Soap Carving for Casting
Intro: Soap Carving for Casting
How to carve a bar of soap into a smaller soap shape. Discussion of various tools that can be used for this purpose. A little silliness - the carving I made is a kind of slug thing - I'm going to cast it in plastic and glue one googly eye to the upturning end. See the flat part?
STEP 1: Outline the Basic Shape
Draw a side elevation of the shape you'll carve on the side of the soap. Starting with 2-D on one side of the block is a good way to start thinking in 3-D.
STEP 2: Carve Out the Basic Shape
I started doing this carving with a Dremel tool, but quickly found that a knife worked much better for the coarse work. Ivory soap at least is quite soft and carves easily. I tried a cutting blade and a grinding disk. The grinding disk is more effective than the cutting blade but both are slower than knife.
STEP 3: Do the Fine Carving
For smoothing out the edges, the Dremel works better than a knife, especially a serrated one. Try several different grinding bits depending on the shape you're working with.
STEP 4: It's Soap, Wash It.
For a final smoothing, soap as a medium has this great advantage that it dissolves in water. I didn't want to put it under the tap at first, but really, soap doesn't go away all at once. You do have to rub at it. A wet finger isn't enough - dunk that baby.
I could have gotten this smoother if I'd put more effort into it, but I decided it was Fine. SO my slug will be a bit lumpy... that's OK.
13 Comments
BubbleDragon 17 years ago
rachel 17 years ago
mg0930mg 14 years ago
zachninme 16 years ago
rachel 16 years ago
(for those of you who are Confused, see here)
Kaiven 15 years ago
uniquesoaps 16 years ago
dremmel 17 years ago
gigman 17 years ago
rachel 17 years ago
mrmath 17 years ago
rotor 17 years ago
Murf 17 years ago
