Quick and Easy Brazing Aluminum, Copper and Nonferrous Metals
Intro: Quick and Easy Brazing Aluminum, Copper and Nonferrous Metals
In this instructable I'll show you how to fix a bicycle kickstand, make bi-metal candle sticks, show you a few examples of other things you can make. There's a lot more you can do, this is really easy and I hope this will get you started.
I think many instructable projects on this site could be simplified with this technique. Basically, with any project where you want to make something strong out of metal like aluminum or copper. A couple ways you might use this include mechanical uses like adding a foot to a bicycle kick stand, making a bicycle cart or part on a lawnmower, and uses in electronics like soldering copper to aluminum to a solar panel backing. Brazing is just great for a lot of things!
Brazing, means melting an alloy to join two metals. There are a few different brazing systems out there. My favorite is low temperature brazing using an alloy called HTS-735-II. It brazes at low temperatures and makes it easy to connect all sorts of metals and the welds aren't brittle.
Project Materials:
* Propane torch
* Low temp fluxless brazing rods (These are hard to find so I listed a couple places people can get them.)
- Alumiweld 730 rods from Harbor Freight Item #44810, they cost about $14 bucks for an 8 pack. To braze a kick stand you might use 1/4 a rod.
- You can buy pounds for around $35 a pound from alumiweld.com this is where Harbor Freight orders from.
- Or HTS-735-II welding rods can be ordered from these companies in US and a UK seller. These companies charge around $70 for a pack, so it's not the best deal though this is what I used in my projects.
* Pliers
* Protective Gloves
* File or steel wool to clean the joint surfaces.
* A brick or steel can or tray to braze on.
* Metal pieces you want to connect together like: aluminum, magnesium, zinc, brass, copper...
Note:
* Not for food grade applications. Having called the manufacturer of the Alumiweld product, they said they are not selling a food safe product yet, though they will be. So I'll update this instructable when they do. But with the current product I wouldn't let the product have prolonged contact with skin or food since I don't think it's designed for that.
If you do want to join pipes for food applications here is an easy to use product for that purpose:
#450 Soft Silver Solder
96.5% Tin / 3.5% Silver
Melting Point: 430° F
"Use: Ideal for electrical work, utensils, and dairy and food equipment."
http://www.aladdin3in1.com/catalog5.htm
FAQs:
* There are two methods I use for welds, melt and blob methods. Both are described in their own section.
* I use the term "welded" instead "brazed" a lot for a few reasons. First it's common language and people who are starting out with this will be confused by technobabble. The Second, I use the term "welded" because that's how the product I use describes itself.
* This is low temperature so there aren't a lot of fumes or uv light dangers. I often use this indoors, though a garage with good ventilation is probably recommended.
* The weld point tends to be stronger then the base metal, if the metal is aluminum or copper. So you can fill in gaps like dents in propellers and holes or cracks.
* The alloy I'm using here can be used at sea, it won't disintegrate from electrical differences. So you can fix propellers and things with this.
* Making an odd sized nut. Because this alloy does not stick to iron or steel screws, you can melt it onto an aluminum or brass washer and build it up around the threads. Then give it a twist with a wrench, it comes free and you have a nut.
* Making bushings or custom threaded screw holes. This is also usually hard to do. But if you have a piece of steel you can put in a hole and you fill around the hole with this stuff, this alloy won't stick to the steel so when you take out the screw you had in the hole you will have a it will make a threaded screw hole. If you used a smooth steel bolt then you will have a close fitting bushing. Though the hole will be tight so you may need to sand it if you want to use it as a bushing.
* FYI I don't sell this welding product and I'm not associated with the companies that do. This technique is just cheap, easy and awesome! Enjoy!
STEP 1: Melt Brazing - Making Candle Sticks
STEP 2: Melt Brazing - Making Candle Sticks Part 1
Here I cut two pieces of aluminum stock metal (2’ x 3’ x 1/8’) and picked out some copper 3/4' adapter pipes.
STEP 3: Melt Brazing - Making Candle Sticks Part 2
Here I’m heating the metal on a heat resistant surface. I’m heating both pieces with a hand torch and rubbing the brazing rod against the metal. When I'm not applying heat, I touch the metal with the brazing rod to see if it will melt. When the rod starts to melt then the metal is hot enough. So I’m wetting the copper and the aluminum with this melted metal, like melting a crayon. Then I'm applying a little more heat so everything melts together.
STEP 4: Melt Brazing - Making Candle Sticks Part 3
Then I let the parts cool, it's best to let the metals cool slowly in the air. Then I test the welds.
STEP 5: Melt Brazing - Making Candle Sticks Part 4
This is about as easy as soldering, but works on metals that don't easily accept solder. In fact if I was soldering copper to aluminum or aluminum to aluminum, this would be my preferred method since it requires no flux.
STEP 6: Blob Brazing - Bicycle Kick Stand
STEP 7: Blob Brazing - Bicycle Kick Stand Part 1
STEP 8: Blob Brazing - Bicycle Kick Stand Part 2
STEP 9: Some More Examples
* Cup: This cup is made from a discarded can. The metal is very thin so I cleaned it and used the blob method to braze a handle onto it. Though keep in mind that this cup is plastic lined as contact with this particular alloy is not intended for food use.
* Coin: This is a coin for a magic trick. I used a blob welding method, but blob or the touch & melt method would work. (Note: The depicted big-y coins are not us-currency.)
* Bushing: This is a powder cast brass bushing. It would be easier to use a copper tube, but if you wanted to weld on a bushing like this it's not too hard. It is saturated with oil so first you need to burn the oil with the torch. Then position it and braze it. After the item has cooled, polish it and oil it.
65 Comments
heathersharmony 3 years ago
InstructablesSA123 3 years ago
pipe. What is best, solder or braze and what type of materials do I use, re. rods
with flux or without - high flame or low flame? I am a total novice in this regard. Thanks.
terrybb 6 years ago
I want to join copper rod to copper angles. I do stained glass and plan to creat a support for butterflys on the copper rod and support them by soldering them to an elbow rod. What do you recommend to join the copper rod to the copper elbow?
SabinaCowan 8 years ago
wonderful, thanks for the info.
NickS21 8 years ago
I want to make this from galvanized chain, would this method work, thanks.
lowiron 9 years ago
Hi,
I would just like to add a few comments here. I am a maintenance tech and do most of our welding and fabricating at work. A few years ago newbie in our maintenance department introduced me to the HTS 2000 aluminum repair rods. I had heard of this type of material for years, but had never actually used it. One night an aluminum casting on a conveyor roller support had been broken during a mechanical failure of another part of the conveyor. It just so happened that we were out of all types of our aluminum brazing/welding rods, and the supervisor said to toss the part because we can get a new part locally the next morning.
The new kid called me over to the weld area and showed me that he had several sticks of the HTS 2000 in his tool box. He asked if he could try joining the pieces of the support back together so they could operate the conveyor. I told him to go for it because I was curious. I have heard professional welders refer to this type of filler metal as "aluma-crud" and other derogatory names. The kid used a stainless wire brush and brushed the snot out of the pieces. he then soaked the pieces in plain rubbing alcohol, then blew them dry with compressed air. He borrowed my small Smith Aircrafters torch and got busy. When he was done he bounced the support on the cement floor and it held together. That same support was put back on the conveyor, and is still function today running almost 24/7.
I agree that this type of filler metal should not be used in critical areas where failure may lead to injuries or expensive repairs. However, I find that it is very useful when used within it's limitations.
I would also like to point out that I would not use this type of filler in medium to high vibration scenarios. It appears to leave a somewhat more brittle weld joint especially when used on some types of cast aluminum. Here is a little secret I will share with others who are interested in aluminum repairs.
There are several name brand types of flux cored aluminum rod. Some will flow at around 800-900 degrees F. Others flow anywhere from 900 -1150 degrees F. I have found that these flux cored rods/wire are less time consuming because of less preparation needed, and that a few of them will be a closer match to the metallurgical properties of the item needing to be repaired.
AL-Cor made by Harris flows in the 700-800 degree F range with excellent results...Approx $17.00 for a roll that is 36" long. It sounds like quite a bit for so little, but a little of the AL-Cor goes a long way because it flows so well.
Other higher temp aluminum filler metals that are flux cored would include Aufhauser 1/8"x20" flux cored rods at approx. $50.00 per 2 pound package. Another product by Harris is their CORAL60. This too is 1/8"x32" rods at I believe approx. $55.00 for 3 pounds. I actually prefer the Aufhauser because it seems to flow a little better than the CORAL60. These flux cored aluminum rods/wire are great for those who are not well versed in welding, and often result in strong permanent repairs. I have used all of the above with excellent results, but usually only when I have a serious case of the lazy bones. Normally I prefer the good old tried and true Oxy/Acetylene torch, bare aluminum filler metal, and flux. To me there is something relaxing about gas welding/brazing. So.........pick your filler, and happy aluminum joining.
gathem 10 years ago
Every time I heat aluminum with a torch it warps terribly. Most of the time I am working with 1/8 L stock or 1/8 plate stock.
Any tips for avoiding this?
steam_cannon 10 years ago
Vijaykumar123450 11 years ago
Kevanf1 13 years ago
Excellent 'ible' though, this will come in very useful for aluminium work I have to do.
Kevan
Dr Qui 13 years ago
eBay has the best price by far, sadly i found this out after i had bought from the official dealer
steam_cannon 13 years ago
Unless, that is, I can get set up with aluminium welding on my mig welder.... I ought to have done an Instructable about this I suppose as I've just fitted a Euro torch socket to it.
Ilan Voyager 11 years ago
steam_cannon 11 years ago
What do you call structural? I would not use zinc alloys on structural works where a failure would be catastrophic. The adhesion (if no flux is used) is rather impredictable and zinc itself is a source of worries with galvanic corrosion, specially when in contact with copper or its alloys.
For example on frigorific works tin-silver is preferred. A zinc join would not be reliable because of the possibility of stray currents.
Regarding structural capabilities, it can be used for repairing engine casings which require significant structural strength and vibration resistance. It is used for repairing propellers as well. In my experience working with it, it seems fit for use for structural components such as connecting supportive pipes/bars. Now if it was pure melted zinc, then I would agree that wouldn't work. But the alloy seems to work much better then pure zinc, which I use regularly for metal casting.
Alumiweld (whatever they claim), Aladdin 3, Welco 52 and all that stuff are made basically of an alloy of zinc at 96-97 %, aluminium around 3% and a bit of copper and other metals. This alloy has been known for more than 80 years.
The best proof is all that stuff melt at the same temperature; 490° C, have the same use and solder the same metals. There are no miracles in joining metals.
Whatever the -small- variants in composition it's basically zinc with an electrical potential lower than aluminium. Briefly an anode in case of electro-galvanic corrosion.
The lone true fixing on aluminium propellers and casings is welding mainly with a 4043 or 4047 alloy, but the zinc alloy works in most cases as most of these repairs are not structural (a hole in a casing does not affect its structural integrity, a long crack yes and in this case you have to weld), and are made on not highly stressed small structures.
The great advantage of zinc alloy is the low temp, so it requires a simple torch. The inconveniences are corrosion and sometimes resistance at long term.
The stress performances are not sufficient and reliable enough for structural purposes. By structural I mean a joint able to withstand the stresses, vibration cycles, and corrosion effects of a structure stressed at the maximum possible. You'll never see zinc alloy joints on aluminium boats, planes and even race bicycles.
I almost forgot: 490° C is enough to temper (=soften) heat treatable aluminiums like the 6061. (have you remarked that industrial aluminium ladders are never welded ?)
Anyway I've had some great experiences with Alumniweld and I would recommend it for all sorts of projects. Some more great project ideas:
* Building a light metal frame for a robot
* Building a metal frame for a picture
* Build a roof rack
* Make metal green house shelves
* Make an angled plant hanger
* Make metal toy boats
* Build a fishtank or speaker support.
* Fix a lawn mower wheel bearings or bolts
* Build a small engine support
And "yes" it is a miracle to make basic repairs without spending thousands of dollars and hours of training on the equipment.
All that I wanted to point that zinc alloys cannot be used in stressed structures where a failure could have catastrophic consequences like on a mountain bike, a ladder, or inside an engine. That bothers me to read impossible claims or to see videos of the kind of a guy fixing a crack between the two valves of a car engine...it's simply outside the possibilities of zinc alloy soldering.
Also some prices are simply...let's say puzzling: the Welco 52 can be bought at 10.05 USD a pound...
