Solar Food Dehydrator (Dryer)
Intro: Solar Food Dehydrator (Dryer)
Dry your fruit, vegetables, and other goods with your own sun powered dehydrator. Electric Food Dehydrators can be expensive and consume unnecessary energy.
This solar dehydrator was made entirely of recovered materials. It was constructed with scrap ply wood, 2x4s from an old ladder, a house window, and other items which could be considered trash. It was created as a project at Maharishi University of Management in Fairfield, Iowa.
Why We Dry: Removal of moisture prevents bacteria from ruining your values fruits and vegetables. Drying is a form of preservation.
STEP 1: Learn the Design
Become familiar with the design to minimize mistakes...
There are vents underneath in the front which are hidden in this picture. The darker section is a piece of heat absorbent material, we used painted metal for this particular dehydrator, but other materials will do as long as they are dark. The food itself is placed on the shelf, which will be made out of a cloth screen. Other screen-like materials can be used, but take chemical leeching into consideration to prevent contamination. The back piece of ply wood can be opened to remove the shelf and provide additional ventilation.
STEP 2: Find Materials
Thin Ply Wood (Body)
4 2.5' Long 2" x 4"s
10 feet of 2" x 2" wood (Braces and drying shelf support)
A Window (20" x 23 1/8") or a suitable slab of clear plastic.
Screen (For covering vents)
Stretchable Cloth/Material. We used stalkings. (For drying rack)
2 Hinges
Screws
Staples
Thermometer
A Hook & String (To fasten the rear door)
Caulk (For perfectionists)
2 Hinges
Screws
Staples
Thermometer
STEP 3: Size Pieces
Here is a checklist for the plywood pieces.
-1' x 23 1/4"' (Top)
- TWO 20" x 12" x 26 1/8" x 14 1/8" (Sides) This has a diagonal cut.
-26 1/8" x 23 1/16" (Bottom) This will be trimmed to fit legs and vents.
-14 1/8" x 23 1/16" (Back) This will be on hinges.
*Careful Cutting
*Careful Cutting
STEP 4: Assemble Frame
A. Cut 2" x 4" notches out on the bottom ply wood piece for legs. Cut out 2" x 4" slits for ventilation.
B. Construct base first as pictured.
C. Fasten side pieces of ply wood to legs.
D. Attach rear ply wood piece.
E. Screw 2" x 2" on top of side pieces to anchor the top piece. (This is more clear after viewing the second picture on this step)
*Drill then screw to prevent splitting
STEP 5: Additional Components
A. Size and Insert heat absorbent shelf (Approximately 23" x 20") . This rests on the top of the legs.
B. Construct drying screen by stretching and stapling material over a 14" x 22 1/2" frame constructed of 2" x 2" pieces.
C. Cut and attach support piece for drying screen.
D. Attach the window. Caulking the borders is recommended, but if the window is flush against the frame, then caulking is optional.
E. Cover vents with screen material to protect from insects.
F. Place thermometer inside, ideally close to the drying screen rack.
*Clean parts before adding them
STEP 6: Dehydration Tips
A. Dehydration will occur between 100 and 140 degrees Fahrenheit. Any lower and bacteria can grow, any higher and it will be cooking. In order to achieve this balance the rear door may need to be left ajar.
B. Different fruits and vegetables have different optimum drying temperature ranges. Research what you are drying to find this out.
C. Remember to store your result in a dry place.
Thank you for reading our directions!
49 Comments
shari.weiss7 3 years ago
Luckily I live in Phoenix and we fry eggs on the sidewalk. I’ll have to add cooling features!😂
abhalight 2 years ago
SachinK143 4 years ago
Briera 4 years ago
KrishnaK198 4 years ago
gcai_fwb 14 years ago
However for use in more northern climes the sun is not enough during the cooler months and we have to resort to electrical methods.
Rather than using a stand alone dehydrator I've found a single 100W incandescent light bulb placed at the bottom of the oven of my stove works very well, creating sustained 150-160 degree heat. I've added a light dimmer to vary the bulb intensity ie. a heat control - a little expermentation and I have a cheap and effective dehydrator with relatively low running costs. For more heat add light bulbs or a combination of different wattages.
Note: CFL bulbs will NOT create the desired heat.
afridave 13 years ago
madwilliamflint 13 years ago
Isn't it a bit loud?
diy_bloke 10 years ago
Nothing like having yr jerky done in 5 minutes :-)
(Sorry, the idea is stolen from 'Tool Time' in which Tim Allen builds 'a manś kitchen', using an acetylene blow torch to roast turkey. Could not resist :-) )
afridave 8 years ago
I have seen people braaing meat with a blowtorch...
diy_bloke 8 years ago
Now I know you are from South Africa :-) 'braaing'
indeed....we braai regularly...superb way to socialize on a sunny sunday afternoon...chops, wors ,steak, ribs, pap en sous, beer...what else could you wish for?
well I could mention a couple of things to still wish for :-)
'braai' no doubt related to dutch (verb) 'braden' or (colloq) 'braaien'
indeed.....we also do something on a fire which we call a pootjie...it is basically a dutch oven type stew....pootjie means little feet....a poot being a foot...this is derived from the tripod feet on a popular form of cast iron pot...some people take great care and pride and are infact experts at the pootjie cooking...very tasty
interesting. Maybe not from the tripod but directly from 'potje' (a [small] pot). Often used in food relation: potje koken, wat de pot schaft,etc
you may be right....not sure why the feet idea is stuck in my head...I think its because i have heard the pot described as a driepootjie...
I myself am english born and speaking but have lived is south africa all my life...afrikaans is my second language...i could however maintain a decent conversation with a dutch speaking person and it would not take long for me to speak almost fluent dutch..
I can top that :-) seen someone fry a Turky with dynamite: He fried and sliced it at the same time
