Supa-Hula (a Very Big Hula-hoop Made From Plastic Electrical Conduit)
Intro: Supa-Hula (a Very Big Hula-hoop Made From Plastic Electrical Conduit)
STEP 1: Materials:
Plastic electrical conduit.
It is 10 feet long and has a flare at one end that makes it a connector. (Also - I want this sweet pvc cutter )
Best luck with 2 pieces of 3/4"
3 pieces did not stay together but could be glued with PVC cement (the 2 part stuff that smells terrible)
A regular size hoop can be made with a 1/2" piece.
The conduit costs a dollar or two per piece. It is extremely rugged stuff.
STEP 2: Connect
STEP 3: Bend
STEP 4: Connect Other End
STEP 5: Hula-Hoop
STEP 6: 30fter
STEP 7: Jack Says Hi
STEP 8: Hazel Has a Little One
Here is a 1/2" conduit.
STEP 9: Have Fun!
They are also fun to roll and jump through.
28 Comments
JamieW127 7 years ago
This is so cool. Do you think this material would support a vine? I'm planning on creating some privacy in my yard with four honeysuckle vines, and I really want the round shape but four round-topped arbors would be WAY too expensive. Gag. Do you think if each end of the conduit were attached to a fence post it would hold its shape? Thank you for your time!
marc.cryan 7 years ago
JeriE1 8 years ago
Elleisse 7 years ago
Try Fiber-Fix Repair Wrap from Home Depot or Lowes. When you wet the wrap it hardens like steel. You can wrap the wet wrap around the hoop and allow to harden, thus making it a stable, durable hardened hoop. However, keep in mind that the hoop will harden like steel and therefore should be applied and set inside the room you intend to hang your canopy (in the event it is too large to fit in the door). For removal at a later date you will likely have to cut through the hoop with an electrical tool. Make sure to reinforce ceiling hooks. I'm not sure how much weight it would end up being, but worth a try. You can try a search of videos for a demonstration or commercial on the product. I originally saw it on SharkTank years ago being demonstrated. Impressive stuff.
blakemenezes 10 years ago
If you have any questions, please contact me at blake.menezes@autodesk.com
Best,
Blake Menezes
Autodesk Social Media Strategist
marc.cryan 10 years ago
dddddd 10 years ago
I used a little over 20 feet of 1 inch inside diameter inch high pressure polyethylene line (the kind they use for submersible well pumps), and held it together at the ends with a scrap of 1 inch outside diameter plastic pipe and a few turns of gaffer's tape.
You're hooping at about 95 RPM, and mine is comfortable at about 60 RPM. I suspect mine is a little heavier.
I've gotta' think about hoop size/weight vs RPM. I think is the size, with bigger slower. Heavier hoops seem easier.... angular momentum?
dddddd 10 years ago
I've got some sunburned plastic electrical conduit lying around, so I'll give it a try, and see if the light-versus-heavy thing makes sense.
I think rigid is important in a hoop, and slower is better than faster for me, because my hips don't move that way very easily or very fast :-)
mainah 10 years ago
ndjalva 10 years ago
You are nuts.
calgirlya 10 years ago
dr acula 10 years ago
dawnorama 10 years ago
Jessica316 10 years ago
lmnopeas 10 years ago
justbennett 10 years ago
