Homemade Steampunk Paintball Gun
Intro: Homemade Steampunk Paintball Gun
An updated version of my last gun, it's a lot more compact and easier to hold and fire, along with having all these smashing features:
Breech loading bolt.
Single spring actuated ball valve.
Pistol grip with two stage trigger with removable safety.
Fully functioning adjustable rear sight.
360 fps muzzle velocity with a 68 cal paintball.
It's not intended to be used in matches but it was great fun to build, and pretty nice to shoot!
(also it says on the pictures "05/10/2006" it wasn't actually taken then, my camera c**cked up the previous day and so reset it's date.)
20 Comments
Alexws11 7 years ago
Rdav- 7 years ago
See my response to itisnot_me
MohammadY11 8 years ago
I like tis .... is it important to place the pressure pumb. Plz reply soon
Rdav- 8 years ago
..I'm not quite sure what you're asking?... can you re-phrase?
itisnot_me 8 years ago
Hey,
Could you expand more on how you made this.
Rdav- 8 years ago
Well it was quite a while ago, but I'll give it shot.
The framework, and essential gas containing components were made using standard pvc-welded joints.
The rest of the features, 'stock' grips and such were made out of pvc that I used a heat gun to soften, then mould into the correct shapes, holes and slots where done with a drill and a file (and tin snips to cut out the larger areas) and then I hot-welded the non-structral pieces (melting and fusing them together, rather than using a filler material) together using a tip of a hot glue gun, which holds them really quite tight, even to this day the thing is still intact and looking as good as it did back then. (there are plenty of more detailed instructions on pvc moulding etc on Instructables if you want to search around for them)
With regards to the mechanism, that was made fairly rag-tag out of bits that I just had around, a sawed off part of an old bike is the bolt, and some cut and moulded pvc for the trigger, as long as it serves the basic function it doesn't really matter what it is, or used to be.
Anything specific you'd like to know?
sillywilly 11 years ago
Rdav- 11 years ago
Attached to the running bolt (the grey bit) is a bolt handle, which is connected to a ball valve via a piece of cable, the bolt is cocked prior to firing (cocking consisting of pulling the bolt back until it latches onto the sear) and the ball valve is closed.
The breech is opened via a small hatchway opened by retracting another bolt (the breech bolt) on the barrel, and whatever you are going to fire is loaded in, after that the bolt is closed and the gun is pressurised. The final stage is firing, the sight for the gun can be adjusted by moving a small screw on the sight, which adjusts elevation, so fine tuning is possible (albeit not very necessary on a smoothbore gun) once you are ready to fire, the safety (consisting of a small removable steel that stops the sear moving back) - is removed and the trigger is pulled, the movement of the trigger moving is then transferred to the sear which rotates (shown in diagram) so that the running bolt is released and is forced forward with high speed, pulling on the cable opening the ball valve and discharging the gun.
Hope that helps, :D
motleyjust 11 years ago
TruFord 10 years ago
Iam not fully sure but this gentleman posted another instructable ( https://www.instructables.com/id/Home-made-Paintball-Gun-Metal-Denting-1/ ) in there he pressurizes a pvc pipe using a bike pump. On that page he also mentions making the final version and posting a picture to this instructable. So my guess is he used the same methods as shown in the posted link to make this shoot. He uses a ball valved connected to s spring loaded trigger system. Since a human wouldnt be able to twist the ball valve fast enough to allow for a even and full force to be applied to the ball. So to answer your questions there's a pressure chamber in the stock of the gun that is pressurized by using a bike tire pump. (atleast thats what Iam lead to believe by his other instructable.) I would think one would be able to make a spring loaded/airtight piston (similar to spring loaded airsoft rifles) that would achieve similar results by pulling back a spring loaded chamber. When released it would force all the air down the barrel propelling the paintball.
hockeymonkey81 10 years ago
plz make an ible plz!!!!!!!!!!!!!!!!
poil87 10 years ago
SMOKINACE99 10 years ago
-Rook 10 years ago
Rdav- 10 years ago
tdfa98 11 years ago
DIY and STUFF 11 years ago
Rdav- 11 years ago
solidfunk 12 years ago
Rdav- 12 years ago
