Slim Fit T-Shirt Mod
Intro: Slim Fit T-Shirt Mod
I have a bunch of great logo tee-shirts but they're cut for men and I don't like the way they fit, so today I'm going to show you how to mod your t-shirts into a flattering shape that you'll actually wear, using a serger.
For this project, you will need:
- Girly-tee that fits you, to use as a guide
- Baggy tee that fits you around the collar
- Serger (ask around to see if a friend will let you borrow) with thread
- Sewing pins
- Tailors chalk
- Scissors
To keep up with what I'm working on, follow me on YouTube, Instagram, Twitter, Pinterest, and subscribe to my newsletter. As an Amazon Associate I earn from qualifying purchases you make using my affiliate links.
STEP 1:
First, iron your shirts and turn them inside-out. Line up the template at the shoulders and trace around it with tailor's chalk.
STEP 2:
Pin along the new side seams, and cut off the sleeves at the new armhole. Run the new side seams through the serger.
30 Comments
JenaR3 5 years ago
bekathwia 5 years ago
erlns 9 years ago
Great tutorial, I made it and my t-shirt now fit me perfectly :)
Thank you, keep the awesome work !
Greetings from Colombia.
yolanda.sutherland 9 years ago
Excellent! Just what I needed. How about crew neck to V neck? ;-)
CelinaF1 9 years ago
I've used this tutorial 3 times now and it's a great idea. One thing I didn't keep in mind, though, is the seam allowance. So I lost 1/4" all the way around and my modded t's are all really tight now. Just wanted to point this out so peeps wouldn't make the same mistake I made. :)
mvd011244 10 years ago
Aswa 10 years ago
I just got an affordable one and couldn't wait to try this, as I have a pile of band shirts I've been wanting to adjust. I always get mens' shirts rather than girlies, because the material is usually sturdier, and the designs are bigger and cooler, and also, most girlies are way short.
So I finally got to try this, and I must say this is probably the most straight-forward and easiest tutorial I've seen for this kind of mod.
At first I was sceptical, but it's like magic!
Boxy to foxy, indeed!
Adjusted 3 shirts so far and will work my way through the pile. It's as if I had been on a massive shoping trip, suddenly I have so much more to wear! ;)
Thank you so much for sharing this. :)
theowoo 10 years ago
Fretka 12 years ago
I found your 'ible and was able to mod my prized tees that I couldn't wear any longer due to a major weight loss ( 120 lbs !!)
my thanks and...here are my prized tees I was able to alter !!!
lilsurelybeans 12 years ago
I also agree with HVANSICK. You don't need a serger to do this. My old 1970s zig zag machine sews jersey just fine.
I use a size 11 needle and stretch stitch foot. I straight stitch the seams (according the to straight stretch stitch settings in my manual). Then I use a pineleaf stretch stitch on the edge to overcast a neat edge on the raw edge. My machine also has an overcast stretch stitch that will fix the raw edges and stitch the seam at the same time, but I usually do them separately.
Just read your manual. It will tell you what stitches to use with what fabrics. If you have an old machine without a manual, a lot of manuals/tutorials are online too.
Toboe 12 years ago
Fishpail 12 years ago
...no wait they have manuals for that, the hardest part is FINDING a serger.
As a university student living on her own. I'm run out of luck on this. Cause DAMN they're pricey! Even used!
Still, great ible!
sarimsaq 13 years ago
bekathwia 13 years ago
Wolf Seril 13 years ago
I'm a guy, but I'm tall and skinny, so normally I have to choose between a shirt that fits well but barely reaches my belt, or a shirt that is the right length but could fit two of me.
locofocos 13 years ago
Treknology 13 years ago
@ locofocos
In both cases find a shirt that fits the shoulders and arms, and it is worth the expense of going to a professional and sacrificing those t-shirts to have a proper set of cardboard "blocks" made that will then incorporate the length you require.
Once you have your custom "blocks", you can cut as many t-shirts as you want, widening them if you want a sloppy fit or narrowing them to get that "I'm Tom Cruise, check out my lack of muscles" look--if you really want the body-conscious tight look, use double-ribbed fabric instead of plain Jersey.
And yes, Fabric shops will often help out guys, just as electronic shops will help out females, because there's a recognized imbalance in these fields, and therefore people seek to increase the under-represented group.
As far as self-teaching, pick up a rough machine at a garage sale, using any colored thread, and just start sewing lines and patterns into old bits of fabric--towels, handkerchiefs, torn t-shirts.
Obviously, based on my NIC, I would rather just request the right item from the Relicator, but they haven't eventuated yet, so making them is your best choice.
makalove 13 years ago
Personally, i'm fine with instructables that contain video that adds to the instructable, but i dislike instructables that aren't usable without their video component, particularly when the video doesn't have any closed captioning available.
And don't be ashamed to be male and able to use sewing equipment. I am a qualified commercial sewing machinist.
