Rainwater Collection & Distribution System
Intro: Rainwater Collection & Distribution System
This is a custom system I designed to collect the rainwater coming off my roof and have both the ability to store the water and distribute it without attaching any temporary piping. My apologies in advance that I don't have pictures showing the step by step construction - I only discovered this site last night!
STEP 1: Get Your Materials and Tools
It's a pretty simple collection of materials - most of which can be found at your local hardware store. I did a little hunting around to find an appropriate rain barrel - ended up getting one from an eco-store here in Calgary.
Materials:
6 - 2x4 studs (each 8 feet long)
Approximately 100 - 3" long deck screws
55 gallon rain barrel
Sections of 2" central vacuum tubing (could substitute plumbing PVC or ABS pipe, but they cost 2x or 3x the price). Length determined by the distance you need the water to travel - I needed 6 sections.
Assorted couplings, end caps, 90 degree elbows, 2" ball valve, 1 'Y' section, and two threaded adapters to connect into the rain barrel.
2" plastic straps to affix the pipe to fence.
1 10' length of 3" pvc pipe & assorted 3" couplers/elbows
Silicone cauking
Optional stainless steel screws (or substitute the deck screws)
PVC/ABS Glue
'C' shaped straps - number depends on the length of your delivery pipe
Tools:
Power drill
Saw (I used a mitre saw, but a hacksaw would work)
Measuring tape
Level
String
Materials:
Silicone cauking
PVC/ABS Glue
Tools:
Power drill
Measuring tape
Level
String
STEP 2: Build the Stand
I didn't have any set plans, but I knew I wanted to build something that wouldn't fall apart under the weight of the water-filled barrel. A 55 gallon barrel of water weighs over 200 kilograms. Also, if the base sags, the connections will be stressed, so make the base of the legs wide to support the weight.
I built mine out of 2x4's, roughly 2'x2'x2'. The barrel I purchased (side note - these can be obtained quite inexpensively, just make sure what they used to contain wasn't toxic) had a spigot attached, so I had to accommodate that during construction. I had to be careful to make sure the lengths were correct (measure twice cut once), and that the joints were square. Take a bit of extra time and it will stand up much longer.
STEP 3: Prep the Pipe
In this step I prepared the lengths of pipe by drilling a 1/2" hole every foot along the pipe - be sure that they are all in line.
STEP 4: Determine Your Fall Line
I have a 40' section of fence I wanted the pipe to travel, so I put a screw in the fence at the level the water would be exiting the barrel, and then a second screw in the fence where the pipe would end. I then took a string and attached it to both strings to find out what the fall would be from the barrel. From this line I put marks on the fence where I would attach the pipe using the straps.
STEP 5: Attach the Pipes to Fence
I attached the pipes to the fence with some plastic 'C' shaped straps - found them in the electrical section of the hardware store. Then, using the ABS/PVC glue I connected the end cap, and then pipe-to-pipe with couplers - almost all the way back to the barrel.
STEP 6: Plumb the Barrel
This step proved to be a bit more complicated than I expected, mostly because I was using vacuum tubing/connectors on one side, but to connect to the barrel the only pieces I could find were for plumbing. Problem was, they were about 1/16th of an inch smaller than I wanted them to be. So after a bit of cleaning out the inside with a dremel, I was back in business.
I designed this system to be able to store rainwater, but have a spillover pipe that would take any excess into the pipe system and away from the house. This spillover pipe enters the main pipe on the opposite side of the valve (see pictures).
I cut holes in the barrel, as I was concerned that the small spigot wouldn't be able to handle any volume of water. I then attached the plumbing fixtures at the top and bottom and used some silicone caulking to seal the connection. I then measured, cut, and glued the pipes, elbows, and valve assembly.
STEP 7: Connect the Valve Assembly to the Watering Pipe
Pretty straight forward - helps to have a bit of leeway in your watering pipe (the one you drilled holes into). Use couplers if needed and the ABS/PVC glue.
STEP 8: Connect to Your Eavestrough
I did this step a day after I did the other steps, and from one day to the next I learned that the 2" pipe capacity was just barely enough to handle any real volume of water coming from the barrel. So, I opted for a 3" diameter abs pipe to handle the water coming from the roof. It was a little tricky getting the oversized fixture to attach to my aluminum eave, but with some minor modifications I got it to work. Again, I used some silicone caulking to seal the connection.
STEP 9: Test the Connections for Leaks
Finally, if you have a rainstorm nature will do this for you, but if not (as in my case) I used my garden hose. I learned that I had a small leak coming from the eave connection - which I fixed once it dried out using some more caulking.
We haven't had any real rain as of yet, but I anticipate this system working just fine. I have some other rainwater collection and distribution ideas to try out - and will document each step.
Feel free to email me if you have questions: mcrs@mark11.com - let me know if you have suggestions regarding float activated, solar powered pumps that I could attach to another rain barrel to distribute water.
Cheers
Cheers
37 Comments
nancytyler143143 1 year ago
CalebL40 5 years ago
mark11photography 3 years ago
Cheers ;)
mark11photography 9 years ago
Calculation is correct Hugh - or in kilograms (as I'm in Canada and we use the metric system) it's 206.9742kg
Side note: the stand continues to hold strong after 5 years of use and being exposed to the elements. I've revised the design to have the cross boards on top of the supports, which in turn are on top of the legs.
HughWeinrich 9 years ago
55gal (H2O) * 8.3lbs/gal = 456.3 lbs(H2O)
Shooglenifty 10 years ago
I have a feeling that your fence will begin to rot where the holes are made in the piping. Water takes the path of least resistance, hence down along the side of your fence.
mark11photography 10 years ago
Hi Shooglenifty - I had the same concern when I set this project up 4 years ago, but have found no such problems with the design. My experience has shown that rot tends to form when water comes into contact with wood without the drying presence of air. We live in a very dry, not exactly desert, climate on the eastern slopes of the rockies, and don't have much rot issues aside from where the fence boards are in touching the ground.
Thanks for your reply. I live in Ireland and that fence would be firewood by now due to the rain fall we get here. My garden fences need to be painted twice a year here with anti rot woodstain. Spring and then Autumn before the frost. It's a nightmare.
I have several barrels here with more or less the same idea, except i used a hose pipe running from the barrel that was then drilled every 6 or so inches where needed and then laid in my raised beds.
Due to the amount of rainfall here i placed Seaweed and Stinging Nettles into hessian bags or even womens tights / stockings and placed them in the barrels (weighed down with rocks) to give the plants nutrients, it's not really water they need here it nutrients as it rains nearly every day here in the Irish North West.
Glad to hear your Indestructable is still working well after 4 years and your fence is still in top shape.
All the best.
Shooglenifty.
chris73044 12 years ago
Buzzinski 13 years ago
But, setting up a 55 gallon ( 208.20 litres) tank is a bit too small in my opinion. To create a decent storage system to say water an average garden you would need in excess of 1000 litres for 3 month period. New homes built in Queensland since 2005 are mandated to include a minimum 1000 litre rain water tank for no drinking purposes .i i.e. toilet flushing, clothes washing etc.
billbillt 12 years ago
mark11photography 12 years ago
You bet - would be great to ramp up the size of the tank system. The way this is designed, you could really put any size tank you want. Where I live in Canada, there wouldn't really be enough space in my yard to put a system much larger than about 200 gallons. If you do install a similar rig send me/post some shots!!
jdbt 12 years ago
Buzzinski 12 years ago
To start with our rainfall is very sparse over much of Australia so we tend to use purpose built rainwater tanks of large capacity (29,000 litres or 6,500gallons Australian or 7806 gallons US approx) and not worry about using little 200litre barrels.
Please have a look at http://www.gough.com.au/tanks/default.htm or if the link doesn't work look up Gough Plastics in Australia and click on Water Tanks.
Basically we run a length of pvc pipe from the gutters down into the tank and water is drawn from there via gravity feed or electric pump. In remote locations we don't worry too much about filtering the water for human consumption but in large towns and cities you need a filter.
We also use this water for garden use and such things as flushing toilets, washing clothes etc without being filtered.
http://www.savewater.com.au/how-to-save-water/in-the-home/rainwater/rainwater-tank-installation for some information about how to install a rainwater tank.
Hope that helps you out a bit.
Mike
mark11photography 13 years ago
I completely agree with you on the quantity issue. Although this was an initial installation, I have multiple downspouts and have plans to set up similar rigs at the other ones as well. The way I have designed this one is to do most of the watering automatically, or at the very most with the quick turn of a valve. By spring I will have at least two other systems set up to store and distribute rainwater.
I'd love to have a rainwater system that I could use to supply water for other uses in my house, but it's not in the plans for now.
Thanks for the feedback!
Mark
http://www.transport.wa.gov.au/ACT_P_LS_Installing_rainwater_tank.pdf includes some more information about tank sizes etc.
http://www.yourhome.gov.au/technical/fs73.html
An overview of what you need to do to make a complete system including first flush diversion system to keep debris from roof entering rainwater tanks.
Finally Wikipedia http://en.wikipedia.org/wiki/Rainwater_tank which shows a 1,000 litre poly tank on a steel pallet which could be an ideal method of storing rainwater if you can't source an Australian style rainwater tank in the USA.
Hope this points you and others in the right direction.
Reply
flag[delete]
jimihendrix4753 13 years ago
Very simply, the top pipe you see acts as a safety overflow. When the barrel fills to that point, it automatically drains to the free side of the valve and away from the house. One of the reasons I installed this in the first place was to avoid water from the downspout collecting and leaking into my basement. And after two years I can say it works perfectly.
Mark
yokozuna 12 years ago
Eye Poker 13 years ago
http://www.hcn.org/issues/40.18/a-good-idea-2013-if-you-can-get-away-with-it
In Utah, Colorado and Washington, it's illegal to do so unless you go through the difficult -- and often impossible -- process of gaining a state water right. That's because virtually all flowing water in most Western states is already dedicated to someone's use, and state water officials figure that trapping rainwater amounts to impeding that legal right.
