn't swap the S&W i traded for it for anything. The one I had needed a fair bit of polishing on the ramp when I got it but after worked great.
KLethal 9 years ago
cpeebles 9 years ago
KLethal 9 years ago
liam.plybon.3 9 years ago
KLethal 9 years ago
seamster 9 years ago
Excellent guide maintaining your firearm. Nicely done!
KLethal 9 years ago
