Talk to an Arduino With an IOS Device Using Bluetooth Low Energy
Intro: Talk to an Arduino With an IOS Device Using Bluetooth Low Energy
For this project you will need
an Arduino (we'll use the Leonardo)
an iPhone 4s, 5, iPad 3, 4, mini, or an iPod Touch 5th generation.
Bluetooth Low Energy Shield from Red Bear Labs (http://redbearlab.com/bleshield/)
4 or 5 LEDs
a momentary push switch
some wire
a bread board or proto-shield
Red Bear lab's provide an app in the App Store that is general purpose enough to get your BLE-compaitble ios device talking to the shield, but what if we want to take it a little farther, and write our own custom app? Well thats what we are going to cover today.
NOTE!!! TO RUN A CUSTOM APP ON YOUR IOS DEVICE THAT IS NOT IN THE APP STORE YOU WILL NEED TO BE ENROLLED IN THE IOS DEVELOPER PROGRAM WITH APPLE. it is $100 dollars and is not not covered in this tutorial.
STEP 1: Wire Up the Arduino.
The BLE shield uses Pin 8 and 9 to do its stuff, so its a good idea to leave those alone.
the positive terminals from our LEDs will be going to the following pins on the Arduino
3, 5, 6, and 10
The negative terminals will all go to a common ground. I did not use any resistors in my project, depending on which LEDs you use, you may want to include them.
I'm using on of the LEDs on my proto-shield connected to pin 4 on the Arduino to indicate connectivity with the phone, and one of the toggle switches connected to pin 7.
STEP 2: Arduino Sketch
Red Bear Labs has a ton of great code for iOS, Mac OS X, and the Arduino to browse through on their GitHub page. Included in that is the Bluetooth Shield SDK. You'll want to grab support libraries from the link on their site http://redbearlab.com/bleshield/ and drop them in your Arduino libraries folder, or import them through the Arduino IDE.
After you've got them imported, check out the Sketch here
https://github.com/scottCheezem/BlueRCSketch/tree/LED_example
it is a bare bones sketch that reads from the BLE shield one byte at a time. The First byte it reads is the pin to address, the second byte is the value (0-255) to apply to the LED at that pin.
STEP 3: Xcode Project
For the iOS interface we're going to keep it simple and just use a typical Analogue game pad and a connect button. the code for the Analogue stick control comes curtisy of https://www.cocoacontrols.com/controls/jscontroller
should note that the SDK from red bear labs can also be used to Mac OS X applications....
In order to build the project and run it on a physical device you will need to join Apples iOS developer program, and have Xcode installed.
Grab the code from https://github.com/scottCheezem/BlueRCiOS/tree/LED_example
I've included the headers from Red Bear Labs and the Analogue stick controls. It should be ready to build and go, but I've only tested it on my iPhone 5 with iOS 7 beta 3
The project is built from a single view template. Joystick, a label for the signal, and a button to toggle connections - what more could you ask for in a remote control app.
STEP 4: Upload Sketch. Build & Run.
So wouldn't it be neat if someone swapped out the LEDs for some motors and added a bumper to the toggle button?
28 Comments
LeaV5 6 years ago
Hey man this for this project! I am trying to run this on IOS 10.3 and I get this error "Property 'UUID' not found on object of type 'CBPeripheral *'" in the BLE.m file. When I look at the location of these error messages they refer to p.UUID. Do you how I can fix this?
AbishekM4 7 years ago
Is it possible to receive messages from an arduino on iOS using this method?
ShivaganeshguptaS 7 years ago
is it work for HM-10 BLE , i am using HM-10 BLE
thehand 7 years ago
Hi sir, thank you for your reply please in my country avaialbe only BLE HM10. any other way to that app.
i want send 1 or 0 value to ardiuno . can u please any alternate thing.
ThankYou.
JoshH17 8 years ago
thehand 8 years ago
TheRealDryErase 8 years ago
I have managed to get the everything running but it's not connecting b/c it's not finding the arduino. I am using tinyduino and its ble module. Could me using different arduino cause the connection error.
Does anyone know what I have to change to get it working?
(https://www.tiny-circuits.com/tiny-shield-bluetooth-low-energy-nordic.html) - this is the ble module i am using
thehand 8 years ago
Unfortunately, almost definitely. The code included from this 'structable is quite specific to the Red Bear Labs Shield. Other arduino&ble all in one modules or other arduino ble shields almost certainly won't work with this code.
SanjayN8 8 years ago
Can i use BLE-Mini instead of BLE-Shield for communicate with IOS device?
bome 8 years ago
Hi!
Great project! Is it possible to connect multiple iOS devices at the same time?
Thanks!
thehand 8 years ago
No, the kind of communication in this project is board to one iOS device.
bome 8 years ago
thehand 8 years ago
Well I guess the question is "What are you trying to do?" Bluetooth (and really bluetooth serial here) may not be the right tool for the job as its really designed for a one to one pairing. if you need multiple concurrent devices communicating in both directions either with each other or the arduino, you might try something over a proper ad-hoc wireless network. if the goal is to allow multiple iOS devices to control or take part in controlling some hard ware then there are a couple of flavors of arduino or arduino-shields that allow for tcp/ip over the standard 802.11. of course there is also the Raspberry pi as well, you would need an over the counter wifi dongle, and some server software - most of which comes with the standard RPi distro.
ArneG1 8 years ago
ArneG1 8 years ago
I got it to work by using the following #include Statements.
#include <boards.h> // "boards.h" is needed for RBL_nRF8001
#include <RBL_nRF8001.h>
MaddyMaxey 8 years ago
Can't wait to give this a shot!
thehand 8 years ago
It has been a while since I ran this project, but I believe that that specific header file comes from the Red Bear Labs Github for the BLEShield.
https://github.com/RedBearLab/BLEShield
When I originally authored this intractable, Red Bear Labs had put out the first version of their arduino shield and a stand alone mini BLE board. It looks like they have since then expanded their product line and subsequent library of example code. Not to mention that there are now a bunch of other BLE boards on the market right now. My guess (based on a cursory glance at their commit history, and last updated date) is they probably changed the name of the header to keep namespace conflicts from occurring.
tldr: if you're downloading RBL support libraries for the first time now try #include<ble_sheild.h>
also. if you get this working on a fork of my BlueRcSketch, and issue a pull request, I'd happily merge it in.
greenonline 8 years ago
The ble.h header file, which is referenced in your BleRC.ino file, no longer appears to be part of the NordicSemiconductor BLE Arduino library. There is only a ble_assert.h and a lot of aci(lib) header files. Has the BLE library changed the header files or have I downloaded the wrong Arduino library?
marcmans941 8 years ago
Ok. I've been going crazy using the Redbear lab board and trying to modify the advertising packets. my problem is I am creating a unique UUID service and I want to advertise it like it says in this Bluetooth Low Energy Advertising Tutorial but I can't get the packets to show it. Has anyone done this? I have the LEDs working but I also have other sensors.
