Soldering Iron to Soldering Tweezer Conversion
Intro: Soldering Iron to Soldering Tweezer Conversion
Hi.
In nowadays, lots of electronics are using SMD components, repairing such details with no specific equipment is tricky. Even if you need to replace the SMD LED, soldering and desoldering could be challenging without a heat fan or soldering tweezer. In my case, purchasing such not cheap device is not sensible. After some time of thinking, I decided to use only the stuff that already has.
Many of us have a couple of soldering irons and often they're identical, in my case, it's the same situation. I took a couple of soldering irons and created and hinge, with a tension spring in it. Now I can snap a couple of soldering irons and get a soldering tweezer, with separate temperature adjustment for each tip.
In this instructable, I'm delighted to share my implementation of such conversion with you.
STEP 1: Hinge Models
When I've started designing this hinge, decided to add some features. One of them is a range limit grove, it prevents moving solders on a huge distance and makes the tweezer handier. Another one is a grove for the spring, with its help spring will never slip and doesn't require extra materials or tools to fix it in place.
Models are ready for printing and could be printed with 0.2 mm layer thickness. Better to print with supports.
STEP 2: Assembling the Tweezer
This step is very easy and could be understood by images only.
#1 Install nuts in the inner hinge
#2 Install the spring on both hinges
#3 Place the screws on their places and tight them a little bit
#4 Snap the soldering irons on their places
STEP 3: Test!
After assembly, I've made a test recording that shows the soldering and desoldering process of the SMD components on the broken motherboard from a 3D printer and some other parts.
If you like it, please vote.
Thank you for reading!
15 Comments
jorbe 1 year ago
JulianoS12 3 years ago
IgorM92 3 years ago
You can buy this kind of soldering iron anyway you like, like here on amazon https://www.amazon.com/s?k=cxg+936d&crid=3HG57ULPV...
or here
https://www.aliexpress.com/wholesale?catId=0&initi...
If you have any other questions, do not hesitate to ask.
Yonatan24 3 years ago
IgorM92 3 years ago
xenoscientific 4 years ago
IgorM92 4 years ago
This conversion idea helps a lot.
ronopotomusjones 4 years ago
IgorM92 4 years ago
Enjoy this thing. Happy to share interesting ideas.
samcpt 4 years ago
IgorM92 4 years ago
Sad to hear that you also had a problem with your board. This one, which I've used had a problem with bed temperature monitoring (incorrect temperature was displayed and jumped a lot during printing) and skipped steps. After some investigation, I figured out that the board has a crack somewhere.
ajoyraman 4 years ago
IgorM92 4 years ago
Great question…
Soldering could be done in the same easy-peasy way, just recorded a video
https://youtu.be/SLrGismX2_c
(also updated the last step in instructable)
Kind regards, Igor
Hey Jude 4 years ago
You may also like this: https://www.instructables.com/id/How-to-Make-a-Solder-Buddy-from-sheet-plastic/
IgorM92 4 years ago
Your idea also cool.
