Quickly Sharpen a Knife...with a Dremel!
Intro: Quickly Sharpen a Knife...with a Dremel!
Ever needed a knife sharpened really fast? Well you have come to the right Instructable! This Instructable will teach you how to sharpen, and clean up, a knife with a Dremel!
STEP 1: Items Needed
Okay so first off you will need a couple key tools and objects.
Tools:
Tools:
- A Dremel.
- A vice or something to hold the knife while sharpening.
- Some Dremel bits. Part No. 932 -- A Aluminum Oxide Grinding Stone -- Part No. 401 -- Mandrel -- Part No. 414 -- 1/2" Felt Polishing Wheel -- Part No. 421 -- Polishing Compund -- ( Part Nos. 401, 414, and 421 are optional. Only get these if you want to polish your knife.)
- Safety Goggles.
- An old, or new, blunt knife.
STEP 2: Start Your Dremel!
Okay so by now you've found an old blunt knife somewhere. I really don't care how you found it just that you found one, and you've probably gotten those parts or it would really be no use in reading this Instructable...anyways, lets get started.
EDIT: When I cut it at a 25 degree angle the blade wasn't that sharp. So after a few tries I decided to cut the angle down to 10 degrees.
1. You should put the Aluminum Oxide bit in.
2. Put the knife in the vise.
3. Start the Dremel up.
4. Grind away at about a *10* degree angle.
5. Turn it over and grind that side too.
6. On to the buffing!
STEP 3: Optional: Buffing the Knife.
Okay so if you clicked on this step you probably are either curious or want to clean up your knife.
This is where the Parts 414, 401, and 421 come into play.
So...screw the 414 into the 401, then rub some of the compound onto the buffing bit.
Buff away!
Buff away!
STEP 4: Done!
Now you have an extremely sharp knife. Well depending on how good a job you did.
Ideas...
1. You could resell the knife to a friend, for more than you think it's worth. -- Just because of its good condition. --
2. Use it.
3. Give it to someone as a cheep birthday preset.
Remember: Safety First!
-- Taylor G.
Ideas...
2. Use it.
-- Taylor G.
17 Comments
Vorshack 2 years ago
watchmania 8 years ago
Out of focus objects are frutating to look at, aren't they?
tpeters8 7 years ago
useless comments from overly critical neckbeards are frustrating to look at, aren't they?
Marekpyka 5 years ago
No, they are frutating. :)
lonelyBlobby 6 years ago
watchmania 7 years ago
Tronclay 10 years ago
Why would i spend a half hour using my stones to sharpen a small, hard-use blade when i can do everything from redefining to honing and even using makeshift home made strop bits to smooth out my edge and do it all in 5 or 10 minutes and get right back to work? It would take a fair amount of negligence and/or inexperience with a rotary tool to PERMANENTLY destroy a knife with it but that being said it does require more care than using stones and I would certainly recommend practicing a lot on knives you dont care about first, then moving up to your user knives.
P.S. A lot of budget knives (50$ or less, walmart stuff like Buck, Gerber etc..) arent ground out all that well and the factory edges often leave a lot to be desired. Ive reprofiled my fair share of cheaper knives and a dremel does a great job of that as well. Explore the dremel my son, its power will enlighten you.
Desi JR 7 years ago
I would rather learn something from somebody that actually knows what they are doing rather than from somebody just "experimenting". That way I don't make any rookie mistakes that could be easily avoided by not listening to amateurs.
Denger 11 years ago
2 stroke 13 years ago
weaponscollector94 14 years ago
2H2H 15 years ago
N467RX 15 years ago
im_tux 16 years ago
kevinlee 16 years ago
garrettmikesmith 16 years ago
