Simple Panoramic Rig
Intro: Simple Panoramic Rig
Below are directions for a simple rig for panoramic video. It was built with free pallet wood and the temporary use of my mountain bike rim. The project took about 5 minutes to put it together.
STEP 1: Tools/Materials
Tools:
- Saw
- Drill
- Measuring tape
Materials:
- Bicycle Rim/Tire (26” used for this project)
- Wood – I used pallets
- 16” x 3.5”
- 38” x 5.5”
- 32” x 4” (x2)
STEP 2:
Find any wood. I used pallets from a previous project. Cut to approximate lengths shown above.
STEP 3:
Drill hole in small board to match axle diameter. Mount tire to board – use nut from bike.
STEP 4:
Drill a clearance hole in the center support.
STEP 5:
Attach small board to center support.
STEP 6:
Add stabilization legs.
STEP 7:
Place camcorder/camera on edge of wheel.
STEP 8:
Spin and record. See link for video.
21 Comments
michaelgc 9 years ago
Super simple, love it! Thanks for the video also...
ehudwill 9 years ago
Great idea. I really like the look of the shot. Thanks for sharing.
jimrlynn 9 years ago
Very nice. You can get a pan with a different "feel" to it if you mount the camera back on the hub. You could easily attach a tripod to the rim to get the camera up high enough to get the wheel out of the shot. My son likes it as well (NYU-Tisch, they play Quidditch)
dacker 9 years ago
@jimrlynn, I agree with your first point.
In the 90s, when I still worked for Eastman Kodak, I had access to a proper (and expensive) panoramic indexing head to mount on a tripod. I experimented with it a couple times with my Canon A1 35mm SLR.
Part of the intent of the head was to rotate the camera such that the film plane was at the center of rotation. SLRs bodies are all marked with a small graphic which locates the film plane. Rotating the camera inside or outside the film plane introduces distortion in the images. I expect DLSRs and P&S digital cameras have the same issue.
MrBillG59 9 years ago
The object is not to rotate around the film-plane, but to rotate around the focal point node of the lens which is somewere around the center of the lens.
dacker 9 years ago
Mea culpa!
What you wrote resurrected a 20+ year-old memory which makes me think you are spot-on about the center of rotation. I half-remember needing to do some math to determine the focal point node of my 28-90 zoom lens at the 28mm focal length.
Still, the point is that having the camera way out on the rim is less than ideal.
hheijnen 9 years ago
You don't need to calculate the Nodal point you can use the process described in this youtube movie
Marked with a similar indicator on prime lenses, but not on zooms because of shifting elements as you change focal length. I think there is an estimator app out there somewhere...
karlpinturr 9 years ago
The tripod's an interesting idea, but it will magnify any 'wobble' caused by bearing sloppiness.
You would have to locate the hub closer to the top of the tee to allow for $1.99 roller ball castors from Harbor Freight. 3 of them located just
under the rim would stabilize a tripod. I am going to build one this
weekend. Also, I was anticipating useing what is called a "top hat" or
"low boy" tripod, which only extends about 18 inches.
chuckyd 9 years ago
I agree.
mtairymd 9 years ago
I agree. I also tie wrapped my phone to the spokes and rotated the rig 90 degrees to make a spinning video. Weird but not very useful.
https://www.youtube.com/watch?v=vEubled5kes&feature=youtu.be
Homee2010 9 years ago
Nicely done. I will make this tomorrow. But, mine will be a road bike wheel. I guess I'll just have to spin it faster... ;)
fixfireleo 9 years ago
great idea for keeping a steady shot! you should patent and sell them to realtors for like $500 each! :)
Slavat 9 years ago
Легче!
http://www.wired.com/2011/09/ikea-hack-time-lapse-panning-tripod-from-kitchen-timer/
Nice, neat and simple - but if you don't nailgun the stabilization legs, you'll have something a lot more portable, as well as adaptable to different slopes and cambers and leg sizes/heights/thicknesses etc.
And if you do start getting into angles and/or heights where stability is an issue, a few woodscrews would be more flexible than nails - particularly from a nailgun.
andreyeurope 9 years ago
Nice and simple. Good Work!
AJMansfield 9 years ago
You should add some of the resulting panoramic shots you got with it.
ghaines2 9 years ago
epic. With a coulp of mods it would make a grate time laps rig :)
M3G 9 years ago
Simple yet effective! Nice work.
