Screw Lock
Intro: Screw Lock
Problem: "to have a screw losse"... :-)
Solution: Two component glue.
STEP 1: Material
Two component glue
Note: Glue is here already mixed up. Only about 1cm is needed.
STEP 2: Do It
So put some glue around the screw.
You can also see the bicycle pedal.
The problem was, that the screw on the bicycle pedal alway opened by itself. After ride the bicycle for a while, the screw was open.
I know there is a special like oil fixing screw or the like. But this did not helped that much.
WARNING: You should only use this method with the two component glue on parts of the bicycle which is not critical to damage something or somewhere which it can be VERY DANGEROUS if it breaks!
10 Comments
Helmut118 16 years ago
smokehill 16 years ago
gmichaelt 17 years ago
michaelk42 17 years ago
Aside from the crank hole getting deformed by being pedaled loose, have you been making sure to torque the bolt down hard enough? Park Tool has a list (at the bottom) and it can range from 300-480 in.-lb.!
Torque specs
sam 17 years ago
ironsmiter 17 years ago
s666666666666 17 years ago
trebuchet03 17 years ago
GreenDay 17 years ago
michi 17 years ago
