HANDPOWERED SERVO TORCH
Intro: HANDPOWERED SERVO TORCH
In this instuctable ill show how to make handpowered led torch from servo motor
The basic principle behind this project is servo acting as a generator when given mechanical rotation which is similar to bicycle dynamo
Bonus Tip : For Best and Free Project ideas check www.letsmakeprojects.com
STEP 1: Materials Required
servo motor
small cube with lid
led
super glue
STEP 2: Fixing the Led
make a hole on the cube so as to hold the led and passage of wire
STEP 3: Servo Connections to Led
servo is connected to led by the 2 terminals present in both ledand servo motor
connect the led to servo and just give a check by rotating the motor shaft clockwise and anticlockwise
STEP 4: Gluing Up
using super glue base of servo is attached to back side of cube
12 Comments
RANDOM KNOWLEDGE 7 years ago
sorry nice try bit no.1 you kill the led verry soon.
2 its a flash not a constand light
3 to smal to handle
i would put 1 item on it : Z -- you see here the letter Z, thats our paperclip bend it almost like that but with a Vertical LINE not scuare. put a piese of tubing on the side you turn the led on and you can CONTINU have light. (but place a resistor of 500 Ohm and see how bright it is then go lower in Ohm`s by 100ohm every time (not lower then 200\300ohms
ROBO HUB 7 years ago
and dont get me wrong friend,
its amazing in its simplicity and looks,but the name was what me akted to respond.
as i say ,nice
rafununu 7 years ago
When your Led will burn (soon), add a resistor to the new one, it will last much longer !
ya sure ill try it out
anyway thanks for ur suggestion..
khabarnaak 7 years ago
Let me collect these materials. Then i will do next things.
good...go ahead
I will try it again later. Thanks for such nice tutorial.
OK i got it.
mikenaly 7 years ago
