How to Make a Survival Knife From a Sawblade
Intro: How to Make a Survival Knife From a Sawblade
This tutorial is how to make a survival/hunting knife using a few basic materials. It cost me nothing since I already had an old sawblade laying around.
SUPPLIES...
Circular Saw Blade
Dremel Tool with attachments
Safety Glasses
Other Optional Supplies:
Fine Sandpaper
Steel Wool
Steel File/s
Gloves
Wood (for handle)
SUPPLIES...
Circular Saw Blade
Safety Glasses
Fine Sandpaper
Steel Wool
Steel File/s
Gloves
Wood (for handle)
STEP 1: Drawing the Pattern
When drawing the pattern, keep in mind that you should save room for a handle. Besides that the possibilities are almost limitless. I used a black sharpie marker and drew directly on the blade.
STEP 2: Cutting the Blade
This is probably the hardest step. Keep following your pattern and be prepared to go through about 15-20 light cut-off disks (if you use better disks, you will save yourself a lot of time) If your dremel has variable speed settings, turn it to the highest speed. This step takes a lot of time so take some breaks in between.
STEP 3: Sanding
The blade at this point should look pretty crude. If you have a sanding bit attachment for your dremel, it works perfectly. Otherwise use another tool or use rough graded sandpaper and steel wool.
STEP 4: Polishing
After the blade is sanded down, it is time to polish it. I prefer using soft grade sandpaper and steel wool instead of power tools. After polishing, apply a thin coat of oil. Motor oil and vegetable oil both work great. The oil will also help prevent rust.
STEP 5: Handle
The handle material can be almost any material you want. Wood, plastic, rubber and even string can all make great handles. Mine is made out of a single strand of paracord. If you prefer a more "permanent" handle, take two thin slabs of wood and use two to three rivets to bolt them together.
STEP 6: Finished Knife
The finished knife is very satisfactory. It took me two afternoons to make but it was worth it. Its solid and very lightweight. I am thinking about making a sheath to match. I hope you enjoyed this tutorial. Please rate and comment! :)
If you made a knife like this, put a picture below for others to see.
6 Comments
jenuram 10 years ago
jackowens 10 years ago
ironsmiter 12 years ago
only the carbide teeth(on the authors bade) are hard.
This is a very good material, if you're just learning about knives.
It'll force you to sharpen a LOT more frequently.
and practice makes better.
that's why cubscout and boyscout knives are always going dull.
It's on purpose ;-)
IF one of your blade blank lines is straight, I'd suggest going for a score and snap method. Score the line a few MM deep with the dremel, then clamp in a vice just below the score, and bend. You SHOULD get a nice, satisfying 'snap'. If it bends instead, just bend back and forth a few times, like you would a pop tab, on a can of soda. It'll go :-)
Also, being mild steel, a hacksaw with a nice sharp new blade, will cut nearly as quickly as a dremel, with a mini cutoff blade. more armwork, but less consumables.
jackowens 12 years ago
stormy0314 12 years ago
