Stainless Steel IPhone Case W/Belt Loop
Intro: Stainless Steel IPhone Case W/Belt Loop
Several years ago I had Sony PDA in my pocket while under my truck. When I rolled over, I heard the crunch of my screen breaking. I needed a belt case for my iPhone and didn't want that to happen again. I was inspired by an instructable by Phil B's https://www.instructables.com/id/iPhone-Case-of-Polished-Metal/ to make a metal case.
Yesterday i made this stainless steel belt case for my newly acquired iPhone 4. Like most of you, I wanted to protect it from screen damage, but I have an affinity for SS, so I made it out of scrap SS I had picked up some time back at the salvage yard for just such a project.
Stainless is a difficult metal to work with, but well worth the effort. I welded it with my MIG wire welder using SS wire and ground down the tack welds. I was having trouble getting the front "mirror smooth" so I did some "engine turning" on the front. I used a sandpaper roll on my milling machine and it came out better than I expected.
I lined it inside with thin leather on the front, sides and bottom. A trial fit told me it would be too tight using the .070" leather, so I use a cloth backed vinyl upholstery on the front that measured .040. I used contact cement to glue the lining inside. The phone fits perfect with a little bit of drag and it is easy to remove using my finger through the hole in the bottom..
3 Comments
Phil B 10 years ago
graydog111 10 years ago
I found that piece of metal and it was the exact size I needed, saving a lot of time and work. That does not happen very often. Making it took me about 4 hours because SS is so hard to cut and grind. Old men need to keep busy so I am not complaining, just sore today. Being 77, I am finding that growing old is not all it is cracked up to be.
Phil B 10 years ago
My belt loop allows the phone to tip out from my body a little when I slide the holster upward on the belt. My belt is thin enough that I can angle the front of the holster downward for more comfort.
