Save 368 Billion Gallons of H20 Per Year
Intro: Save 368 Billion Gallons of H20 Per Year
use waste water to flush your toilet
2007 estimate f households:
111,162,259
(http://www.census.gov/population/projections/nation/hh-fam/table1n.txt)
average annual household water use:
127,400 gallons
percentage used for toilets:
26.7% = 33,124 gallons per household per year
(http://www.toiletabcs.com/toilet-water-conservation.html)
Sooooo,....
33,124 * 111,162,259 = 368,213,866,716 = 368 billion gallons per year saved by using this method if everyone in the US does it.
overview if video not working:
put a bucket over your bath tub drain so that while you take a shower it will fill with water splashing off of you.
when full set bucket aside and use the water to flush your toilet by pouring the water directly over the toilet drain til everythings flushed away.
You can do this using a very small amount of water from the bucket if you aim right and hold it high enough (the force of the water falling into the drain sucks everything away).
111,162,259
127,400 gallons
Sooooo,....
24 Comments
ElSergio 13 years ago
I don't mean to be condescending, I just really don't get it.
leevonk 13 years ago
2) it takes a lot of energy to desalinate water, energy costs money and creates pollution.
3) it is impossible to pump desalinated water from the oceans to all inland inhabited areas over tens of thousands of miles in the quantities needed (for farming, drinking, livestock, washing, toilets, etc). This would require immense new infrastructures.
4) things other than humans need water too, if we drain all local water and then start desalinating and pumping new water inland for only ourselves this would still be a problem for the 'natural surroundings".
5) probably other reasons too, those are just off the top of my head..
pddonovan2011 10 years ago
Desalinated water! Hmm. The only way to desalinate water is Reverse Osmosis. Reverse osmosis is a cold distilling process, not as pure as heat distillation but you still have water that is only wet, there are no minerals it it, 99.97% pure! A 4' cubic gravel pit, on the side of your home, filters out the large impurities that are in rain water from your roof top. When the filter fills with too much debris, you back-flush the debris out and continue to filter from that time one. The water in your cistern (3000 to 5000 gallons!) is now clean enough to use a Hospital Grade filter, with Infra-Red, to clean-up the water and make great drinking water. The rest is used for your yard and flushing toilets. City water should be for back-up when your cistern runs dry. THEN, YOU are managing YOUR water supply correctly! Desalinating water is not the answer, it is a stop-gap attempt to supply water to people not smart enough to gather what is available, to the individual home, for free! It also fills some ones (someone elses!) pocket and supports ignorance. Gather your own water, leave Mother Nature to her own designs, stop feeding 'The Machine!' The energy needed to pump water for desalination is huge, add into that fact that, here in the SFBA, we use drinking water to make electricity and you soon see the oxymoron of desalinated water.
Okay, I can handle this one. Sure, the Planet is 70% water but only 11% of that is drinking water and 8% of that is in our glaciers. The glaciers are thawing and disappearing. Hear in California we are starting Spring with 30% of the water needed for daily consumption. Hetch Hetchy, our primary source of water for the SFBA not only supplies drinking water, they use it to make electricity aw well. As a Nation the united States uses the most of everything. #1 customer for Saudi Arabian oil, we create 40% of the Planets Waste and use 45% of the resources available world wide. Every year there are stories in the news about how someone got caught-up by a sudden torrential down pour of rain and they are swept down a flood control ditch and need to be rescued. But everyone seems to miss the big picture. The 'victim' is floating down a man-made aqueduct and all that Fresh Rain Water is going out to sea. In the Sierra's there is a lake, Mono Lake, which was once a Sportsman's Paradise. Fishing, Boating, Skiing it had it all, then some moron said, "The LA basin needs that water, Mother nature will make more, all that Snow will refill it but the L.A. Basin needs it now!" The built the Aqueduct, the took the water, and the lake has not filled yet, decades later. Hetch Hecthy was once a beautiful valley that rivaled Yosemite. Up went the damn, the valley is under water and the SFBA has their water AND they make electricity also for the SFBA. Problem, when this all happened there were only 10 million people in the SFBA, to day their are 37 million and that number is down from what was 43 million. The water and electricity infrastructure has NOT been upgraded to adapt to the population growth. They just work the generators harder and pump the water faster, the water for 10 million people to 37 million people. There just isn't enough water. If the weather goes dry and there isn't enough snow fall, there isn't enough water because we use it for drinking AND watering our precious gardens AND making electricity. So what happens, "Water? You want Water? Well, you're going to have to CONSERVE the water we have or there won't be enough!?" I have been in California all my 57 years, there was a time when a drought was a 'worry!' Today, thanks to population growth, irresponsible water consumption, water district miss management, and the rape of the California Farmers, not to mention DECADES of non conservation. we are in a near state of emergency where water is concerned!
That;s the bad News!
Today, if EVERYONE gets with the program, we can make do with the water we have. BUT, we will need to filter it because it is polluted, to some degree, and we do NOTHING to keep what falls from the sky! It is all about, "Dangit! It's raining again, did I bring in the patio furniture? Darn, did I clean-out the rain gutters"
When it should be, "It's Raining, COOL! Gonna fill my back-up water supply, flush the under ground aquifer, add to the snow pack and I'll just have to slow down a little on my way to work."
I hope I enlightened you!
How to 'save' water!
When I was young, my Father had a near terminal genetic disposition, we called it the 'Cheap Gene!' THEN it seemed like he was just being a cheapskate, today his methods should be considered pure Genius where Saving Money and our planet, is concerned. Sticking with saving water/money! Here is how it worked. Two half gallon containers, in the toilets, saved a gallon every flush. Flushing only '#2s' and not '#1s', saved an entire toilet flush every time! Showering over a five gallon bucket, for flushing the toilet, reused water and again. Two 55 gallon drums, with faucets welded at the bottom, placed on a sturdy 3' tall 2X4 frame caught water from the Washing Machine, we used zero phosphate detergent and very little earth friendly water softener. Used the 'gray water' for watering the vegetable garden. Two 3000 gallon cisterns captured rain water and we rarely used 'city water' for the garden/landscaping.
That's water, now for home energy! Triple window coverings, pull shades, shears AND curtains, provide great insulation from cold winter days/nights and super hot Summer Days. When the technology became available, we were the first to get insulating foam pumped into the walls and fire retardant fortified cellulose insulation (Recycled Newspapers) blown into the attic, 12 inches thick. The house stayed cool all day and warm all night. On the coldest days, we would run the heater, for half an hour and it would shut-off before the half hour ended. The house stayed warm all night and cooled enough to stay cool on the hottest days. Our house never had A/C.
Food costs. We bought and super insulated, a 32 cubic foot freezer. We packed home grown food, into half gallon milk jugs and stacked them close to each other and always had fresh-frozen food all year long. Blew Relatives minds when we had fresh Corn-on-the-Cob for Christmas Diner. The lowest space in the Freezer was a huge basket, we bought four day old bread, from the Bakery Thrift Store, a dozen Loaves every time. I remember going to the store, with my Mother, and we would buy meat, milk, eggs and the stuff for cleaning. For the weekend we would buy Salad makings, enough for two days, because Lettuce doesn't keep fresh for very long and require too much room to grow fresh. Everything else came from the Backyard Garden. We grew five fruit trees and rotated crops every year and returned the 'leavings' back to the ground. Read that as, 'Dig a ditch, bury the corn stalks, bean vines, tomato plants, you know, the 'Leavings' which rotted all winter long. The next spring we dig them up, spread them with compost and manure around the yard and till the ground smooth for planting. Prior to these practices, we spent two summers preparing the ground. Every day for an entire summer I would come home from summer school and grab the shovel. Dig the ground and remove the shovel full and grind it through a home made screed. Thus removing the rocks from the soil, a 4' X 4' area every day, BOY did I get in shape that summer! We were green, ecologically responsible, Hobby Farmers before it was 'trendy!'
There are draw backs to this practice. To this day I can't eat a store bought tomato, they taste terrible to me and make me a little sick. I travel forty miles into the California valley to buy fresh picked strawberries so they don't disappoint as well. The 'wood' they sell as Peaches, Plums and Nectarines are indicative of the destruction of our farm lands in this nation. I am saddened and thankful that I am old enough to look forward to dieing before the total economic collapse of this nation. I see it every day in the cost of life. The house my parents paid $32,500.00 for, in 1968. Sold recently for $1,200,000.00 and the cost goes up every year. When I retire I plan to go to Arizona and build an Earth Ship over a fall out shelter next to a 5000 gallon cistern and hope I die from old age and not the stupidity of man kind. If every household put a 4000 gallon cistern into the ground for capturing their rain water, California would become the single largest water storage entity on the planet. We would never hear about 'drought anything' again.
The current mind set is to sacrifice your health in pursuit of your wealth, then use your wealth to regain your health. Imagine the human potential for greatness of everyone had practiced responsible ecological land management all the passed century. Today the economic demise of this Nation would not be possible let alone inevitable. The fat, lazy, couch potato children would not exist because, as did I, they would have learned the value of maintaining the 'Family Garden Plot' and worked as hard as I did (Starting at age 10!) to insure healthy nutrition for the entire family. Add the 'Barter and Trade' formality to that equation and you have the makings for a very healthy, strong nation of people. Too bad, too late and too far gone. So sad!
It is time for everyone to take responsibility for their future This is one great way to start, keep it up, expand it, educate those around you, make the commitment.
GenAap 13 years ago
WhiteGrub 15 years ago
leevonk 15 years ago
dillio121 13 years ago
lovegroove 14 years ago
leevonk 14 years ago
http://www.youtube.com/watch?v=l31MSpojWTA
remix as heard in video:
http://www.youtube.com/watch?v=PtsErVLpy0k&feature=related
extrordinary1 15 years ago
We dug another well, 7 ft by 14 ft. This well had a separate pump in our basement and in the well itself. The one in the well was used to water the garden. Here's where it gets interesting.
I designed a forced air system to force the warm/hot humid air into the well and let it condensate from the cooler temperature inside being below the dewpoint. Here we have humidity between 80-100% in the summer, especially in droughts. A 2 inch dia. PVC pipe 20 ft long set in the ground, without forced air will strip 1100 gallons of water a day at 50% humidity. The pump inside the well made sure it never got within 6 ft of the top to allow room for the forced air to condense. A pipe with 3/4 inch holes in it for drainage, was used to vent the forced air. A vented shed covered the well.
This became our laundry water, shower water, and toilet water. In the winter we didn't get much water and had to use what we hauled in most of the time. Not enough humidity and the dewpoint simply didn't exist unless it snowed.
We began to also drain our gutter water into that well when it rained, We also dumped snow into it if there was enough to deal with, to help keep the water cold and the ground so that when warmer weather came, it was cool enough to condense the humidity. We later dug another well to take the overflow so we reduced our demand to haul water even more.
You've got a good idea here and every little bit helps when we work collectively to achieve things like this. No matter how big or small your savings create. When we moved into town, we dug a 4 ft by 30 ft well, when the cops tried to give us a ticket during a watering ban and we were watering the garden, we showed them the entire system and that it was not connected to the city water at all. No ticket resulted.
dtc989 14 years ago
extrordinary1 14 years ago
dtc989 14 years ago
Sandisk1duo 15 years ago
jillg 15 years ago
higgrobot 15 years ago
