Realistic Rubik's Cube Costume
Intro: Realistic Rubik's Cube Costume
This costume aims to look more realistic by creating the illusion that it can twist. This illusion is achieved by the exaggerated clevis between the tiles. Although this subtle detail requires a lot of work, it goes a long way toward making the cube look more realistic. enjoy...
STEP 1: What You'll Need
- Black Duct Tape (Masking tape is ok, but isn't as strong. I don't recommend it)
- Utility Knife (Be Careful!)
- Cardboard Box Approx. 3ft Square
- More cardboard (3/4" thick may be rare, but it gives the best results. You can also use thinned cardboard for the tiles and then stack them up to make them thick [more work])
- Contact paper (White, Yellow, Green Blue, Red, Orange [do the nerds who will see you a favor and DO NOT substitute different colors])
STEP 2: Find a Box
1. Find a Box you can fit it
2. cut holes for your arms and head.
Now it's a party!
Now it's a party!
STEP 3: Find Another Box
I used a different box (about the same size as the first one) made of 3/4" thick cardboard to use for the tiles
you'll need to calculate the size of you tiles based on the size of the base box you start with,
Plan to leave about 1" between tiles. Also, plan to have the edge/corner tiles hang over the edge by the amount of the thickness of your tiles.
You'll need 44 tiles. 9 tiles x 5 sides (none on the bottom) - one full tile missing for the head hole.
after I cut my tiles with a knife I cut off the corners with a band saw to "round" the edges (Optional)
STEP 4: Start Taping
1. I recommend Taping two tiles together, then taping them to the box. that way they look like two faces on a sub-cube.
2. Same idea for the 'Corner pieces', tape 3 tiles together, then tape that 'partial cube' to the box.
NOTE: You may want to make the hole big enough for your head, but then have the top tiles hinge down to fit around your neck so you don't have extra space all the time.
STEP 5: Coloring Time
1. cut out oversized squares of contact paper
2. attach them to the tiles
if you can, model the pattern from a real cube, you'll impress the nerds (only a true nerd will ask you if it is a solvable configuration).
NOTE: The configuration I made is not solvable (Lame! I know), I ran out of the correct colors. Next time...
then cut off the excess contact paper and marvel at your work
STEP 6: Win Best Costume
Have fun with your costume
let your friends try it on
use it as a coffee table until next Halloween!
32 Comments
mrcrap 6 years ago
follow me on instagram mr.pig_17
ArjunD 9 years ago
Nice!
mkovacs1 12 years ago
designerd 12 years ago
majorson 12 years ago
instructable as well:
https://www.instructables.com/id/How-to-solve-a-Rubiks-Cube-for-the-first-time/
RubixCubeFTW 12 years ago
My only question atm is the colorful tiles. Why do you have to cut them oversized? Did you add MORE tape once they were on the box?
I was wondering if it would work by just cutting the colorful 'squares' as big as the tiles are, and gluing them on. Wouldnt that be easier?
mfinn3 13 years ago
It is not very important whether you color the tiles first then attach them, or color them after they've been attached. I applied the colored contact paper after the tiles were attached because i wanted to model it after a realistic cube pattern, but wasn't organized enough to plan it ahead (this was a October 30th project)
hope that's helpful
mcontreras3 12 years ago
kt004 12 years ago
donotreg 13 years ago
is the bottom ( the part where my feet stick out ) supposed to be cut off?
designerd 13 years ago
Andrew Ryan 14 years ago
heres a pic of me wearing the cube.
i1014.photobucket.com/albums/af261/Prankster369/IMG_0270.jpg
designerd 14 years ago
