Robotic Paper Octopus (with Micro:bit)
Intro: Robotic Paper Octopus (with Micro:bit)
Make a grumpy paper octopus that retracts its tentacles in reaction to loud noises!
STEP 1: Making the Tentacles
- Cut out a tentacle
- Fold it in half with the template markings on the outside
- Tip: You can save some time by folding the tentacle in half, then cutting the rounded top part
STEP 2: Poke the Holes
- Use a sewing needle to make the holes in the marked locations
- Make sure to go through both layers of paper
STEP 3: Invert the Tentacle
- Fold the tentacle in a zig-zag
- Unfold the tentacle, then refold it inside out so the template markings are on the inside
- You can also leave the template markings on the outside if that's your style!
- Optional: add glue when you fold it in half to hold the two layers together (it's not necessary since it holds its shape pretty well without glue)
STEP 4: Cut and Knot the Thread
- Cut a piece of thread around 12" long
- Double or triple knot the end of the thread
- Thread the needle
STEP 5: Sew the Tentacle
- Use the holes you made in step 2 to sew the thread through the tentacle
- Make sure to start from the rounded end of the tentacle, and on the outside of the zig-zag fold
- Add a drop of glue (or tape) on the knot to make sure it doesn't pull through the paper
- Double check that the knotted end is on the rounded side of the tentacle, and the extra thread is on the opposite side
STEP 6: Make More Tentacles!
- Repeat 7 more times until all 8 tentacles are finished
- Set the legs aside for now to let the glue dry
- Are you regretting making a robot with 8 legs? Just be glad it's not a centipede!
STEP 7: Making the Body
- Cut out the template for the body and top
- Fold the body following the markings on the template
STEP 8: Assemble the Top and Body
- Glue the body into an octagon shape (the two sections on either end should overlap on top of each other to form 8 sides)
- Glue the top on to the tabs
- Tip: I found it easiest to flip the body upside down while I was gluing the tabs in place
STEP 9: Alternative Body
- If you're feeling up to a challenge, you can also make the body using the origami method, which results in the twisty-top on this Octobot
- I used the instructions here to create an Origami Octagonal Box: Origami Octagonal Box
STEP 10: Cut the Base
- Use the base stencil octagon to trace an octagon onto a piece of cardboard
- Cut the base octagon out of cardboard
- The base should be just small enough to fit inside the body (but not so small that there's loads of empty space around it)
STEP 11: Attach the Tentacles
- Glue a tentacle to the bottom of the cardboard base
- Only glue the last folded section of the tentacle (the one without a hole)
- Make sure the thread doesn't accidentally get glued to the cardboard
STEP 12: Add the Other Tentacles
- Repeat for the other 7 tentacles
- Try to keep the threads from getting tangled
STEP 13: Make the Servo Holder
- Cut the servo holder template
- Fold the servo holder
- Glue it around the servo
- You don't need to glue the paper to the servo—just wrap the servo holder around the servo, and glue it where the two parts overlap
STEP 14: Attach the Servo
- Glue the servo holder to the cardboard base of the Octobot
- Note that the servo itself isn't centered on the body—the servo's shaft is what should be approximately centered
STEP 15: Making the Axle
- Cut a piece of straw about 3/4" long
- Use the needle to poke a hole through the straw at about halfway between the top and bottom
- Poke another hole (this one only needs to go through one wall) close to the top of the piece of straw
STEP 16: Check the Straw Size
- Put the straw onto the servo shaft
- Since straws come in all different sizes, it may be too big. If that's the case, put a very small piece of tape around the servo shaft to increase its diameter
- The straw should fit snugly on the shaft
STEP 17: Attach the Thread
- Sew one of the pieces of thread onto the straw
- First go through the middle holes, then up out the top
STEP 18: Do It Again
- Repeat this 7 more times until all 8 pieces of thread are sewn into the straw
- It's best to do this one piece of thread at a time to avoid them getting tangled or twisted
- Check that the length of the thread between the straw and the tentacles is roughly the same
- You can check this by pulling the piece of straw up to check that the threads are all roughly the same tensions
STEP 19: Attach the Axle
- Push the straw to the servo shaft, making sure it's snug (if it's loose, the shaft will just spin inside the straw without turning the straw itself)
- Make sure the tentacle are all fully extended, then tie a big knot where the threads exit from the straw
- Trim the extra thread
STEP 20: Connect the Circuit
- Connect the servo to the Bit Board at Servo Pin 1
STEP 21: Upload the Code
- Upload the code from here: Octobot Code
- You'll note that the sound activation requires touching the logo at the same time. That's to avoid accidentally triggering it if you're in a noisy environment. You can change that by getting rid of the "logo is pressed" block
- The sound trigger requires using the micro:bit v2. If you don't have the v2, there's loads of other ways you can trigger the Octobot, such as using the accelerometer to shake the micro:bit, or making it light-sensitive
STEP 22: Test It
- It's easiest to test the mechanism while the servo is still exposed
- Use the A and B buttons to try retracting and extending the tentacles
- Tip: For the TentacleAction function, try playing around with the timing and speed to get different effects
- Depending on how loose the threads are, you may need to pre-wind the threads around the axle by using the A button before triggering the TentacleAction function
STEP 23: Put the Body On
- Put the body on
- The thread should slide into the thin cutouts in the body
- The servo wire should go through the larger cutout
- Optional: You can add a bit of glue to secure the body to the cardboard base (I didn't in case I wanted to access the inside)
STEP 24: Give It a Face
- Give your Octobot a face!
- Touch the logo and shout "BOO!" to make Octobot retract its tentacles!
13 Comments
Ama_2460 1 year ago
jrflorentine 1 year ago
mahmoud8373 3 years ago
AnandM54 3 years ago
Techhlp 3 years ago
jrflorentine 3 years ago
I 100% agree with you on string--recently on Twitter I've seen people use it to make flapping wings and articulated tentacles!
not.sure.dojo 3 years ago
I may add some LEDs to the eyes. I need to see if I have any RGB LEDs; green for happy, red for angry and blue for calm, I suppose. If I do that, then I suppose I should add another servo to move the eyebrows up/down. Or, I could just build it like it is and not overdo it, lol.
I think a stepper motor should work? The only reason I used a continuous servo was because I only had servos on hand, and I used a continuous one so that the strings had something to wind around.
MuthukumaranK 3 years ago
- Will try to use some polypropylene sheets (regular plastic folders which we can get at stationery shops) for tentacles! They are stiffer and can take multiple cycles of folding / unfolding
- will make the axle attached to servo eccentric so that some tentacles shrink and some tentacles expand for each revolution of servo
sigritom 3 years ago
Penolopy Bulnick 3 years ago
seamster 3 years ago
