Taking Advantage of Bulk Burger Prices!
Intro: Taking Advantage of Bulk Burger Prices!
How many times have you seen ads in the paper for ridiculously low prices on bulk ground beef. Then you ask yourself what am I going to do with a 5, 10 or 15 pounds of ground meat? Ive seen people throw 5 lb bags of ground meat in the freezer. Which is fine as long as you remember to get it out 4 days before you are going to use it.
Ive found a better way, repackage it into smaller portions. I portion them into 1 quart zip lock bags then make them about one inch thick so they thaw out in no time.
You will need:
Several 1 Quart Zip Lock Bags
Kitchen Scale
Sharpie or Magic Marker
You will need:
Kitchen Scale
STEP 1: Label Your Bags
I had a 6+ pound bag of bulk hamburger. So I labeled 5 bags 1lb. You can date them too if you want, mine doesn't usually last that long.
STEP 2: Weigh the Meat
I then grabbed a wad of burger and put it in the bag and set it on the scale.
STEP 3: Fine Tune the Weight
Then you add a little more, or take some away, until you reach 1 lb (or so)
STEP 4: Pack and Flatten
Then pack and flatten the meat into the bag. This makes for easy thawing later. It also cuts down on freezer burn.
STEP 5: Weigh the Last Bag and Put in Freezer
When you get to the last bag label it accordingly, I had 1.5 lbs left. Then your ready to pop them into the freezer.
So get out there and stock up your freezer with bargain basement meat. You will be glad you did.
25 Comments
robersona 10 years ago
lemonie 15 years ago
JDBennett 11 years ago
caitlinsdad 15 years ago
jello666 13 years ago
Joe Martin 15 years ago
tecneeq 15 years ago
MAP
L
acesnanna 15 years ago
JDBennett 15 years ago
pansartax 15 years ago
thematthatter 15 years ago
l8nite 15 years ago
