Super Easy to Make Portable Speakers for Mp3/ipod
Intro: Super Easy to Make Portable Speakers for Mp3/ipod
I didn't want to fork out loads of money on portable speakers.
So I didn't
And made some.
These are powered by a battery.
They are incredibly easy to make I'm 14 I did it!
As ever I am not responsible if it doesn't work or goes wrong.
Try it at your own risk.
This is easy because the speakers already have and amplifier and controls built in. They are very loud and very clear.
These cost me about £2 (50p for the speakers and £1.50 for the battery) I had a spare connector lying around.
What you need
Some computer speakers powered by the main. ( I found mine at a car boot sale for 50p!!!!!!!!!!!)
Electrical insulation tape or you could solder
A 9volt battery
A 9volt battery connector.
What ever casing/box you want to put it in.
So I didn't
And made some.
What you need
A 9volt battery
STEP 1: Getting Started
Remove all the casing from around the computer speakers Do not cut any cables.
Find the pack that converts the voltage from mains (240) to 12 or whatever the circuit runs at.
cut the cable running between the pack and the circuit board.
STEP 2: Adding the Battery Connector
Where the cables came off the converter simply connect them onto the battery connector. Positive to Positive and Negative to Negative. You could solder but I just wrapped them around and then put he tape over the top.
The yellow wire with the black tape on is not in use
STEP 3: How Easy Was That
Add the battery on turn it on and plug in your mp3 player.
And create whatever case you want for it.
Mine is yet to have a case because I'm not sure if I want to connect all 4 speakers. Because then it wouldn't be too portable.
Easy.
Any queries get in touch I will try to assist.
Any suggestion get in touch
Good luck
With 2 tweeters and 2 woofers it can be very loud!! : )
Easy.
Good luck
27 Comments
Anand Kachale 8 years ago
hey i have a speaker but it does not have any amplifier circuit to control it. Can i take it from a 4.1 home theater sub-woofer??
Aron Rc RC 8 years ago
!!!!!!!It is a awsome speaker dude!!!!!!!!
MUSIC650 12 years ago
thanks
hsarode1 12 years ago
mattyuke 12 years ago
I wouldn't think so because the voltage will fluctuate as that is what makes the speakers vibrate at different frequencies, and you wouldn't get a clear reading.
Why do you want to measure the output voltage of the audio output?
Matt
blizard.wizard 14 years ago
Mirc_El 13 years ago
Find the biggest capacitor on the board (that's the main filter) and measure the voltage there while it's running. The voltage is different from the transformer output (usually higher) because the alternative current is converted to DC. Don't short any contacts on the board while doing it! That should be the operating voltage. You should solder the battery contacts to that capacitor. Be aware of the polarity! Usually the capacitor has a black stripe (a minus) on the negative side. The transformer on my speakers said 9V output (in reality it gave 10 volts, but under no load). The main filter capacitor voltage was 14V! Though, it should be around 12V under load. (chinese speakers with too small components for it's output).
mattyuke 13 years ago
Thanks
mattyuke 14 years ago
paintsniper 14 years ago
skywalker619 13 years ago
lawrenzium 14 years ago
https://www.instructables.com/id/Portable-Tennis-Ball-Speaker-for-Mp3-Ipod/
