Rocket (tape) Laser Decals
Intro: Rocket (tape) Laser Decals
Make graphics decals for your rocket with simple things.
You need a laser printer, packing tape, and a couple of minutes.
This will not work with ink jets, only thermal toner, or indelible ink based products.
STEP 1: Make Some Designs and Print Them !
Print your decal the way you want it to appear .
The white (paper) is removed later so it is clear.
I have found that the worst quality paper makes the best decals.
This only works with thermal - non water soluble printers like a laser printer.
Most copy machines use thermal ink.
STEP 2: Cover With Tape and Press It Down...hard!
In this next step we cover the image with tape.
We need the tape to stick to the color particles.
Rub it down firmly...
I used the flat end of a battery on a hard surface.
After pressing the tape down, trim the decal near the margins.
Note: Where printing covers the surface there will be little glue left to stick to the surface.
If you have a lot of printed area, leave extra border.
STEP 3: Soak It, Rub It, Dry It....
Now soak the decals in warm (hot bath temperature) water for a few minutes.
Get a piece of wax paper ready.
Rub the wet paper on the tape. It will start to come off of the tape.
Keep everything wet. We are not removing the glue just 95% of the paper.
The paper will come off but the image will remain.
When done lay decal on wax paper, sticky side down.
Do not press the decal into the wax!.
STEP 4: Apply the Decal to the Rocket Tube
Lift the decal and stick down to the rocket tube.
Good luck, and happy decorating.
7 Comments
hjameskimble 3 years ago
bomb_ca 4 years ago
bomb_ca 4 years ago
Lego bricker 8 years ago
Big Baneser 9 years ago
The first time I looked it over and I thought I'd need some weird paper along with chemicals. Now that I've read it fully I feel dumb for missing how simple it is. I must see if my school printers work for this.
backwards lamb 11 years ago
mikeasaurus 11 years ago
