Skateboard Table
Intro: Skateboard Table
For those of you who were told not to skate in the house as a child, here's a lazy susan coffee table that rotates on skateboard wheels.
Think of the possibilities: Play board games where nobody has to look at the board upside-down. Bring the remote within reach without getting up from the couch. Epic tea parties.
Check out the video below:
*If anybody wants to make that Scrabble Tile Coaster, you can: https://www.instructables.com/id/Scrabble-Tile-Coasters/
STEP 1: Design Inspiration
My inspiration came from this table (pictured). Here's the blurb they use to describe it:
I wanted one that met the following constraints:
I purchased only from Anytown, USA stores. Home Depot, Ace Hardware, Amazon and Pier 1 (for the glass). No specialty shops. No exotic lumberyards. Nothing fancy. Just deck planks, a couple of cheapo complete skateboard sets, and miscellaneous fasteners.
I used a power drill and a miter saw and a palm sander. You could sand by hand if you had to or wanted the workout, but the other two tools are pretty essential. It's more trouble to get the proper handsaw for the finish work than it is to just ask a neighbor to borrow his miter saw. Or chopbox. Or whatever you want to call it.
After cutting and drilling, assembly is more or less Ikea-style. All inserting dowels into slots. Then some screwing. Just like Ikea.
"Perfectly engineered truck, wheel and glass interplay, the 360 Table is a grown-up lazy susan that celebrates that instance of teenage rebellion. Taking seriously the claim that skating is a lifestyle, this piece accommodates and furnishes that life quite well."
But their version retails for $2000. And does not include the glass top, which will cost you another $100 or so.I wanted one that met the following constraints:
- Less than $100
- Made from wood and parts available pretty much anywhere
- Requires minimal power tools
- Easy to assemble
STEP 2: Materials
Parts
- Redwood board - 2x $14 each
- 2 x 6 x 8
- Dowel pins - $2
- 12 pack
- with channels in the side for extra glue hold
- Dowel centers
- Simpson strong-tie T-shaped strap - $4 at HD
- 6" x 6"
- and screws to install on the bottom
- Krown Rookie Complete Skateboard x2 - $44 at Amazon
- full set of trucks/wheels/bearings cheaper as full set than individually
- save deck for future projects
- Wood glue
- Semigloss polyurethane
- #8 1" wood screws
- miter saw
- palm sander
- drill
- with brad point bits
- 5/16" and something teeny-tiny for your pilot holes
- speed square
- protractor
- a band clamp (you could use any ratcheting tie, it's pretty much the same thing)
- rubber mallet
- palm sander
- sponge for applying polyurethane
STEP 3: Saw
Cut your 2 x 6s to length. I had the guys at the lumberyard cut the boards into 24" segments, then I cut them to size in the shop. (Perfect for the urban woodworking enthusiast; portable, easy, and you get to watch the giant saw at the lumberyard in operation.)
The length of the radial portions on the top of the table base may vary. Customize it to your space. (I made my table a little smaller than the original by shortening the radial boards from 20" to 18".) Just make sure each board end is absolutely square by trimming the last inch or so from each side of the 2 x 6 prior to working with them. Not every cut at the mill or the lumberyard is going to be to your specs. Here's what I did for a 36" diameter table:
- Radial boards for the top of the base: 18"
- Leg boards: 14"
STEP 4: Saw 2
Now that all of your boards have been cut to length, it's time for the fiddly part: that central joint. We'll need to know where to make the cuts to give you a beautiful set of 120 degree pointed boards, and that might require some math.
I've broken it out into three options for you:
Now that you know where to make the cuts, get to it. I made a few practice pieces to get a feel for a new saw, figure out the size of the kerf, and because I am on the obsessive side of cautious. I also struggle with simple math.
Things to remember: make your marks as exactly and as consistently as possible. Use the speed square. Use a ruler. Check with a protractor. Then cut.
- For students of the humanities and children, use a protractor to mark a line from the center of the end of the board. Draw a line along the 60 degree mark from that midpoint to the side of the board. That'll give you a lovely line that you may cut along.
- For those of you who fully trust the angles along the bottom of the miter saw, just go ahead and mark the midpoint of your board, then set the saw to 30 degrees, align with the midpoint, and cut.
- For those of you who know trigonometry, just puzzle it out. [Hint: x = .5(width of the board) • tan(30)]
STEP 5: Treat the Wood
You can save this step till last, but I like my pieces to be done before I assemble everything. It gives me that Ikea feel of ready-to-assemble furniture. And it makes me concentrate extra hard on not allowing any dings to the wood. And forces me to glue very, very carefully later on. For those of you unsure of your polyurethaning abilities, you might want to do this just before installing the skateboard parts.
I chose polyurethane because it has good protective qualities and has a matte finish. I don't want a glossy table with a glossy top, that's a little too much shine for me. The semi-gloss is good for my needs and hides mistakes better than a gloss. You will be fine with an oil or wax if you want to go that route. The Minwax tung oil gave me the same look as the semi-gloss poly, in case you are curious. (It was also approximately a zillion times easier to apply.)
For the brave and/or foolhardy, let's put on some polyurethane. First, follow the directions on the can. Then, because the can directions sometimes suck, try this:
*The palm sander moves too fast and melts the finish. Then you wind up having to sand everything back to zero and start over. Bad news. Get close with your wood. Touch it. Caress it. Then rub it with abrasive paper. Lovingly. John Henry will appreciate the triumph of man over machine. So will your finish.
- use as matte a finish as possible to avoid having a tiny mistake force you to start over
- use a disposable sponge brush (or just a sponge like I did)
- don't over-do it, you will regret it later when you have to scrape off the bubbles/drips with a razor
- follow the grain
- allow plenty of drying time
- hand-sand between coats*
- if any of that sounds too hard, just use oil or wax
STEP 6: Joint
Now that everything is cut to size, it's time to mark our holes for doweling. Check the secondary images and image notes for this step, as many of these ideas are easier to convey visually rather than with text.
You'll really want some dowel centers for this. (If you don't have any, a thumbtack should do in a pinch.) They will help you align your holes after drilling. Your drill likely has some wobble and may travel a bit as you drill out your holes. The dowel centers allow you to mess up a little bit on your initial hole placement by letting you just use the existing hole to mark where to drill on the next board.
Mark your drill locations in the following places:
Use a brad point bit. It will make this easier. If you don't have one, drill pilot holes, then use your normal bits. You shouldn't need to buy anything special for this. Be sure to wrap your bit so you don't end up drilling too deep.
Measure twice, stay away from the edges of the wood so as not to split your board, take a deep breath, then drill perpendicular to the face you are working on.
Use the dowel center to mark the drill location for the board you will attach to the board you just drilled into freehand.*
*Look at the pictures and read the image notes, this is sounding much more complicated than it is.
- each side of the pointy bit on the radial supports
- two equidistant marks on the underside of each radial support
- two equidistant marks on the top of each leg
STEP 7: Glue
To glue, put a small dab of wood glue on both sides of your dowels. Then align the corresponding board. You'll have to glue and push in all three boards at once for the interior joint. Once you've pushed everything together to your satisfaction, put the strap clamp around the whole shebang. Tighten to the point that everything is pushed together, but not so tight that it starts to pull your joint apart. Then wait for it to dry.
Bonus cheating step: screw the T strap onto the base of the joint after the glue has dried. I don't fully trust the dowels, so some surreptitious metal makes me feel better.
Then glue on the legs. Clamp them in place with something like this. (Not pictured because I didn't actually glue the legs on so I could carry this in my car.)
STEP 8: Attach Trucks
Your trucks may vary in size, so I'll give approximate directions for attaching your skateboard apparatus.
Center the trucks on the board. You'll want your outermost wheel to be even with the edge of the radial board. Measure, measure, measure. Mark the center of the holes with an awl or pencil tip or paper clip or something else thin and pointy.
Use the same technique as before to create drill stops with tape, using the length of your screws as a guide. Then drill each mark that you made. Go in as straight as you can to keep the screwheads parallel to the radial boards. It'll be prettier that way.
Put on all the trucks facing the same direction. Look at the pictures. Then screw 'em on.
STEP 9: Tabletop
Glass tabletops can be pricey. Check for cheap ones at thrift stores, garage sales, and flea markets, or just cannibalize one from another table.
I got mine from a salvage yard that sources their materials from the local dump/recycling center. I got mine from Pier 1. Worth the slight mark-up to not have to dig through trash for a day looking for a single item. And the prices at the recycling center were actually higher than the Pier.
Put the glass on top of the skateboard wheels. Centering the table is a bit of a challenge (aka nightmare), so I decided to just eyeball it to get it as close as I could. You'll notice in the video that the glass hangs over one set of wheels a bit further than the others, but it's not too much of a hassle to move it back into place. I imagine that a real set of skateboard wheels with proper bearings might prevent the eccentric motion, but I chose not to check. Or I could have just picked up a bigger piece of glass for an extra $10.
You're welcome to experiment with the placement of the glass, the bearings, or the glass size. Tell me what worked for you. 3 months of pro membership for anyone who builds their own version and posts a pic in the comments.
55 Comments
iarnon 1 year ago
Rainadeer 5 years ago
I used red cedar wood for the table and picked out some nice Thrasher trucks and Thrasher pentagram bolts. I ordered a 36” glass top as part of a deep discounted sale (the package was damaged but the glass was perfect) from Amazon Warehouse. The glass top has a 1 5/8” diameter hole with silicone o-ring and cap for a patio umbrella. I’m going to try to slip an Independent skate tool through the hole with a couple bearings so that it spins over the center joint of the table but is still easy to remove whenever he wants to use the tool.
I was able to solve the issue with the glass sliding when the table spins by affixing silicone bumper guard along the edge of the glass. :)
Also, this was super hard to photograph! The glass is so shiny. Looks even better in person.
mchau2 8 years ago
izzyspeaks123 8 years ago
This is a brilliant write up on its own, but sadly the video is not there? But it does give me ideas. How easy is this to center when setting it up for use?
LynxSys 9 years ago
Not only is this an excellent and well-documented Instructable, but you've saved yourself $1840 (plus tax)! Well played. Also, I rather enjoyed your slightly tongue-in-cheek writing, and I like how everyone in the comments is working on your centering issue. I think you'll be excited to hear that my solution to the problem involves an Arduino, distance-measuring lasers, and using a CNC router (or laser cutter) to construct parts of the linear actuators. It will be powered by a hacked computer PSU, and will use LEDs to notify you when your tabletop is in danger of falling off. I'm still working on getting it to e-mail you when the glass breaks...
splatman 10 years ago
Or put the wheels on a lathe, and cut down all but the part that will stick out by an 1/8" or so.
the1realdave 10 years ago
1. Buy the glass first
Since the glass is easily the most expensive piece, buy it first. Then size your wood to match the glass.
2. Cut the interior angles first
Size your three horizontal boards 8"-14" longer than the radius of your glass. Then cut the interior angles of all three, and test how they fit together before doing the exterior cut. The six 60 degree cuts will be the most difficult to get positioned and angled correctly. Doing them first, with some extra wood gives you room to redo them a couple of times without having to throw out your board.
Once you're happy with the fit, and you have your dowel holes drilled, and the dowels mated up, measure the length to the square ends (based on the the diameter of the glass), and cut the square end. Remember measure twice, cut once, and use a square for all your lines.
3. Test your assembly before gluing or staining
First, Make all the pilot holes for the bracing and the trucks, Then do a test assembly of the horizontal pieces of the table. Without glue, put in the dowels, and seat the bracket (don't over-tighten the screws). Then, flip over and attach the trucks. Then use the ratchet strap to temporarily hold everything together. Test the table by setting the top on it and verifying that it works to your satisfaction.
4. Stain and clear coat as next to last step
After you're happy with the test assembly, remove all the hardware and prepare the wood for staining. Be sure to sand all the surfaces sufficiently to remove any contaminants (even the oil from your hands can disturb the stain). Pay special attention to exterior corners; be sure to sand them enough to remove sharp edges or rough spots.
Next, stain the bottom faces first and after it dries, sand to remove any drips, and then stain the top surfaces (the experience staining the bottoms, will help you do a better job on the top.
Repeat the process with the polyurethane clear coat.
With everything perfectly measured, stained and finished. Carefully glue the joints in the middle, attach the bottom bracket, and use strap for glue to cure. After the glue is cured, attache the legs and the trucks.
You now have a table, with minimal risk of failure.
wilgubeast 10 years ago
mganpate 11 years ago
Woodyouliketo 11 years ago
beerd 11 years ago
I'd love the pro membership if it's still available!
wilgubeast 11 years ago
trainables 12 years ago
wilgubeast 12 years ago
I'd love to see a fluffy, motorized version. Bonus points for lasers, an Arduino, and lasers.
curious youth 12 years ago
Giles Farmer 12 years ago
Pics here:
http://www.flickr.com/photos/gilesfarmer/
Robert_Britt 12 years ago
valhallas_end 12 years ago
If you can't remove the rotation eccentricity, an easy solution would be to grind a center hole and place a small shaft pin at the center of your table - a good holdfast for the whole glass plate that wouldn't be very visible. Plus you could actually use a skateboard wheel and bearing in a larger center hole if you wanted to up the skater vibe...
