Shelves From Old Futon
Intro: Shelves From Old Futon
Turn an old futon into some sweet new shelves. Concept by Gabe Nathanson. He's the original "suspension invention" inventor. This particular design/implementation by me.
Ingredient list:
Ingredient list:
- Turnbuckels - 1 per threaded rod
- Threaded Rod - i used 1/4in
- 1 old futon - or other shelf like wood
- box of washers
- box of nuts (both should fit the threaded rod)
- drill
- dremmel - optional
STEP 1: Design Shelves
Design your shelves to fit your room -
these are totally adjustable, so you could do anything
STEP 2: Deconstruction & Cutting
- take apart old futon
- cut wood into your desired shelf lengths
STEP 3: Finding Studs & Drilling Holes
- find studs in ceiling using stud finder
- drill small holes where you want your rod to hang.
STEP 4: More Drilling
- drill 4 holes in each piece (2 on each end)-
you want to make sure your wood holes match up with the holes in the ceiling
STEP 5: Screwing & Hanging
- screw the closed loop end of the turnbuckle into the holes
- screw threaded rod into the other end of the turnbuckle
- hang threaded rod as in pictures
STEP 6: Nearly Done
- insert wood shelves onto threaded rod - in whatever configuration you wish.
- after each piece of wood is on, add a washer and a nut.
- i used a ladder to keep the wood shelf held up while i ran the nuts up to the desired position. also used tape to tape the washers to the shelf so that they didn't get in the way
- (optional) - to save a lot of time running the nuts up the rod, use something like a dremmel with buffing attachment to turn the nuts so that they spin up the rod.
15 Comments
grysqrl 13 years ago
komecake 14 years ago
pinkbunny 17 years ago
gorillapoop 17 years ago
dmacrae 17 years ago
royalestel 17 years ago
jwatriss 17 years ago
wperry1 17 years ago
LasVegas 17 years ago
theRIAA 17 years ago
http://www.flickr.com/photos/theriaa/406564229/
randofo 17 years ago
trebuchet03 17 years ago
