Super Nintendo Hard Drive
Intro: Super Nintendo Hard Drive
I had an old SNES game that didn't work any more, but I didn't want to throw it away. I stumbled upon a cool use for it - an external hard drive enclosure!
I've seen people put hard disks and larger SSDs into SNES cartridges, but not a M.2 (2280) SSD which I also had laying around, so I thought I'd give it a try and share my process.
One thing I tried hard to achieve was to make the cartridge appear stock, unless you look at the bottom of it. I didn't want to have any cutouts or openings on the sides, which would make it look like less of a clean build.
If you have any interest in seeing some of my other projects - check out my channel: Franklinstein
STEP 1: Open Cartridge and Remove PCB
- Open the cartridge with these special adapter bits for SNES screws: https://amzn.to/3QjwgPl
- Remove the PCB
STEP 2: Cut Internals on Cartridge
There are a few areas of the internal cartridge structure that will need to be removed to allow the SSD and adapter to fit inside. See image below for reference.
STEP 3: 3D Print SSD Adapter and Other Parts
- Print the SSD adapter
- Print the adapter clamping straps (2x)
- Print the bulkhead adapter
- Tap the SSD adapter holes to #4-40
- Countersink the holes on the adapter clamping straps (not required, but looks cleaner)
- If you don't have a printer - you can print the files here
STEP 4: Assembly
Let's put everything together!
- Add foam tape to one side of straps
- Apply double sided tape to underside of SSD adapter
- Insert SSD adapter into rear cartridge - press firmly to allow tape to adhere
- Insert SSD into adapter
- Install USB-C cable into SSD
- Bolt clamping straps on to hold it in place
- Bolt bulkhead adapter to bulkhead fitting of USB-C cable
- Apply double sided tape to bulkhead adapter
- Install bulkhead fitting as shown
- Reassemble upper half and screw everything back together - you're done!
STEP 5: Design a Custom Game Sticker
One of my favorite parts of this project was designing a super custom label for my cartridge. You should do the same!
- Here is the template I started out with
- I used Canva to edit everything
- I printed my stickers with Avery labels
STEP 6: Project Complete!
Now you can show off your super unique hard drive, with a custom game sticker.
Enjoy!
10 Comments
WUVIE 8 months ago
DavidA26 8 months ago
sirjason132 8 months ago
Safirelibra 8 months ago
BrockGrimes 8 months ago
siviafamily5 8 months ago
cheez 8 months ago
bob2021 8 months ago
I hope you meant āthe box in the garage thatās being taken to the recycling centreā. Up-cycling shouldn't also be wasteful. ā»ļø
