Superman Stamped Card
Intro: Superman Stamped Card
My Hubby and I were married 4 days before Christmas. We came to the agreement that we would not exchange gifts on our anniversary, after all Christmas was only 4 days away. Instead we create cards for each other. I usually scrapbook mine and he creates his on the computer. This is an Instructable on how I created the stamp which is the main part of this year’s Anniversary card. Here we go.
STEP 1:
Supplies: (not everything is shown on the picture)
Blue cardstock (8.5”x11” folded in half)
White cardstock
Black “Staz On” stamp pad (+/- $8)
Cricut machine
Sure Cuts a Lot Computer program (no longer available for the Cricut, they lost the law suit)
Cricut Deep Cut Blade & Housing ($29.00 at http://www.cricutmachine.com)
Cricut Stamp Refills ($9.99 at http://www.cricutmachine.com/product_info.php?products_id=243)
12”x12” new cutting mat (not shown)
Piece of clear acrylic for the base for the stamp (left over from another project)
Access to Internet
A variety of coloring mediums (crayons, markers, pastel chalks, water color pencils, and Gamsol Magic supplies, or whatever you like)
Double stick tape
White cardstock
Cricut machine
Access to Internet
Double stick tape
STEP 2:
I made my hubby a Superman t-shirt for Christmas. So I decided to make an anniversary card to go with it. First I did a Google search for a Superman symbol. I found the one that would make a great stamp. I saved it onto my hard drive. Then I opened the Sure Cuts a Lot program. I clicked on the picture symbol and then found the Superman symbol on the hard drive and opened it up.
STEP 3:
Clicked on preview and it was just what I wanted for a stamp. I clicked on okay and it appeared on the on screen mat.
STEP 4:
I clicked and dragged the symbol in the upper left hand corner and I made it smaller by clicking and dragging the lower right hand corner.
STEP 5:
I wanted to make a card that is 5.5” x 8.5” (this fits anA7 envelope). So I made it about 4 inches tall. The symbol is wider than it is tall. #1 is the button for locating the picture. #2 is the spot to resize the picture and #3 is where you click to cut.
STEP 6:
Next I opened my Cricut machine and I exchanged my regular blade housing (green)
STEP 7:
for my deep cut blade housing (blue).
STEP 8:
I put the 6”x6” piece of Cricut Stamp Refill in the upper right hand corner of the brand new mat and I loaded the mat into the machine. The blade length was set at 4.5 and the pressure 4.
STEP 9:
I clicked on the cut Icon and the program brought up that it was connected to the Cricut and started to cut.
STEP 10:
Soon it was done and I unloaded it from the machine.
STEP 11:
I weeded away the parts I didn’t need for my stamp
STEP 12:
and I put the Superman symbol out line on to the acrylic block that I had. Remember to but it on the block backwards, so that when you stamp it, it will read right. It is delicate enough that it took a little bit to get the lines straight. That looks good.
STEP 13:
I inked the stamp with the Staz On ink pad. I use Staz On because it is a permanent ink that wouldn’t smear if gotten wet. It will stick to almost anything.
STEP 14:
Anyway, I stamped 5 copies of the stamp on white cardstock.
STEP 15:
Then I proceeded to color each one with a different method. I then cut each one out and put it up against blue paper. The one I like best will go on my card. #1 Crayon, #2 Marker, #3 pastel chalk, #4 water color pencil, and #5 Gamsol magic (I used this method here: https://www.instructables.com/id/How-to-Color-a-Valentines-or-Any-Other-Card-with/) See if you can tell which one I liked the best.
STEP 16:
Yep, that’s the one I like best. I used double stick tape and attached it to the front of my card. Of course the inside says. “You are my Superman!” (Blush) Enjoy!
