Send and Receive MIDI With Arduino
Intro: Send and Receive MIDI With Arduino
This instructable will show you how to use an Arduino to send and receive a variety of MIDI messages so you can start building your own MIDI controllers and instruments. First I'll talk a little bit about MIDI protocol, if you're just looking for sample code skip ahead to steps 5-9.
If you know absolutely nothing about MIDI note, velocity, and pitchbend or are confused about what MIDI does and why you would want to use it, check out my What is MIDI? instructable.
STEP 1: Bytes and Bits
To understand MIDI communication, you have to understand a little about bytes and bits. A byte is a packet of data used to store information. In MIDI protocol, each byte is made up of 8 bits; bits can only equal to 0 or 1. A sample byte is given below:
11010111
Each 1 or 0 in this byte is a bit. The leftmost bit is called the most significant bit (or MSB) and the rightmost bit is called the least significant bit (or LSB).
Bytes of the form above are binary numbers because they are expressed using only 1's and 0's. We can convert this number to base ten as well:
11010111 in binary (base 2) = 215 in decimal (base 10)
If you need help converting numbers from binary to decimal or vice versa check out Wolfram Alpha. Type in a binary number followed with "from binary to decimal" to get the decimal equivalent. Wolfram Alpha is also great for converting to and from hexadecimal.
Wikipedia is a good resource for more information about bytes and binary.
STEP 2: A Bit About MIDI Protocol
A really basic overview of MIDI terms and concepts is given here.
MIDI messages are comprised of two components: commands and data bytes. The command byte tells the MIDI instrument what type of message is being sent and the subsequent data byte(s) store the actual data. For example a command byte might tell a MIDI instrument that it going to send information about pitchbend, and the data byte describes how much pitchbend.
MIDI data bytes range from 0 to 127. Convert these numbers to binary and we see they range from 00000000 to 01111111, the important thing to notice here is that they always start with a 0 as the most significant bit (MSB). MIDI command bytes range from 128 to 255, or 1000000 to 11111111 in binary. Unlike data bytes, MIDI command bytes always start with a 1 as the MSB. This MSB is how a MIDI instrument differentiates between a command byte and a data byte.
MIDI commands are further broken down by the following system:
The first half of the MIDI command byte (the three bits following the MSB) sets the type of command. More info about the meaning on each of these commands is here.
10000000 = note off
10010000 = note on
10100000 = aftertouch
10110000 = continuous controller
11000000 = patch change
11010000 = channel pressure
11100000 = pitch bend
11110000 = non-musical commands
The last half of the command byte sets the MIDI channel. All the bytes listed above would be in channel 0, command bytes ending in 0001 would be for MIDI channel 1, and so on.
All MIDI messages start with a command byte, some messages contain one data byte, others contain two or more (see image above). For example, a note on command byte is followed by two data bytes: note and velocity.
I'm going to explain how to use note on, note off, velocity, and pitchbend in this instructable, since these are the most commonly used commands. I'm sure you will be able to infer how to set up the others by the end of this.
STEP 3: Send MIDI Messages With Arduino- Hardware
Parts List:
MIDI connector Digikey CP-2350-ND
220Ohm 1/4watt resistor Digikey CF14JT220RCT-ND
Other Parts
(1x) Arduino Uno Amazon
(1x) usb cable Amazon
(1x) breadboard (this one comes with jumper wires) Amazon
(1x) jumper wires Amazon
(1x) MIDI to USB Cable Amazon
Following the schematic above, solder a 220Ohm resistor to MIDI pin 4. Connect ground to MIDI pin 2 and 5V to MIDI pin 5. If the pin numbering is unclear, refer to the pictures above.
STEP 4: Plug in MIDI Out
Connect the MIDI socket to a MIDI cable and plug the other end of the cable into your MIDI instrument of choice. I used a MIDI to USB cable and connected to my computer.
STEP 5: Software Solution: Serial to MIDI Application
You can bypass the MIDI adapter setup from the last two steps by using the Ardiuno's USB connection to send Serial messages to your computer, then run an app like Hairless MIDI to convert this the Serial messages to MIDI and route them to other applications on your computer (Ableton, Garageband, etc). The only difference in the code is that you will need to set the baud rate of your Serial connection to something that Hairless MIDI will accept, so be sure that the number in this line in the Arduino's setup() function:
Serial.begin(31250);
is the same number specified under Hairless MIDI >> Preferences >> Baud Rate (I used 9600, see the image above, I had to replace line Serial.begin(31250) with Serial.begin(9600) in all the example Arduino sketches in this instructable). Normally when you create MIDI with a MIDI connector you need to set the baud rate to 31250, but if you're connecting via USB to a Serial to MIDI application, you can use whatever baud rate you like.
To use Hairless MIDI you will need to select your board (something like usbmodemfd121) from the Serial Port menu and select the MIDI channel that you would like to send or receive MIDI to/from. Make sure you have the same MIDI channel selected in the preferences of whatever other MIDI applications you are running on your computer.
Another thing to be aware of is that you cannot program the Arduino while it is connected to Hairless MIDI, because the port is occupied (see the error in the second image). A quick way to bypass this without needing to quit Hairless MIDI each time you want to change your code is to select a different Serial Port from the Hairless MIDI interface, upload your new Arduino code, and then set the Serial Port in Hairless MIDI back to the correct one.
STEP 6: Basic Note On, Note Off With Arduino
This code sends MIDI messages out Arduino digital pin 1 using note on and note off commands.
As I explained in step 3, the MIDI commands for note on and note off are as follows:
noteON = 10010000 = 144
noteOFF = 10000000 = 128
Both of these commands are followed by two more bytes to make a complete MIDI message, the first is note and the second is velocity (for more info about what "note" and "velocity" mean check out my introductory MIDI instructable). Note and velocity can range from 0 to 127. In this example I used notes ranging from 50 to 69 (D3 to A4):
for (int note=50;note<70;note++){}
and I set the velocity to 100:
int velocity = 100;
So when the function MIDImessage() is called in the loop() of the arduino sketch, it sends the three bytes:
Serial.write(command);
Serial.write(MIDInote);
Serial.write(MIDIvelocity);
if the "command" in the MIDImessage() function is noteON then the note will start, if it is noteOFF the note will stop.
The code below plays the notes D3-A4 in a loop, it turns on a MIDI note for 300ms then wait 200ms before turning on the next note. I wrote a MaxMSP patch (you can download the runtime version for free) that displays the incoming MIDI messages and attached it below. Here is an example video:
<pre>/* MIDI On/Off Messages By Amanda Ghassaei July 2012 https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/ * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, or * (at your option) any later version. */ int velocity = 100;//velocity of MIDI notes, must be between 0 and 127 //higher velocity usually makes MIDI instruments louder int noteON = 144;//144 = 10010000 in binary, note on command int noteOFF = 128;//128 = 10000000 in binary, note off command void setup() { // Set MIDI baud rate: Serial.begin(31250); } void loop() { for (int note=50;note<70;note++) {//from note 50 (D3) to note 69 (A4) MIDImessage(noteON, note, velocity);//turn note on delay(300);//hold note for 300ms MIDImessage(noteOFF, note, velocity);//turn note off delay(200);//wait 200ms until triggering next note } } //send MIDI message void MIDImessage(int command, int MIDInote, int MIDIvelocity) { Serial.write(command);//send note on or note off command Serial.write(MIDInote);//send pitch data Serial.write(MIDIvelocity);//send velocity data }
STEP 7: Note Off With 0 Velocity
You may have noticed in the previous step's video, that the velocity appeared to set back to 0 when the note off message was sent. This is because a MIDI message with a note on command and velocity 0 is the same as a note off message. Sometimes when a software MIDI environment receives a note off message it will automatically translate it into a note on message with velocity 0 because they are the same. You will probably find that it is easier to program MIDI by sending these note on/velocity=0 messages rather than sending note off.
The code below does the exact same thing as the code in the last step, but it only uses note on commands. Essentially, I've replaced the following line:
with:
MIDImessage(noteON, note, 0);
<pre>/* MIDI On Messages with 0 velocity By Amanda Ghassaei July 2012 https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/ * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, or * (at your option) any later version. */ int velocity = 100;//velocity of MIDI notes, must be between 0 and 127 //(higher velocity usually makes MIDI instruments louder) int noteON = 144;//144 = 10010000 in binary, note on command void setup() { // Set MIDI baud rate: Serial.begin(31250); } void loop() { for (int note=50;note<70;note++) {//from note 50 (D3) to note 69 (A4) MIDImessage(noteON, note, velocity);//turn note on delay(300);//hold note for 300ms MIDImessage(noteON, note, 0);//turn note off delay(200);//wait 200ms until triggering next note } } //send MIDI message void MIDImessage(int command, int MIDInote, int MIDIvelocity) { Serial.write(command);//send note on or note off command Serial.write(MIDInote);//send pitch data Serial.write(MIDIvelocity);//send velocity data }
STEP 8: Variable Velocity and Arduino
In this code I've modified the variable velocity so that it increases with increasing note number. In the beginning of the loop() function the variable velocity is set to 20, then it is increased by five in each iteration of the for loop:
velocity += 5;
so for note = 50, velocity = 20, then for note = 51, velocity = 25, then for note = 52, velocity = 30... and so on.
once the end of the loop() function is reached, the velocity is reset back to 20.
Here's a video of the end result, notice how the volume increases with increasing velocity.
<pre>/* MIDI note on messages with variable velocity By Amanda Ghassaei July 2012 https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/ * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, or * (at your option) any later version. */ int noteON = 144;//144 = 10010000 in binary, note on command void setup() { // Set MIDI baud rate: Serial.begin(31250); } void loop() { int velocity = 20;//set velocity to 20 for (int note=50;note<70;note++) {//from note 50 (D3) to note 69 (A4) MIDImessage(noteON, note, velocity);//turn note on delay(300);//hold note for 300ms MIDImessage(noteON, note, 0);//turn note off delay(200);//wait 200ms until triggering next note velocity += 5;//ad 5 to current velocity value } } //send MIDI message void MIDImessage(int command, int MIDInote, int MIDIvelocity) { Serial.write(command);//send note on or note off command Serial.write(MIDInote);//send pitch data Serial.write(MIDIvelocity);//send velocity data }
STEP 9: Pitchbend and Arduino
Now that you know how to control note on and note off, you can try pitchbend.
Pitchbend information is stored in 2 data bytes, and most significant byte (MSB) and a least significant byte (LSB). Each of these bytes contains only 7 bits of information. This means that all pitchbend information is stored in 14 bits, with the most significant 7 bits stored in the MSB and the least significant 7 bits stored in the LSB.
For most applications you will only find yourself changing pitchbend via the MSB and just setting the LSB to 0. In this case you have 7 bits of resolution for pitchbend (128 steps). In MIDI protocol pitchbend = 64 is no pitchbend, pitchbend greater than 64 is pitchbends the frequency up, and less than 64 pitchbends the frequency down.
In the example below a note played and held, then played again while the pitchbend increments from 64 to its max value of 127, then played a third time while the pitchbend increments from 64 to its min value of 0. This sequence is looped forever. The images above show the output in ableton from this Arduino sketch.
<pre>/* MIDI Pitchbend (msb) By Amanda Ghassaei July 2012 https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/ * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, or * (at your option) any later version. */ int noteON = 144;//144 = 10010000 in binary, note on command //noteON data storage: int note = 60;//middle c int velocity = 100;//velocity of MIDI notes, must be between 0 and 127 //(higher velocity usually makes MIDI instruments louder) int pitchbend = 224;//224 = 11100000 in binary, pitchbend command //pitchbend data storage: int lsb = 0;//least siginificant bit of pitchbend message int msb = 0;//most significant bit of pitchbend message void setup() { // Set MIDI baud rate: Serial.begin(31250); } void loop() { //first play note w/o pitchbend MIDImessage(pitchbend, 0, 64);//reset pitchbend to 0 (zero pitchbend is lsb = 0, msb = 64) MIDImessage(noteON, note, velocity);//turn note on delay(700);//sustain note MIDImessage(noteON, note, 0);//turn note off delay(500);//wait 500ms until triggering next note //then play with pitchbend up MIDImessage(pitchbend, 0, 64);//reset pitchbend to 0 (zero pitchbend is lsb = 0, msb = 64) MIDImessage(noteON, note, velocity);//turn note on for (msb=64;msb<=127;msb++){//increase pitchbend msb 64 (no pitchbend) to 127 MIDImessage(pitchbend, lsb, msb);//send pitchbend message delay(10); } MIDImessage(noteON, note, 0);//turn note off delay(500);//wait 500ms until triggering next note //then play with pitchbend down MIDImessage(pitchbend, 0, 64);//reset pitchbend to 0 (zero pitchbend is lsb = 0, msb = 64) MIDImessage(noteON, note, velocity);//turn note on for (msb=64;msb>=0;msb--){//decrease pitchbend msb from 64 (no pitchbend) to 0; MIDImessage(pitchbend, lsb, msb);//send pitchbend message delay(10); } MIDImessage(noteON, note, 0);//turn note off delay(500);//wait 200ms until triggering next note } //send MIDI message void MIDImessage(int command, int data1, int data2) { Serial.write(command);//send command byte Serial.write(data1);//send data byte #1 Serial.write(data2);//send data byte #2 }
Below is a video demonstration of the code above. For this piece of code, pitchbend will be most noticeable in instruments with a long sustain, such as a string instrument, keep that in mind when testing the code for yourself.
You will most likely be fine using only 128 steps of pitchbend resolution, but in case you must use all 16384 steps, see the code below. Basically what I've done here is defined a variable called pitchbendVal, which varies from 0 to 16383. As I said below the "zero" pitchbend value is msb = 64 and lsb = 0. In binary this is:
MSB = 64 = 01000000
LSB = 0 = 0000000
(remember MSB and LSB are 7 bit numbers)
putting these values together we get:
1000000 0000000
MSB LSB
or
10000000000000
which translates to 8192 in decimal
so now the "zero" pitchbend value is 8192.
You'll also notice I had to break the variable pitchbendVal into two 7 bit parts to send out via MIDI message:MIDImessage(pitchbend, (pitchbendVal&127), (pitchbendVal>>7));
the first part, pitchbendVal&127, returns the least significant 7 bits of pitchbendVal
the second part, pitchbendVal>>7, returns the most significant 7 bits of pitchbendVal
see & and >> on the Arduino reference page for more info.
<pre>/* MIDI Pitchbend (full resolution) By Amanda Ghassaei July 2012 https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/ * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, or * (at your option) any later version. */ int noteON = 144;//144 = 10010000 in binary, note on command //noteON data storage: int note = 60;//middle c int velocity = 100;//velocity of MIDI notes, must be between 0 and 127 //(higher velocity usually makes MIDI instruments louder) int pitchbend = 224;//224 = 11100000 in binary, pitchbend command //pitchbend data storage: int pitchbendVal = 8192;//value between 0 and 16383. zero pitchbend = 8192 void setup() { // Set MIDI baud rate: Serial.begin(31250); } void loop() { //first play note w/o pitchbend pitchbendVal = 8192;//reset pitchbend to "0" (zero pitchbend is pitchbendVal = 8192) MIDImessage(pitchbend, (pitchbendVal&127), (pitchbendVal>>7));//send pitchbend message MIDImessage(noteON, note, velocity);//turn note on delay(700);//sustain note MIDImessage(noteON, note, 0);//turn note off delay(500);//wait 500ms until triggering next note //then play with pitchbend up pitchbendVal = 8192;//reset pitchbend to "0" (zero pitchbend is pitchbendVal = 8192) MIDImessage(pitchbend, (pitchbendVal&127), (pitchbendVal>>7));//send pitchbend message MIDImessage(noteON, note, velocity);//turn note on for (pitchbendVal=8192;pitchbendVal<16384;pitchbendVal++){//increase pitchbend from 8192 to 16383 MIDImessage(pitchbend, (pitchbendVal&127), (pitchbendVal>>7));//send pitchbend message delay(1); } MIDImessage(noteON, note, 0);//turn note off delay(500);//wait 500ms until triggering next note //then play with pitchbend down pitchbendVal = 8192;//reset pitchbend to "0" (zero pitchbend is pitchbendVal = 8192) MIDImessage(pitchbend, (pitchbendVal&127), (pitchbendVal>>7));//send pitchbend message MIDImessage(noteON, note, velocity);//turn note on for (pitchbendVal=8192;pitchbendVal>=0;pitchbendVal--){//decrease pitchbend 8192 to 0; MIDImessage(pitchbend, (pitchbendVal&127), (pitchbendVal>>7));//send pitchbend message delay(1); } MIDImessage(noteON, note, 0);//turn note off delay(500);//wait 500ms until triggering next note } //send MIDI message void MIDImessage(int command, int data1, int data2) { Serial.write(command);//send command byte Serial.write(data1);//send data byte #1 Serial.write(data2);//send data byte #2 }
STEP 10: Receive MIDI Messages With Arduino
Most Arduino MIDI projects send MIDI messages out, but you can also use the Arduino to receive MIDI data. Here are some ideas:
an Arduino synthesizer that uses MIDI messages to construct audio waveforms
a device which uses MIDI to trigger mechanical events, like the ringing of different sized bells
a MIDI to control voltage(CV) device- communication between MIDI and analog synthesizers
Parts List:
1N4148 diode Digikey1N4148-TAPCT-ND
10kOhm 1/4watt resistor Digikey CF14JT10K0CT-ND
470 Ohm 1/4watt resistor Digikey CF14JT470RCT-ND (I used 2x220 instead)
6N138 optocoupler Digikey 751-1263-5-ND
Other Parts
The hardware setup is slightly more complicated for receiving MIDI than it is for sending. As you can see in the schematic above, you have to set up an optoisolator in between the MIDI jack and the Arduino. If you are confused about the MIDI pin connections, refer to fig 1. I set this circuit up on a breadboard in figs 4 and 5.
The following code receives these messages, reads them, and stores them appropriately. See the comments for more information.<pre>/*Receive Midi By Amanda Ghassaei July 2012 <a href="https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/"> https://www.instructables.com/id/Send-and-Receive-...> * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, or * (at your option) any later version. */ byte commandByte; byte noteByte; byte velocityByte; void setup(){ Serial.begin(31250); } void checkMIDI(){ do{ if (Serial.available()){ commandByte = Serial.read();//read first byte noteByte = Serial.read();//read next byte velocityByte = Serial.read();//read final byte } } while (Serial.available() > 2);//when at least three bytes available } void loop(){ checkMIDI(); }To make sure that everything is working properly, try the code below. This code turns the led at pin 13 on briefly when it receives a note on message for MIDI note 60 (middle C). Notice how I included "&& velocityByte>0" in the if statement- this makes sure that we are dealing with a note on statement, if you don't include this the light will blink for both note on and note on with velocity = 0 (note off) messages.
<pre>/*Receive MIDI and check if note = 60 By Amanda Ghassaei July 2012 <a href="https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/"> https://www.instructables.com/id/Send-and-Receive-...> * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, or * (at your option) any later version. */ byte commandByte; byte noteByte; byte velocityByte; byte noteOn = 144; //light up led at pin 13 when receiving noteON message with note = 60 void setup(){ Serial.begin(31250); pinMode(13,OUTPUT); digitalWrite(13,LOW); } void checkMIDI(){ do{ if (Serial.available()){ commandByte = Serial.read();//read first byte noteByte = Serial.read();//read next byte velocityByte = Serial.read();//read final byte if (commandByte == noteOn){//if note on message //check if note == 60 and velocity > 0 if (noteByte == 60 && velocityByte > 0){ digitalWrite(13,HIGH);//turn on led } } } } while (Serial.available() > 2);//when at least three bytes available } void loop(){ checkMIDI(); delay(100); digitalWrite(13,LOW);//turn led off }
If you want to do a lot of stuff in the main loop, or if you are expecting to receive a lot of MIDI data and timing is important to you, you can also try using a timer interrupt to periodically pause the main loop and check if there is incoming MIDI. It will look something like this:
<pre>/*Receive Midi with interrupt By Amanda Ghassaei July 2012 <a href="https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/"> https://www.instructables.com/id/Send-and-Receive-...> * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 3 of the License, or * (at your option) any later version. */ byte commandByte; byte noteByte; byte velocityByte; void setup(){ Serial.begin(31250); cli();//stop interrupts //set timer2 interrupt every 128us TCCR2A = 0;// set entire TCCR2A register to 0 TCCR2B = 0;// same for TCCR2B TCNT2 = 0;//initialize counter value to 0 // set compare match register for 7.8khz increments OCR2A = 255;// = (16*10^6) / (7812.5*8) - 1 (must be <256) // turn on CTC mode TCCR2A |= (1 << WGM21); // Set CS11 bit for 8 prescaler TCCR2B |= (1 << CS11); // enable timer compare interrupt TIMSK2 |= (1 << OCIE2A); sei();//allow interrupts } ISR(TIMER2_COMPA_vect) {//checks for incoming midi every 128us do{ if (Serial.available()){ commandByte = Serial.read();//read first byte noteByte = Serial.read();//read next byte velocityByte = Serial.read();//read final byte } } while (Serial.available() > 2);//when at least three bytes available } void loop(){ //do whatever here }
STEP 11: Examples
I recently built a MIDI controller with a built in accelerometer and gyroscope, as well as 16 backlit buttons. I'll be posting the full project soon (still need to finish enclosure and a few other things), but I've attached some example code that shows how I got the MIDI up and running. Here is a video of two programs I've written so far:
And here is the code for those applications:
single pixel moving around, triggering MIDI (only uses x and y accelerometer):<pre>//accelerometer test- single pixel //by Amanda Ghassaei 2012 //https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/ /* * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * */ //pin connections //#define ledLatchPin 6 //#define ledClockPin 5 //#define ledDataPin 7 //#define buttonLatchPin 4 //#define buttonClockPin 3 //#define buttonDataPin 2 //setup varibles for Gyroscope/Accelerometer int xGyroRAW; int yGyroRAW; int xAccRAW; int yAccRAW; int zAccRAW; byte xGyro; byte yGyro; byte xAcc; byte yAcc; byte zAcc; //looping variables byte i; byte j; byte k; //storage for led states, 4 bytes byte ledData[] = {0, 0, 0, 0}; //storage for buttons, 4 bytes byte buttonCurrent[] = {0,0,0,0}; byte buttonLast[] = {0,0,0,0}; byte buttonEvent[] = {0,0,0,0}; byte buttonState[] = {0,0,0,0}; //button debounce counter- 16 bytes byte buttonDebounceCounter[4][4]; //variables for accelerometer pixel movement boolean firstPress = 1; byte movingPixel[] = {0, 0, 0, 0}; byte yPosition; byte xPosition; int timeX = 0; int timeY = 0; boolean dirX = 0; boolean dirY = 0; byte lastX = 4; byte lastY = 4; //MIDI variables int velocity = 100; int noteON = 144; int MIDIoffset = 60; byte currentX; void setup() { DDRD = 0xFA;//set pins D7-D4 as output, D2 as input Serial.begin(31250);//MIDI baud rate // Serial.begin(9600); cli();//stop interrupts //set timer1 interrupt at 1kHz TCCR1A = 0;// set entire TCCR1A register to 0 TCCR1B = 0;// same for TCCR1B TCNT1 = 0;//initialize counter value to 0; // set timer count for 1khz increments OCR1A = 1999;// = (16*10^6) / (1000*8) - 1 // turn on CTC mode TCCR1B |= (1 << WGM12); // Set CS11 bit for 8 prescaler TCCR1B |= (1 << CS11); // enable timer compare interrupt TIMSK1 |= (1 << OCIE1A); sei();//allow interrupts } ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz timeX++;//increment timeX timeY++;//increment timeY shift();//send data to leds } // buttonCheck - checks the state of a given button. //this buttoncheck function is largely copied from the monome 40h firmware by brian crabtree and joe lake void buttonCheck(byte row, byte index) { if (((buttonCurrent[row] ^ buttonLast[row]) & (1 << index)) && // if the current physical button state is different from the ((buttonCurrent[row] ^ buttonState[row]) & (1 << index))) { // last physical button state AND the current debounced state if (buttonCurrent[row] & (1 << index)) { // if the current physical button state is depressed buttonEvent[row] = 1 << index; // queue up a new button event immediately buttonState[row] |= (1 << index); // and set the debounced state to down. } else{ buttonDebounceCounter[row][index] = 12; } // otherwise the button was previously depressed and now // has been released so we set our debounce counter. } else if (((buttonCurrent[row] ^ buttonLast[row]) & (1 << index)) == 0 && // if the current physical button state is the same as (buttonCurrent[row] ^ buttonState[row]) & (1 << index)) { // the last physical button state but the current physical // button state is different from the current debounce // state... if (buttonDebounceCounter[row][index] > 0 && --buttonDebounceCounter[row][index] == 0) { // if the the debounce counter has // been decremented to 0 (meaning the // the button has been up for // kButtonUpDefaultDebounceCount // iterations/// buttonEvent[row] = 1 << index; // queue up a button state change event if (buttonCurrent[row] & (1 << index)){ // and toggle the buttons debounce state. buttonState[row] |= (1 << index); } else{ buttonState[row] &= ~(1 << index); } } } } void shift(){ for (i=0;i<4;i++){ buttonLast[i] = buttonCurrent[i]; byte dataToSend = (1 << (i+4)) | (15 & ~ledData[i]); // set latch pin low so the LEDs don't change while sending in bits PORTD&=B10111111;//digitalWrite(ledLatchPin, LOW); // shift out the bits of dataToSend //shiftOut(ledDataPin, ledClockPin, LSBFIRST, dataToSend); for (j=0;j<8;j++){ PORTD&=B11011111;//digitalWrite(ledClockPin,LOW); //digitalWrite(ledDataPin,((dataToSend>>j)&1)); if ((dataToSend>>j)&1){ PORTD|=B10000000; } else{ PORTD&=B01111111; } PORTD|=B00100000;//digitalWrite(ledClockPin,HIGH); } //set latch pin high so the LEDs will receive new data PORTD|=B01000000;//digitalWrite(ledLatchPin, HIGH); // SlowDown is put in here to waste a little time while we wait for the state of the output // pins to settle. Without this time wasting loop, a single button press would show up as // two presses (the button and its neighbour) volatile int SlowDown = 0; while (SlowDown < 15) { SlowDown++; } //once one row has been set high, receive data from buttons //set latch pin high PORTD|=B00010000;//digitalWrite(buttonLatchPin, HIGH); //shift in data //buttonCurrent[i] = shiftIn(buttonDataPin, buttonClockPin, LSBFIRST) >> 3; for (j=0;j<4;j++){ PORTD&=B11110111;//digitalWrite(buttonClockPin,LOW); PORTD|=B00001000;//digitalWrite(buttonClockPin,HIGH); } for (j=0;j<4;j++){ PORTD&=B11110111;//digitalWrite(buttonClockPin,LOW); if ((PIND>>2)&1){//digitalRead(buttonDataPin) buttonCurrent[i]|=1<<j; } else{ buttonCurrent[i]&=~(1<<j); } PORTD|=B00001000;//digitalWrite(buttonClockPin,HIGH); } //latchpin low PORTD&=B11101111;//digitalWrite(buttonLatchPin, LOW); for (k=0;k<4;k++){ buttonCheck(i,k); } } //turn off leds- this way one row does not appear brighter than the rest // set latch pin low so the LEDs don't change while sending in bits PORTD&=B10111111;//digitalWrite(ledLatchPin, LOW); // shift out 0 //shiftOut(ledDataPin, ledClockPin, LSBFIRST, 0); for (j=0;j<8;j++){ PORTD&=B11011111;//digitalWrite(ledClockPin,LOW); PORTD&=B01111111; PORTD|=B00100000;//digitalWrite(ledClockPin,HIGH); } //set latch pin high so the LEDs will receive new data PORTD|=B01000000;//digitalWrite(ledLatchPin, HIGH); } void checkFirstButton(){ for (byte a=0;a<4;a++){ if (buttonEvent[a]){ for (byte b=0;b<4;b++){ if (buttonState[a]&(1<<b)){ //toggle firstPress variable firstPress = 0; //display pressed pixel ledData[a] = buttonEvent[a]; //store current position yPosition = a; xPosition = 1<<b; //reset timers timeX = 0; timeY = 0; return; } } } } } byte scaleAcc(int RAW){ if (RAW<=10 && RAW>=-10){ return 5; } else if (RAW<-10){ if (RAW<-50){ return 0; } else if (RAW<-40){ return 1; } else if (RAW<-30){ return 2; } else if (RAW<-20){ return 3; } else{ return 4; } } else if (RAW>10){ if (RAW>50){ return 10; } else if (RAW>40){ return 9; } else if (RAW>30){ return 8; } else if (RAW>20){ return 7; } else{ return 6; } } } void checkAccelerometer(){ //read values xGyroRAW = analogRead(A1); yGyroRAW = analogRead(A0); xAccRAW = analogRead(A4); yAccRAW = analogRead(A3); zAccRAW = analogRead(A2); //offset data xGyroRAW = 317-xGyroRAW; yGyroRAW = 183-yGyroRAW; xAccRAW = 282-xAccRAW; yAccRAW = 282-yAccRAW; zAccRAW = 282-zAccRAW; if (xAccRAW>0){ dirX = 1; } else{ dirX = 0; } if (yAccRAW>0){ dirY = 1; } else{ dirY = 0; } //convert to 0-10 xAcc = scaleAcc(xAccRAW); yAcc = scaleAcc(yAccRAW); } int getTime(byte acceleration){ switch (acceleration){ case 0://max - acceleration return 25; break; case 1: return 25; break; case 2: return 50; break; case 3: return 100; break; case 4: return 150; break; case 5://lying flat return 0; break; case 6: return 150; break; case 7: return 100; break; case 8: return 50; break; case 9: return 25; break; case 10://max + acceleration return 25; break; } } void moveXPixel(int timeComp){ if (timeComp==0){ } else{ if (timeX>timeComp){ timeX = 0; if (dirX){ if (xPosition==8){ } else{ xPosition = xPosition<<1; } } else{ if (xPosition==1){ } else{ xPosition = xPosition>>1; } } } } } void moveYPixel(int timeComp){ if (timeComp==0){ } else{ if (timeY>timeComp){ timeY = 0; if (dirY){ if (yPosition==3){ } else{ yPosition = yPosition+=1; } } else{ if (yPosition==0){ } else{ yPosition = yPosition-=1; } } } } } void checkMIDI(){ //convert xPosition to decimal switch (xPosition){ case 1: currentX = 0; break; case 2: currentX = 1; break; case 4: currentX = 2; break; case 8: currentX = 3; break; } //if pixel has moved send midi if (lastX != currentX || lastY != yPosition){ MIDImessage(noteON,(lastX+5*lastY+MIDIoffset),0);//turn off last note MIDImessage(noteON,(currentX+5*yPosition+MIDIoffset),velocity);//turn on next note } lastX = currentX; lastY = yPosition; } void MIDImessage(int command, int MIDInote, int MIDIvelocity) {//send s a MIDI message Serial.write(command);//send note on or note off command Serial.write(MIDInote);//send pitch data Serial.write(MIDIvelocity);//send velocity data } void loop() { if (firstPress){ checkFirstButton(); } else{ for (byte pixel=0;pixel<4;pixel++){ if (pixel==yPosition){ ledData[pixel]=xPosition; } else{ ledData[pixel] = 0; } } checkAccelerometer(); moveXPixel(getTime(xAcc)); moveYPixel(getTime(yAcc)); checkMIDI(); } }
four pixels bouncing (only uses x accelerometer, uses x gyro to clear pixels):
<pre>//accelerometer test- bounce //by Amanda Ghassaei 2012 //https://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/ /* * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * */ //pin connections //#define ledLatchPin 6 //#define ledClockPin 5 //#define ledDataPin 7 //#define buttonLatchPin 4 //#define buttonClockPin 3 //#define buttonDataPin 2 //setup varibles for Gyroscope/Accelerometer int xGyroRAW; int yGyroRAW; int xAccRAW; int yAccRAW; int zAccRAW; byte xGyro; byte yGyro; byte xAcc; byte yAcc; byte zAcc; //looping variables byte i; byte j; byte k; //storage for led states, 4 bytes byte ledData[] = {0, 0, 0, 0}; //storage for buttons, 4 bytes byte buttonCurrent[] = {0,0,0,0}; byte buttonLast[] = {0,0,0,0}; byte buttonEvent[] = {0,0,0,0}; byte buttonState[] = {0,0,0,0}; //button debounce counter- 16 bytes byte buttonDebounceCounter[4][4]; //variables for accelerometer pixel movement boolean firstPress[] = {0, 0, 0, 0}; byte movingPixel[] = {0, 0, 0, 0}; byte xPosition[4]; int timeX[] = {0, 0, 0, 0}; boolean dirX; boolean dirY; boolean prevDirX = 0; boolean bounceDirection[]= {0, 0, 0, 0}; boolean toggle[] = {1, 1, 1, 1}; byte peakHeight[4]; byte lastX = 4; byte lastY = 4; //MIDI variables int velocity = 100; int noteON = 144; int MIDIoffset = 60; byte currentX; byte note[] = {60, 64, 67, 72}; void setup() { DDRD = 0xFA;//set pins D7-D4 as output, D2 as input Serial.begin(31250);//MIDI baud rate cli();//stop interrupts //set timer1 interrupt at 1kHz TCCR1A = 0;// set entire TCCR1A register to 0 TCCR1B = 0;// same for TCCR1B TCNT1 = 0;//initialize counter value to 0; // set timer count for 1khz increments OCR1A = 1999;// = (16*10^6) / (1000*8) - 1 // turn on CTC mode TCCR1B |= (1 << WGM12); // Set CS11 bit for 8 prescaler TCCR1B |= (1 << CS11); // enable timer compare interrupt TIMSK1 |= (1 << OCIE1A); sei();//allow interrupts } ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz for (byte a=0;a<4;a++){ timeX[a]++;//increment each element of timeX } shift(); } // buttonCheck - checks the state of a given button. //this buttoncheck function is largely copied from the monome 40h firmware by brian crabtree and joe lake void buttonCheck(byte row, byte index) { if (((buttonCurrent[row] ^ buttonLast[row]) & (1 << index)) && // if the current physical button state is different from the ((buttonCurrent[row] ^ buttonState[row]) & (1 << index))) { // last physical button state AND the current debounced state if (buttonCurrent[row] & (1 << index)) { // if the current physical button state is depressed buttonEvent[row] = 1 << index; // queue up a new button event immediately buttonState[row] |= (1 << index); // and set the debounced state to down. } else{ buttonDebounceCounter[row][index] = 12; } // otherwise the button was previously depressed and now // has been released so we set our debounce counter. } else if (((buttonCurrent[row] ^ buttonLast[row]) & (1 << index)) == 0 && // if the current physical button state is the same as (buttonCurrent[row] ^ buttonState[row]) & (1 << index)) { // the last physical button state but the current physical // button state is different from the current debounce // state... if (buttonDebounceCounter[row][index] > 0 && --buttonDebounceCounter[row][index] == 0) { // if the the debounce counter has // been decremented to 0 (meaning the // the button has been up for // kButtonUpDefaultDebounceCount // iterations/// buttonEvent[row] = 1 << index; // queue up a button state change event if (buttonCurrent[row] & (1 << index)){ // and toggle the buttons debounce state. buttonState[row] |= (1 << index); } else{ buttonState[row] &= ~(1 << index); } } } } void shift(){ for (i=0;i<4;i++){ buttonLast[i] = buttonCurrent[i]; byte dataToSend = (1 << (i+4)) | (15 & ~ledData[i]); // set latch pin low so the LEDs don't change while sending in bits PORTD&=B10111111;//digitalWrite(ledLatchPin, LOW); // shift out the bits of dataToSend //shiftOut(ledDataPin, ledClockPin, LSBFIRST, dataToSend); for (j=0;j<8;j++){ PORTD&=B11011111;//digitalWrite(ledClockPin,LOW); //digitalWrite(ledDataPin,((dataToSend>>j)&1)); if ((dataToSend>>j)&1){ PORTD|=B10000000; } else{ PORTD&=B01111111; } PORTD|=B00100000;//digitalWrite(ledClockPin,HIGH); } //set latch pin high so the LEDs will receive new data PORTD|=B01000000;//digitalWrite(ledLatchPin, HIGH); // SlowDown is put in here to waste a little time while we wait for the state of the output // pins to settle. Without this time wasting loop, a single button press would show up as // two presses (the button and its neighbour) volatile int SlowDown = 0; while (SlowDown < 15) { SlowDown++; } //once one row has been set high, receive data from buttons //set latch pin high PORTD|=B00010000;//digitalWrite(buttonLatchPin, HIGH); //shift in data //buttonCurrent[i] = shiftIn(buttonDataPin, buttonClockPin, LSBFIRST) >> 3; for (j=0;j<4;j++){ PORTD&=B11110111;//digitalWrite(buttonClockPin,LOW); PORTD|=B00001000;//digitalWrite(buttonClockPin,HIGH); } for (j=0;j<4;j++){ PORTD&=B11110111;//digitalWrite(buttonClockPin,LOW); if ((PIND>>2)&1){//digitalRead(buttonDataPin) buttonCurrent[i]|=1<<j; } else{ buttonCurrent[i]&=~(1<<j); } PORTD|=B00001000;//digitalWrite(buttonClockPin,HIGH); } //latchpin low PORTD&=B11101111;//digitalWrite(buttonLatchPin, LOW); for (k=0;k<4;k++){ buttonCheck(i,k); } } //turn off leds- this way one row does not appear brighter than the rest // set latch pin low so the LEDs don't change while sending in bits PORTD&=B10111111;//digitalWrite(ledLatchPin, LOW); // shift out 0 //shiftOut(ledDataPin, ledClockPin, LSBFIRST, 0); for (j=0;j<8;j++){ PORTD&=B11011111;//digitalWrite(ledClockPin,LOW); PORTD&=B01111111; PORTD|=B00100000;//digitalWrite(ledClockPin,HIGH); } //set latch pin high so the LEDs will receive new data PORTD|=B01000000;//digitalWrite(ledLatchPin, HIGH); } void checkPress(byte Y){ if (buttonEvent[Y]){ for (byte b=0;b<4;b++){ if (buttonState[Y]&(1<<b)){ //toggle firstPress variable firstPress[Y] = 1; //display pressed pixel ledData[Y] = (1<<b); //store current position xPosition[Y] = (1<<b); //store peak height peakHeight[Y] = (1<<b); //reset timers timeX[Y] = 0; return; } } } } byte scaleAcc(int RAW){ if (RAW<=10 && RAW>=-10){ return 5; } else if (RAW<-10){ if (RAW<-50){ return 0; } else if (RAW<-40){ return 1; } else if (RAW<-30){ return 2; } else if (RAW<-20){ return 3; } else{ return 4; } } else if (RAW>10){ if (RAW>50){ return 10; } else if (RAW>40){ return 9; } else if (RAW>30){ return 8; } else if (RAW>20){ return 7; } else{ return 6; } } } void checkAccelerometerGyro(){ //read values xGyroRAW = analogRead(A1); yGyroRAW = analogRead(A0); xAccRAW = analogRead(A4); yAccRAW = analogRead(A3); zAccRAW = analogRead(A2); //offset data xGyroRAW = 317-xGyroRAW; yGyroRAW = 183-yGyroRAW; xAccRAW = 282-xAccRAW; yAccRAW = 282-yAccRAW; zAccRAW = 282-zAccRAW; //convert to 0-10 xAcc = scaleAcc(xAccRAW); yAcc = scaleAcc(yAccRAW); if (xAccRAW>5){ dirX = 1; } else if (xAccRAW<5){ dirX = 0; } if (yAccRAW>5){ dirY = 1; } else if (yAccRAW>5){ dirY = 0; } } int getTime(byte acceleration){ switch (acceleration){ case 0://max - acceleration return 100; break; case 1: return 100; break; case 2: return 150; break; case 3: return 200; break; case 4: return 250; break; case 5://lying flat return 0; break; case 6: return 250; break; case 7: return 200; break; case 8: return 150; break; case 9: return 100; break; case 10://max + acceleration return 100; break; } } void moveXPixel(byte Y, int timeComp){ if (timeComp==0){ } else{ if (timeX[Y]>timeComp){ timeX[Y] = 0; if (dirX){ if (peakHeight[Y]==8&&xPosition[Y]==8){ if(toggle[Y]){ MIDImessage(noteON,note[Y],0);//send midi toggle[Y]=0; ledData[Y]=0; } else{ MIDImessage(noteON,note[Y],velocity); toggle[Y]=1; } } else{ toggle[Y]=1; if (xPosition[Y]==peakHeight[Y]){//if at peak bounceDirection[Y]=1;//falling MIDImessage(noteON,note[Y],0);//turn note off } if (xPosition[Y]==8){//if hitting bottom bounceDirection[Y]=0;//rising MIDImessage(noteON,note[Y],velocity);//turn note on } if (xPosition[Y]==1){ bounceDirection[Y]=1; } if (bounceDirection[Y]){ xPosition[Y] = xPosition[Y]<<1; } else{ xPosition[Y] = xPosition[Y]>>1; } } } else{ if (peakHeight[Y]==1&&xPosition[Y]==1){ if(toggle[Y]){ MIDImessage(noteON,note[Y],0);//send midi toggle[Y]=0; ledData[Y]=0; } else{ MIDImessage(noteON,note[Y],velocity); toggle[Y]=1; } } else{ toggle[Y]=1; if (xPosition[Y]==peakHeight[Y]){//if at peak bounceDirection[Y]=0;//falling MIDImessage(noteON,note[Y],0);//turn note off } if (xPosition[Y]==8){ bounceDirection[Y]=0; } if (xPosition[Y]==1){//if hitting bottom bounceDirection[Y]=1;//rising MIDImessage(noteON,note[Y],velocity);//turn note on } if (bounceDirection[Y]){ xPosition[Y] = xPosition[Y]<<1; } else{ xPosition[Y] = xPosition[Y]>>1; } } } } } } void shake2Clear(){ if (abs(xGyroRAW)>300){ for (byte a=0;a<4;a++){ firstPress[a]=0; ledData[a]=0; } } } void MIDImessage(int command, int MIDInote, int MIDIvelocity) {//send s a MIDI message Serial.write(command);//send note on or note off command Serial.write(MIDInote);//send pitch data Serial.write(MIDIvelocity);//send velocity data } void loop() { checkAccelerometerGyro(); shake2Clear(); for (byte column=0;column<4;column++){ checkPress(column); if (firstPress[column]){ moveXPixel(column, getTime(xAcc)); if (toggle[column]){ ledData[column]= xPosition[column]; } } } }
235 Comments
steamrocks 4 years ago
Like others, I have tried without success to make it work, but have spend days trying to find the cause of failure.
I am using a MEGA and have changed the serial port to Serial1, with input at pin 19. Changes are reflected in the software. Program was re-compiled without errors. Serial
was retained for Serial.println statements for program debugging.
I have:
1. Built the optoisolator circuit and checked my work at least 10 times.
2. Substituted other 6N138's (on sockets) for fear I damaged some.
3. Used an alternate circuit with 4N25's, I have used 100's of these in organ circuits
with total success. Here....none!
4. Written test sketches to see if BOTH optoisolators communicate with the Arduino. They both can get the input pin to change state, just not receive serial data. Several tests of the interface circuits preceded this, including whether or not the LEDs were getting voltage and whether the output stages were going from high to low, and they were. Neither circuit achieved a zero voltage state at the input pin, although the resistance values used were as published.
5. Tried MIDI input with two different high-end Korg keyboards, both set to Ch 1, playing note 60.
6. Tested the keyboards' outputs with MIDI monitors to assure they were transmitting Ch1, note 60. They were.
7. Placed Serial.println statements in portions of the program to see if the Serial.available was working, it wasn't. It appears the program did not get past that statement for some reason. I did not try to analyze the software, if it is published, it should have been checked thoroughly.
I am totally out of options, nowhere to go except to buy a MIDI shield, although with my luck that won't work with a MEGA, either.
With all the work I have put into this, I DESERVE a working MIDI receive! Especially for the
totally cool project it is going into. This only makes me wonder how the MIDI out will work!
mosstech 2 years ago
The "Receive MIDI Messages" diagram is incorrect, and does not match the picture of the board. The MIDI jack wires should go to the opposite IC pins as shown in the diagram. Took me a while to figure this out.
rndjoe 3 years ago
wfelix 3 years ago
miguellincale 3 years ago
Phil Sznyck 4 years ago
I hope you or someone else can answer me that question!
Thanks in advance and for your work until here!
Phil.
Joelf333 5 years ago
Midi out is working just fine. But when trying to receive midi messages nothing happens. The led doesn't blink. I have triple checked the connections and i just can't seem to find it. I send middle C from different programs on my computer and i get the same result, nothing.
I haven't added anything to the programming, its a direct copy paste (yes i have plugged midi cable from midi out to the arduino). The interface is working, the green lamp is blinking.
The programs select a specific channel. Aren't you supposed to select a channel somehow in the programming as well?
heckstall 4 years ago
Thank you!
Skipper1983 4 years ago
Rec-Tec 5 years ago
Jens Jørgen 5 years ago
abhilash_patel 5 years ago
JesoniasF 5 years ago
kurtaa98 5 years ago
Hi I am looking at creating an audio player for my MIDI keyboard and I am looking at this tutorial in conjunction with your "Arduino Audio Output" instructable. I am only interested in recieving MIDI messages. My MIDI keyboard uses a USB A to USB B cable both for communication and power. How could I make a hardware setup suitable for this?
PadrinoR 5 years ago
I'm doing the same project using an arduino nano .. can you tell me what programs should I use and how do I use it in FBU status?
steve2010 6 years ago
Thanks Amanda ,Starting what will hopefully be a programmable midi loop switcher with a separate foot controller but want to learn as I go .So far I've completed step 6 and everything is working as your guide says.
I've had no issues with your code so far
Steve
amandaghassaei 6 years ago
awesome! Hope you were able to finish your project!
